Post by wiz on May 4, 2015 16:46:44 GMT -6
Hey guys
I am aware of how the Numbering system works in regards to Chords ...
What happens with the Kick Pattern/Bass Pattern relationship?
I have never seen a Drummer/Bass Chart , I have seen drum sheet music used.. but not a sort of drum cheat sheet.
I write them out for drummers playing on my song that can read ( a basic drum music chart that details basically kick and snare pattern), as I have already established the base groove idea in my head for the song...
I also find it unbelievably helpful for me, when laying down guide drums and bass myself, to read that pattern as I play....
just curious
Post by M57 on May 4, 2015 17:13:41 GMT -6
So you're looking for a chart for drummers (rhythms only) that focuses on what the bass player is playing?
Post by wiz on May 4, 2015 17:34:18 GMT -6
No.. I knew I hadn't explained it properly... 8)
A chart that tells the bass player and kick drum, when to play, the basic foundation of the groove...
I do this, the reason I haven't seen it is it may not exist...
I write out the basic kick pattern/snare pattern also if its needed Hi Hat and Ride as well, and instructions, e.g. Ride in this section, jungle groove on toms in bridge, go to side stick or foot chick here etc.. this way the drummers I use can come in without hearing a song and play nearly a take first pass.
Then the bass player can read the kick drum timing, and knows where the groove is...
I hope that makes it clearer... if not I will post a photo
Post by Randge on May 4, 2015 17:40:29 GMT -6
That is usually discussed within the rhythm section, post listen down of the song/chart and they just knock it out here.
R
Post by wiz on May 4, 2015 17:43:04 GMT -6
That is usually discussed within the rhythm section, post listen down of the song/chart and they just knock it out here. R Thanks Randgecheers Wiz
Post by gouge on May 4, 2015 17:44:06 GMT -6
are you asking how to score drum parts or are you looking for a shorthand version.
Post by wiz on May 4, 2015 18:15:25 GMT -6
are you asking how to score drum parts or are you looking for a shorthand version. neither. 8) In Nashville, they use a number system to show what chords are playing in the song... e.g. I IV V or 1 4 5 (C F G in the key of C) I am essentially asking, what do the drummers use.. and what does the bass player reference for timing so he is mindful of the kick pattern... Randge essentially answered it for me, the rhythm section discuss it after the rundown of the song.. then those fellas just hit it out of the park... cheers Wiz
Post by gouge on May 4, 2015 18:27:28 GMT -6
excellent, I've not heard of the term before.
but now I have. :-)
Post by Randge on May 4, 2015 19:22:47 GMT -6
Post by gouge on May 4, 2015 19:38:33 GMT -6
that's a neat system. at first I was thinking why not just write the chord above the staff as is done on jazz to allow ad lib.
then I got to the part about holding up fingers mid song to indicate chord progression and I had a moment........
how many times have is had to indicate a chord change through a window and not been able to do it easily.
Post by yotonic on May 4, 2015 19:56:54 GMT -6
If you are charting your own tune and you are the singer then you most likely have the key on lock. Maybe someone in a session might notice something in a chorus lift and suggest shifting it higher or lower for your voice, but usually you should have your song well organized in pre production and rehearsals before spending money on session time.
And if you hire an "A" session player for drums or bass and they are playing on a lot of records they are going to bring a better nuanced part to your track than anything you can chart for them. They won't need a drum chart you can beat box your idea for them or bring a work track. Most will scratch out their own notes and part on your song chart, after they have run through the song, (as Randge said) and worked in their suggestions and changes.
Most guys will give you a few different approaches based upon the breadth of their experience playing for different artists. Not to mention you want that little bit of magic that comes from letting guys contribute during the flow. Drummers have a unique perspective on songs and a lot of the good ones have a great sense for arrangement and structure. There are a couple I use precisely because I get a lot of free arrangement and producing input from them. Popular music is the drums and vocal. Don't skimp on the drummer. Also as a songwriter make sure you have your tempo dialed in so you don't get caught up in a live session and convince yourself that two more clicks is the sweet spot.... when it's not. This is an easy mistake to make if you haven't been playing your material live for awhile.
