Bass EQ
Aug 23, 2013 10:41:11 GMT -6
Post by jsteiger on Aug 23, 2013 10:41:11 GMT -6
Oops, Dan beat me by a few seconds! Looks like you get different results with and without the "F."
Bass EQ
Aug 23, 2013 10:41:15 GMT -6
Post by jcoutu1 on Aug 23, 2013 10:41:15 GMT -6
pma
Post by pma on Aug 23, 2013 13:08:57 GMT -6
Bass is the one thing I tend to shape a lot with EQs. Even if I track my favorite player with my favorite instrument, mic, amp. Some units just fills the bottom regardless of what is going in. I really like cutting with the low and boosting the lo mid on a 550B. 1081 can be awesome as well. And Helios modules also. I mix in a super compressed signal. Usually some tube unit. I really like Altec 436. I've heard sta-levels do a great job. A clipped V72 is sweet.
Bass EQ
Aug 23, 2013 13:17:18 GMT -6
Post by Johnkenn on Aug 23, 2013 13:17:18 GMT -6
Hey PMA...I gotta say, your avatar reminds me of Jules...[shiver]
pma
Post by pma on Aug 23, 2013 14:48:26 GMT -6
Hey PMA...I gotta say, your avatar reminds me of Jules...[shiver] Oh. Sorry. Not my intention. I liked the temple. Will change it...
Bass EQ
Aug 23, 2013 15:41:50 GMT -6
Post by Johnkenn on Aug 23, 2013 15:41:50 GMT -6
pma Ha! Man, I was just kidding!...The temple is totally fine!
Bass EQ
Aug 23, 2013 19:44:20 GMT -6
Post by cowboycoalminer on Aug 23, 2013 19:44:20 GMT -6
I stopped having any issues with bass guitar in any mix when I started doing these few things:
1. DI chain is an Avalon U5 (gain setting to bring to parity only) EQ on 4 or 5 for most basses. Into an LA4 8:1 ratio, getting about 2 to 5db gain reduction. Straight into an Avid HD interface. in the mix, just a little broad mid boost and about 3 db of low shelf cut from 200 down. Then it all comes down to level in the mix. 2. If the bassist has a great sounding amp, I'll mic the cabinets using an 87 on 15" and 421 on 10 or 12" speakers. Usually into API pres into LA3A comps, just taking down the strongest peaks. 3. Sometimes take the cleanest DI signal possible, like a countryman, and give it its own track for re-amping purposes later.
In 90% of cases, option 1 gives me everything I need and everyone's happy. Great instruments played by accomplished players makes the most difference. Good info. Thanks Ward.
Bass EQ
Aug 23, 2013 20:25:26 GMT -6
Post by Johnkenn on Aug 23, 2013 20:25:26 GMT -6
Solved my problem...
Farmed it out.
Bass EQ
Aug 23, 2013 20:37:37 GMT -6
Post by cowboycoalminer on Aug 23, 2013 20:37:37 GMT -6
Solved my problem... Farmed it out. Always works..
Bass EQ
Aug 27, 2013 10:17:18 GMT -6
Post by svart on Aug 27, 2013 10:17:18 GMT -6
when i have to mix stuff where that happens, my go-to fix the the Sony Supressor (or however you spell it). this plug can dynamically carve out the "whoomph" that muddies up the bass. as far as cutting, radial DI thru a CAPI preamp and a distressor or Sta-Level is gonna get you there. mixing- I use an 1176 and a dbx165. I also use parallel compression via an old RCA thing. I also use plugs if need be- Echoboy "bass machine" and Sansamp usually BEFORE the 1176. Ampeg SVX also. I find it interesting that the first answers are always "player" and "bass" but we always find out that the pros always use TONS of compression and effects. I don't mean to be negative to anyone or disparage the fact that a good player comes first, but I think things get a little out of proportion. Lets see.. 1. Distressor/Sta-level during tracking 2. Sonnox plug 3. More possible plugs 4. 1176 5. DBX165 6. RCA parallel.. This is pretty typical of what I've seen and read before. It's rarely just the "player and his bass". There is usually multiple compressors and effects besides the high-end preamps. This amount of processing also seems pretty standard for bass more than any other instrument.
Bass EQ
Aug 27, 2013 10:50:44 GMT -6
Post by Deleted on Aug 27, 2013 10:50:44 GMT -6
Not following the blue site anymore
Bass EQ
Aug 27, 2013 11:13:09 GMT -6
Post by svart on Aug 27, 2013 11:13:09 GMT -6
I didn't really get it.. Explain it?
Bass EQ
Aug 27, 2013 12:03:49 GMT -6
Post by tonycamphd on Aug 27, 2013 12:03:49 GMT -6
I didn't really get it.. Explain it? jules avatar picture over on the purple site looked a lot like pma's picture here? pma changed his avatar pic(as a come backer i think) in response to JK's joking about it? Ahh the nuances of communicative expression lost in the written word are a topic within itself lol!
Bass EQ
Aug 27, 2013 14:28:51 GMT -6
Post by Deleted on Aug 27, 2013 14:28:51 GMT -6
Post by popmann on Aug 28, 2013 6:06:09 GMT -6
While a squire won't help the situation...the key to getting a bass guitar to cut/punch is two components: distortion and attack time on the oppressor being SLOW.
