Post by kcatthedog on Apr 4, 2015 12:40:36 GMT -6
Hey,
I think this is Matador's list of things he tweaks in the standard c12 build.
I have ordered the CM transformer ordered, as I think Cat5 has that in his and I thought his c12 sounded great.
Are people aware of other tweaks ? I have the Campbell cap installed.
Thx !
c12 mod:
From top-to-bottom:
1) Chunger's 34mm edge-terminated capsule 2) NOS RCA 12AT7 (screened from my stash for lowest noise) 3) Silver Mica caps for on-board filters (C10, C11) 4) High impedance 30M and 250M resistances changed to 100M metal film 5) Very nice NP0/C0G ceramic cap for 1000pF C13 gate coupling cap (my favorite all-time audio coupling cap in 1nF or less sizes) 6) Cinemag CM-13114 12:1 output transformer
I will also go through and do my normal "re-tap every single hole for a stainless steel 2-56 1/4" machine screw" mod, which I have found makes a profound difference to the physical feel of the microphone (it feels tighter, and more "solid", if that makes sense). Or it might just be my imagination, but I tend to strip the stock 2mm screws out fairly frequently.
Post by watchtower on Apr 8, 2015 15:09:57 GMT -6
The only tweak I made to mine was using a paper in oil output cap. The other tweak that I want to make, but haven't yet, is tying the unused triode to ground like the original schematic
Post by kcatthedog on Apr 8, 2015 19:11:26 GMT -6
Our good friend, Cat5, kindly provided me with just such a tube !! He turned me on to the whole build in the first place and always maintained that your cap was "THE" cap for this build and luckily I managed to get one; thx Tim !
Post by tonycamphd on Apr 9, 2015 8:14:58 GMT -6
The mods I might recommend would be a GE 5 star 6072. No other tube sounds as good in this mic. Even other brands like RCA don't sound as good. If i had to pick a transformer that wasn't a Haufe original it would be Mark Fouxman's new larger core. This sounds interesting, Mark is a serious dude, what does his tranny do differently to the ami Tim? Is it toroidal? Do u have a model name? Thanx
Post by jfoc on Apr 9, 2015 9:18:30 GMT -6
Post by kcatthedog on Apr 9, 2015 12:50:09 GMT -6
I thought the CM, was custom designed based on Brain Fox's recommendation to enlarge the Transformer and then to increase its low freq response and I guess arguably tone ?
not arguing for or against, just wondering what the design intention of the different transformers was/ is and what their sonic characteristics are ?
When I get my CM, I thought I would set things up ( measure distances) acoustic guitar and vox) and record prior to switching the transformer , then record immediately afterwards but giving the modded mike a little time to warm up and post clips ?
My c12 is the stock build, with Tim's cap and the 5 star ge tube nos tube ( early 50's if I remember correctly).
