Post by Johnkenn on Mar 12, 2015 0:06:37 GMT -6
Good lord...this is driving me insane. I CAN NOT FIGURE IT OUT. In Console one, you could route the output of the AUX, e.g. I could route a reverb to a headphone channel. For some ungodly reason, they've taken that away now. Can an AUX only be sent to the monitor mix now?
Post by drew571 on Mar 12, 2015 7:43:51 GMT -6
Above each AUX channel are sends that can be sent to HP (headphone) or outputs 3/4. Is that what you're looking for? Maybe i'm confused as to what you're trying to do.
Post by Johnkenn on Mar 12, 2015 8:14:14 GMT -6
Well, I'm a bit confused too. Looks like you have a Twin, so my Apollo is a little different...but I have "Cues" which can be routed by an "output cue" button. But when I route the cue to say - Line 7-8, the monitor mix comes out of 7-8 along with it. It no longer goes to Lines 1-2. I want to have the monitor mix go to Line 1-2 like normal and then route just the AUX (reverb) to a stereo channel by itself. That way, I can use that fader on my headphones system to add/subtract only the reverb. I've yet to figure out how to separate the two. kcatthedog
Post by kcatthedog on Mar 12, 2015 8:27:01 GMT -6
i saw a reference on the ua forum site which I can't find to a duall function send and cue that I think lets you do this but I can't find the reference ! is the only source of the verb discretely without the actual dry signal the aux ?
Post by Johnkenn on Mar 12, 2015 8:36:24 GMT -6
Not sure what you mean...
Post by Johnkenn on Mar 12, 2015 8:36:47 GMT -6
If you mean, "is the vocal the only thing going to the AUX", then yes...
Post by gkashiwa on Mar 12, 2015 10:04:19 GMT -6
Good lord...this is driving me insane. I CAN NOT FIGURE IT OUT. In Console one, you could route the output of the AUX, e.g. I could route a reverb to a headphone channel. For some ungodly reason, they've taken that away now. Can an AUX only be sent to the monitor mix now? Hi Johnkenn, You can totally do this by using one of the Cue sends on the Aux. Open the Cue Outputs window and set the source to be a Cue and route the output to the physical out you want. In this case, I have Cue 1 routed to Line 7-8. I think this is what you're trying to do? The Cue sends are pre-fader so you can mute the Aux return if you don't want to monitor the effect. Hope that helps! -GK Gannon Kashiwa
Post by Johnkenn on Mar 12, 2015 10:44:05 GMT -6
Hey Gannon - thanks for stopping by! I've tried that, but when I select "Cue 1" in Cue Outputs, I'm not getting playback from Pro Tools. I'm not getting playback from PT's...When I go back to Monitor on Cue Outputs, I then hear playback from my mix on whichever Output I have selected. gkashiwa
Post by gkashiwa on Mar 12, 2015 11:20:25 GMT -6
Hey Gannon - thanks for stopping by! I've tried that, but when I select "Cue 1" in Cue Outputs, I'm not getting playback from Pro Tools. I'm not getting playback from PT's...When I go back to Monitor on Cue Outputs, I then hear playback from my mix on whichever Output I have selected. gkashiwaTwo forums/threads at once! ;-) Okay, so I think I get what you're saying now - you want Pro Tools only to appear on one set of physical outputs and Aux 1 to appear on a separate set of physical outputs, is that correct? If so, can you use Cue 1 set to MON and routed to say 5-6 so it gets the whole console and use Cue 2 routed to 7-8 with just Aux 1? The other way to do it is to return Pro Tools on a pair of Virtual Channels and use the same Cue for both Pro Tools return and the Aux. That's how I work because it gives you level control for Pro Tools on a separate fader. Will either of those accomplish what you're after? -GK Gannon Kashiwa
Post by Johnkenn on Mar 12, 2015 16:05:23 GMT -6
Sorry, gkashiwa! OK - that allowed me to get the send the Verb to 7-8 like I wanted and I'm also able to hear the monitor mix on 1-2. Problem is, I'm also still hearing the AUX verb through 1-2. I was trying to isolate the AUX verb on just 7-8 - which I was able to do in Console 1. That way, the singer can adjust the amount of verb they want from the headphone remote...If it's still coming through 1-2, I would have to control it through the send here at the computer - which isn't the end of the world at all, but it was awesome to be able to allow the singer to control it. Again, thanks for coming by - lots of UAD users and fans here. BTW - my input channel (vocal mic is S/PDIF L)
Post by Johnkenn on Mar 12, 2015 16:10:48 GMT -6
Post by gkashiwa on Mar 12, 2015 17:47:56 GMT -6
Sorry, gkashiwa! OK - that allowed me to get the send the Verb to 7-8 like I wanted and I'm also able to hear the monitor mix on 1-2. Problem is, I'm also still hearing the AUX verb through 1-2. I was trying to isolate the AUX verb on just 7-8 - which I was able to do in Console 1. That way, the singer can adjust the amount of verb they want from the headphone remote...If it's still coming through 1-2, I would have to control it through the send here at the computer - which isn't the end of the world at all, but it was awesome to be able to allow the singer to control it. Again, thanks for coming by - lots of UAD users and fans here. BTW - my input channel (vocal mic is S/PDIF L) Thanks for the warm welcome! :-) I'll try to drop by regularly. So, the last thing you need to so is just mute the Aux so you don't hear it out 1-2. It will only come out 7-8. The Cue sends are pre-fader/mute so that should solve the double-bussing. Cheers! -GK Gannon Kashiwa
Post by Johnkenn on Mar 12, 2015 18:44:44 GMT -6
Awesome. I'll try when I get home! Btw - we all vote for a Retro Instrumenta deal with UA.
Post by Johnkenn on Mar 13, 2015 18:20:00 GMT -6
Hey gkashiwa - weird...muting the AUX didn't take the verb out of 1-2...It's not a total dealbreaker of course, I can just turn the verb down at the DAW...it's just nice for the performer to be able to do it. I know this isn't your job to troubleshoot my numbskullery - maybe I'll call in next week and talk to a tech.