The distortion, I still pipe it out to a Tech21 RBI. Digital plugs just have not worked as well. Ymmv, but I think modellers blow hard. And I think that because of how hard I have to work to get a single modeller rhythm track to work...digression--you want this on a second channel, because you want to be able to heavily filter the distortion and use it to enhance the main track. My mixing template has two channels for bass routed to a mono buss.
Second one is as important. IME--the bass's attack is its punch/definition, but the sustain will be responsible for mud and "loud notes" (hot spots on a squire?)...and low frequency waves take some time to develop, so you want a solid 27-40ms attack time with a pretty med quick release say 150-180ms. The idea being you want to leave the player's finger dynamics on the attack while controlling the sustained volume. This is an example where a little goes a long way--you need it to recover naturally. So, we're talking 3-5db gain reduction.
Also...eq? Very little. HPF. higher than your 50hz on any song with a pulse. Then, it depends on context and the bass and how it was tracked. Usually there a bump between 4-8khz to play up the attack more after the oppressor, but again--sometimes the distortion channel takes care of that. In fact, I've been known to filter IT at like 250hz and 8khz. Jazz basses are usually harder to mix than Ps. I finally sold mine so that I'd never have that experimental moment where I use it for a track and regret it once the arrangement's built around it. If you want to hear the bass. If you don't and just want to feel low end--thats what Jazz's do. It's counter intuitive, since alone they have more articulation, but my experience has been they want to gel into the background more, where a P has the higher lows and mid bark that actually cuts in a mix.
Bass EQ
Aug 29, 2013 19:55:36 GMT -6
Post by cowboycoalminer on Aug 29, 2013 19:55:36 GMT -6
So I've been working very hard on this. Trying different things. This track here I drove the living hell out of the Heritage and I think it's the closest to a good sound I've gotten yet. Thoughts, comments, concerns? dl.dropboxusercontent.com/u/65640533/Bass%20Test.wav
Bass EQ
Aug 29, 2013 20:13:31 GMT -6
Post by Martin John Butler on Aug 29, 2013 20:13:31 GMT -6
The tone's pretty good, a bit loud in the mix. I think the bass itself isn't a great one. As a guitarist, I'm glad I have a very decent Mexican Fender P-Bass. It's been set up by a great tech here, and plays well. But, if I think about it, my guitar tracks might not sound the way they do if I didn't have a mint, vintage ES-335 or my Martin D-41 Turbo. In the same way, if we were bass players, we would likely have one or two premium basses, like a 66 Jazz Bass or something similar. I think that makes a world of difference on the country tunes you're referencing. Also, our bass playing just isn't that great, when compared to the full time session pros.
The one time I played a rare vintage Fender bass on a track, it sustained notes so long, it was unbelievable. I played differently because of it. Less notes, better placed. That thing just filled up the track without my even trying.
Bass EQ
Aug 30, 2013 7:40:36 GMT -6
Post by svart on Aug 30, 2013 7:40:36 GMT -6
So I've been working very hard on this. Trying different things. This track here I drove the living hell out of the Heritage and I think it's the closest to a good sound I've gotten yet. Thoughts, comments, concerns? dl.dropboxusercontent.com/u/65640533/Bass%20Test.wavI hear the faintest bit of bite in the midrange from the harmonics of the extra drive. I think it's a little loud in the mix and a little tubby. Bring it down a little bit and cut a little bit out from between 200-300 and you're there.
crash
Bass EQ
Aug 30, 2013 8:12:29 GMT -6
Post by crash on Aug 30, 2013 8:12:29 GMT -6
My bass playing buddy loves the sound of his bass going through one of these whenever I run his track through mine.
Bass EQ
Aug 31, 2013 14:48:56 GMT -6
Post by cowboycoalminer on Aug 31, 2013 14:48:56 GMT -6
Thanks for the tips. I think I like the tone but it still needs some tuning. I'l post a better example when I'm satisfied.
Bass EQ
Aug 31, 2013 19:00:28 GMT -6
Post by jazznoise on Aug 31, 2013 19:00:28 GMT -6
Where are people picking on their bass and what picks?
I usually just end up using Blue Tortex's pretty around the neck pickup area, but I see some guys picking at the bridge. Depending what pickup and what position you play, you'll end up highlighting different harmonics. J Basses are particularly notable for this - you'll get a prominent +2 oct sound at one point, a +1 oct and a major third at another. The harmonics are crazy, yo!
Bass EQ
Aug 31, 2013 20:49:01 GMT -6
Post by popmann on Aug 31, 2013 20:49:01 GMT -6
Fingers. All over.
Picks are only good for really specific sounds.
Bass EQ
Sept 1, 2013 0:20:09 GMT -6
Post by ionian on Sept 1, 2013 0:20:09 GMT -6
Fingers. All over. Picks are only good for really specific sounds. It's a combination of technique, how it's recorded, EQ'd, and compressed that gets you your final sound regardless of using a pick or fingers. Carol Kaye has always recorded with a pick and she sounds great regardless. Regards, Frank
Bass EQ
Sept 1, 2013 20:17:15 GMT -6
Post by cowboycoalminer on Sept 1, 2013 20:17:15 GMT -6
I've seen felt picks. They seem to be close to fingers.
Post by Johnkenn on Sept 3, 2013 18:50:08 GMT -6
Stealing this from headtraffic... Did u hear about the bass player who was so depressed about his bad timing that he threw himself behind a train?