Post by NoFilterChuck on May 4, 2015 20:04:25 GMT -6
Gospel uses the same number system. I've found that it's mostly used by folks who never had formal theory training and play mostly by ear for diatonic music such as pop/country/gospel.
Post by jeromemason on May 5, 2015 0:25:54 GMT -6
I had to learn this when I was at my first job recording southern gospel. Wasn't because I needed to know the actual scales or anything, but it was so that I knew where we were in the session. If someone (and the southern gospel folks will light your ass up quick if you don't) in a session yelled back that they needed you to take it from the 4 on the 3rd bar of the 2nd verse there was no way you could know that w/o following and understanding those charts, I'd seen assistants hired that thought they could and they would get eaten alive. I guess that's why I made a fast transition when I came up here. It's something to learn, it's fast, and it's easy once you get your head wrapped around the idea. It's amazing how guys can change keys quickly and even do 2-3 key changes in a song that was not there to begin with just by scribbling the root note where the change would happen. Nothing changes on the charts, and for the guys that usually end up being the session leader and writing these the night before the session, or during the scratch run (which is amazing to watch a vet write those damn charts as the songs going) all of their work is still in tact.
When I'm running a session I'll have my copy, while the players are listening to the scratch I'll make my own little notes, things I know I'll be asked to do. If I know there is a weird lick in a song I'll number each one of them to make it quicker for me to go back to the punch, because 80% of the time you always have to, even the best players will want to go back to those and do them a little better, or give another option. There's also the repeat bars, and that's usually always where a greenhorn engineer will mess up in doing a punch if they are going by a chart, they forget the repeat bars and you hear them saying "I don't see a second verse, I don't see a second chorus" and it's sad, because that takes away from what those players had in their minds, and causes them to lose focus, it's not because they get angry or frustrated, it's just lost seconds and in this game, especially here, seconds are everything, things move 100x faster than anywhere else I've ever done anything and unless you can move with that you're not going to be everyone's favorite engineer.
Just thought I'd give an answer from a non players POV.
Post by wiz on May 5, 2015 0:38:26 GMT -6
I had to learn this when I was at my first job recording southern gospel. Wasn't because I needed to know the actual scales or anything, but it was so that I knew where we were in the session. If someone (and the southern gospel folks will light your ass up quick if you don't) in a session yelled back that they needed you to take it from the 4 on the 3rd bar of the 2nd verse there was no way you could know that w/o following and understanding those charts, I'd seen assistants hired that thought they could and they would get eaten alive. I guess that's why I made a fast transition when I came up here. It's something to learn, it's fast, and it's easy once you get your head wrapped around the idea. It's amazing how guys can change keys quickly and even do 2-3 key changes in a song that was not there to begin with just by scribbling the root note where the change would happen. Nothing changes on the charts, and for the guys that usually end up being the session leader and writing these the night before the session, or during the scratch run (which is amazing to watch a vet write those damn charts as the songs going) all of their work is still in tact. When I'm running a session I'll have my copy, while the players are listening to the scratch I'll make my own little notes, things I know I'll be asked to do. If I know there is a weird lick in a song I'll number each one of them to make it quicker for me to go back to the punch, because 80% of the time you always have to, even the best players will want to go back to those and do them a little better, or give another option. There's also the repeat bars, and that's usually always where a greenhorn engineer will mess up in doing a punch if they are going by a chart, they forget the repeat bars and you hear them saying "I don't see a second verse, I don't see a second chorus" and it's sad, because that takes away from what those players had in their minds, and causes them to lose focus, it's not because they get angry or frustrated, it's just lost seconds and in this game, especially here, seconds are everything, things move 100x faster than anywhere else I've ever done anything and unless you can move with that you're not going to be everyone's favorite engineer. Just thought I'd give an answer from a non players POV. great stuff cheers Wiz
Post by Ward on May 5, 2015 6:56:47 GMT -6
It's a great system that I use also. there is also the alternative used in Christian Worship music... the much simplified lyric sheet with chords or numbers written over the tops of the words at the points where the chords change. Sometimes sloppy but it makes it easier to follow both at the same time when you're playing and singing in a worship service.
