Bass EQ
Aug 22, 2013 8:59:34 GMT -6
Post by jsteiger on Aug 22, 2013 8:59:34 GMT -6
I sent an email to Reid but I don't know if he'll post. I will also ask Drew. He has been working as Justin's assistant for 15 years or so.
Bass EQ
Aug 22, 2013 9:06:07 GMT -6
Post by lolo on Aug 22, 2013 9:06:07 GMT -6
Heard a interview a while ago where he said he uses a 1176 on Bass, and also Decapitator(Sound toys). That plug can do wonders. Little Gem
Post by makeitwork on Aug 22, 2013 9:15:45 GMT -6
hello all. with all due respect, this is probably a player issue. i've gotten tons of bass tracks that are cut through the best stuff but if the player's not articulating well, it's going to be a bit of a mess. when i have to mix stuff where that happens, my go-to fix the the Sony Supressor (or however you spell it). this plug can dynamically carve out the "whoomph" that muddies up the bass. as far as cutting, radial DI thru a CAPI preamp and a distressor or Sta-Level is gonna get you there. mixing- I use an 1176 and a dbx165. I also use parallel compression via an old RCA thing. I also use plugs if need be- Echoboy "bass machine" and Sansamp usually BEFORE the 1176. Ampeg SVX also. whatever works. YMMV! thanks, Reid Attachments:
Bass EQ
Aug 22, 2013 10:21:28 GMT -6
Post by tonycamphd on Aug 22, 2013 10:21:28 GMT -6
IME, i use a simple formula when it comes to bass /kick synergy
big open bass drums 26/24"=jazz bass small damped bass drums 22"/smaller=p bass
I don't use any other basses.
Bass EQ
Aug 22, 2013 10:24:48 GMT -6
Post by jsteiger on Aug 22, 2013 10:24:48 GMT -6
Bass EQ
Aug 22, 2013 10:25:34 GMT -6
Post by Martin John Butler on Aug 22, 2013 10:25:34 GMT -6
Great thread, and great responses.
Bass EQ
Aug 22, 2013 10:35:49 GMT -6
Post by Martin John Butler on Aug 22, 2013 10:35:49 GMT -6
Great posts guys, thanks. Svart mentioned harmonic supplementation, and I think he's onto something, that's a likely part of the picture. makeitwork said, "this is probably a player issue", that's what I was referring to in the previous page. One of my friends who's done a dozen major label albums was visiting, and played on a track of mine. It still needs something more, but same bass, same signal path, and it's 45% closer than my playing was. Also, Tony makes a good point. Much as I prefer the feel of a P-Bass, most tracks with bass I love have Jazz basses. Bands like Coldplay get a kick ass bass sound with a P-Bass, so I can't say that the jazz bass is actually better. I'll try tony's suggestion about matching up the bass with the drums.
There are quite a few contributing factors here, so it's not so easy to say which is the most egregious cause of shall I say.. "Flabby Bass Syndrome"?
If someone here has a track that really gets it right, maybe take a look at the signal path and let us know.
Bass EQ
Aug 22, 2013 12:03:11 GMT -6
Post by Johnkenn on Aug 22, 2013 12:03:11 GMT -6
hello all. with all due respect, this is probably a player issue. i've gotten tons of bass tracks that are cut through the best stuff but if the player's not articulating well, it's going to be a bit of a mess. when i have to mix stuff where that happens, my go-to fix the the Sony Supressor (or however you spell it). this plug can dynamically carve out the "whoomph" that muddies up the bass. as far as cutting, radial DI thru a CAPI preamp and a distressor or Sta-Level is gonna get you there. mixing- I use an 1176 and a dbx165. I also use parallel compression via an old RCA thing. I also use plugs if need be- Echoboy "bass machine" and Sansamp usually BEFORE the 1176. Ampeg SVX also. whatever works. YMMV! thanks, Reid WHAT! MY bass playing could be the problem? Impossible... Actually, I think you're dead on. BTW - thanks for dropping by!!
Bass EQ
Aug 22, 2013 12:12:11 GMT -6
Post by Deleted on Aug 22, 2013 12:12:11 GMT -6
Don't solo the bass, free sansamp plug is really cool (so are the Kemper profiles), highpass your guitars more than you think.
Bass EQ
Aug 22, 2013 15:36:00 GMT -6
Post by ionian on Aug 22, 2013 15:36:00 GMT -6
This won't help if you're mixing someone else's tracks but when you're doing your own, it comes down to the player. I'm a good friend with a popular NYC session bass player and he plays on my stuff all the time and the knowledge he brings to the table that I never considered is staggering.
First of all, the playing needs to be extremely clean to avoid ringing from the other strings. Ringing can sneak in and cause all kinds of problems, masking and fuzziness - especially once you start compressing. Second, how things are played and on what strings contribute greatly to the sound. I'll show him what I want and he'll take a minute to figure out the best way to to play it for a recording, usually explaining to me along the way. Plenty of times he'll play things that look awkward because he staying on a single string but he'll tell me the tone on that string is better for the recording for that phrase he's playing. Or he'll add technique to back things up - for example adding a quick slide up to a high note rather than just playing it to "add weight" as he puts it, to that note. On the same song he'll play regular and then some things he'll play as octaves. In essence he's balancing the tone and the dynamics of his instrument for me automatically for what will translate best for a recording even though it looks completely awkward for bass playing. In the end, in the track, it sounds like a bass just being played regularly, but the amount of tricks he does to his playing to make it sound like that amazes me.
I know it's not magic bullet advice but it does make a big difference. I usually have no problems getting good results from a mix he played bass on. Just something to consider - experiment with your bass player and try different techniques and see how they translate in the recording. Sometimes just playing notes on different strings creates enough of a tone change that can cause random notes to jump out or disappear.
Regards, Frank
Bass EQ
Aug 22, 2013 16:00:25 GMT -6
Post by tonycamphd on Aug 22, 2013 16:00:25 GMT -6
ionian, that is a great point, my 72 jazz bass sounds all together great IMO, but for certain tones i will stick to a certain string, even when it's inefficient form a hand positioning perspective.
I think everyone would agree, there is no substitution for a great player on a great instrument.
Bass EQ
Aug 22, 2013 16:45:22 GMT -6
Post by Martin John Butler on Aug 22, 2013 16:45:22 GMT -6
cowboy, the type of sound you were describing on some Nashville recordings, do you know what the signal path was on any of them? It would be cool if we knew exactly how a certain bass we liked was done. That might help us get to the bottom of this.
Oh, I just remembered something, a long time back, I did a quick demo of a song I wrote that went to Willy Nelson. My friend had a 16 Tk. Tascam that he'd just gotten for his office, and little else, (he's in film and media) . I borrowed his original 60's Jazz bass, or whatever year the most desirable Jazz Bass was made. When I played on the track, I sounded pro, real pro, kinda like what cowboy was referring to. So, now that I remembered that, I can say that the tone of the bass itself is a big factor. Add in playing skill, and then some good processing, you get good sound.
I bet there's a few tips and tricks that would help, but a great player on a great instrument is key. Then, how to record and mix that is what's left.
Bass EQ
Aug 22, 2013 16:47:45 GMT -6
Post by wiz on Aug 22, 2013 16:47:45 GMT -6
Give bass rider from waves a demo.
I actually use it a lot.
I track with a touch of opto compession usually, and then Its quite amazing how well bass rider works. It doesnt change the tone, but makes the bass sit.
Its the only one of those"automatic" plug in things I have ever tried, that has stayed on my system.
Bass EQ
Aug 22, 2013 17:12:17 GMT -6
Post by Martin John Butler on Aug 22, 2013 17:12:17 GMT -6
Hmmm.. Bass Rider? Never heard of it, and so I looked, and it's sitting in my Waves folder, gotta love that. I'm gonna ry that next time I get some tracks going. Thanks wiz ! I use Waves vocal rider sometimes, even with my LA2, it seems quite transparent.
Bass EQ
Aug 22, 2013 17:17:44 GMT -6
Post by mobeach on Aug 22, 2013 17:17:44 GMT -6
I thought #1 had the better tone.
Bass EQ
Aug 22, 2013 17:27:03 GMT -6
Post by mobeach on Aug 22, 2013 17:27:03 GMT -6
This song is nothing special but I plugged my bass into a Presonus tube preamp then straight into an Alesis USB board then into Reaper 32 bit. It's not too bad considering the whole hardware chain is only worth $300
Post by cowboycoalminer on Aug 22, 2013 18:15:06 GMT -6
hello all. with all due respect, this is probably a player issue. i've gotten tons of bass tracks that are cut through the best stuff but if the player's not articulating well, it's going to be a bit of a mess. when i have to mix stuff where that happens, my go-to fix the the Sony Supressor (or however you spell it). this plug can dynamically carve out the "whoomph" that muddies up the bass. as far as cutting, radial DI thru a CAPI preamp and a distressor or Sta-Level is gonna get you there. mixing- I use an 1176 and a dbx165. I also use parallel compression via an old RCA thing. I also use plugs if need be- Echoboy "bass machine" and Sansamp usually BEFORE the 1176. Ampeg SVX also. whatever works. YMMV! thanks, Reid Thanks for taking the time! Glad your here, Reid.
Bass EQ
Aug 22, 2013 18:53:10 GMT -6
via mobile
Post by jcoutu1 on Aug 22, 2013 18:53:10 GMT -6
I'll second this. Great credits man. Nice variety.
Bass EQ
Aug 22, 2013 19:13:01 GMT -6
via mobile
Post by lolo on Aug 22, 2013 19:13:01 GMT -6
I'll second this. Great credits man. Nice variety. +1 Fellas give decapitator a go next time on a bass track.
Bass EQ
Aug 22, 2013 19:18:15 GMT -6
Post by Johnkenn on Aug 22, 2013 19:18:15 GMT -6
Yeah, Reid's kind of a big deal!
I use Decapitator on EG's all the time too.
Bass EQ
Aug 23, 2013 9:32:39 GMT -6
Post by Ward on Aug 23, 2013 9:32:39 GMT -6
I stopped having any issues with bass guitar in any mix when I started doing these few things:
1. DI chain is an Avalon U5 (gain setting to bring to parity only) EQ on 4 or 5 for most basses. Into an LA4 8:1 ratio, getting about 2 to 5db gain reduction. Straight into an Avid HD interface. in the mix, just a little broad mid boost and about 3 db of low shelf cut from 200 down. Then it all comes down to level in the mix. 2. If the bassist has a great sounding amp, I'll mic the cabinets using an 87 on 15" and 421 on 10 or 12" speakers. Usually into API pres into LA3A comps, just taking down the strongest peaks. 3. Sometimes take the cleanest DI signal possible, like a countryman, and give it its own track for re-amping purposes later.
In 90% of cases, option 1 gives me everything I need and everyone's happy. Great instruments played by accomplished players makes the most difference.
Bass EQ
Aug 23, 2013 10:29:45 GMT -6
Post by dandeurloo on Aug 23, 2013 10:29:45 GMT -6
Each style of music will have different needs from your bass track. A number of things need to be dealt with on the front end. Here are a few of the things I have been doing lately when tracking bass.
Tone, attack and overall vibe come from tracking. No matter what style you are tracking, recording the harmonics is a huge part of getting the bass to not be lame. Trying to get rich harmonics from a sterile bass track is really hard even with the thousands of saturation and harmonics plugs out.
I almost always use at least a VP312 DI into a ML into my LA 2A. This is a fantastic sound for any style with tons of flexibility. In many cases this is all that is needed. I have also started to split the signal and run it into this little tube DIY preamp/proto thing I built and run that into some other compressor or pedal for the extra harmonics. I don't always eq it depends a lot on the style. But if I do eq its usually a neve type of eq or a pultec.
Most the time I am using a Tonesmith bass I built a few years ago when I was still building guitars. That bass is really hard to beat. A great bass makes it a lot easier. If you are dealing with dead notes up and down the neck it will be really hard to get a great sound. Also, try playing with a pick or moving your right hand towards the bridge. Stuff like that really makes a huge difference when looking for attack and clarity. In the box Decapitaor and Sansamp are nice on bass. But getting the tone and even playing on the way in is a must!
I almost never record a bass amp anymore for many reasons.
Bass EQ
Aug 23, 2013 10:33:01 GMT -6
Post by tonycamphd on Aug 23, 2013 10:33:01 GMT -6
Yeah, Reid's kind of a big deal! I feel out of the loop, i'm trying to find Reid's credits with no luck? anyone got a link? thanx T
Bass EQ
Aug 23, 2013 10:39:09 GMT -6
Post by dandeurloo on Aug 23, 2013 10:39:09 GMT -6
Bass EQ
Aug 23, 2013 10:39:14 GMT -6
Post by jsteiger on Aug 23, 2013 10:39:14 GMT -6
