Post by Deleted on Feb 13, 2015 20:30:49 GMT -6
so if the above is true(and i believe you), I would think that PT would be at least equal to the most accurate of DAWS simply because it's in the hands of the most users and most professional studios. Wouldn't it stand to reason that those users would be screaming at the top of their lungs if it didn't sound as good, if not better than any other DAW out there? It certainly makes sense that this would be the case, whether it is or not is another story. To be clear, for me personally, i don't like the behavior of Avid, but i absolutely love the way PT works, and it continues to get better with every iteration IMO If were in an ideal world where they've not dropped the ball somewhere, with DAWS set up to match (which most users don't bother with such things as Pan Law). Were talking nuances at best.. But it's not an ideal world, a 32 bit engine FP summation (24 bit Mantissa) with all filters correct should cover us at around 140dB and be perfectly fine. But some times chucking more bits at it works, sometimes we change the order of operation. But what exactly does all this entail? Mixers? EQ's? Filters etc. 64-bit summing can have it's advantages, or none at all dependant on what you're doing. So is it right? Is it wrong? Could you notice? Is it an accumulation? Do your plugs have variable non-linear factors? How exactly are we trying to re-produce this? As said lot of it's nuances, how much of this is down to placebo? How much of it's down to the user and the DAW. Correlative responses even from people in Audio Technology can vary. General rule is, unless they've done an oopsie in places. Were cool!>.
Post by tonycamphd on Feb 13, 2015 20:32:18 GMT -6
well, i can tell you that when i get my new converters i'll be able to use any DAW i want, so i'll give Cubase 8 demo a whirl, if it sounds better than PT to me? you know I won't be shy about letting yall know what i think 8)
Post by formatcyes on Feb 14, 2015 0:13:58 GMT -6
I would expect PT11 to have less issues than Cubase8 It a much newer platform just as I would expect cubase to have less issues than pt(1 to 10) rtas. Each generation requiring backward compatibility is going to cause issues. Altho I have issues with avid and I am always looking to jump ship I like the way they have built PT 11 from the ground up without worrying about legacy plugins or old hardware.
Post by cowboycoalminer on Feb 14, 2015 1:19:37 GMT -6
so if the above is true(and i believe you), I would think that PT would be at least equal to the most accurate of DAWS simply because it's in the hands of the most users and most professional studios. Wouldn't it stand to reason that those users would be screaming at the top of their lungs if it didn't sound as good, if not better than any other DAW out there? It certainly makes sense that this would be the case, whether it is or not is another story. To be clear, for me personally, i don't like the behavior of Avid, but i absolutely love the way PT works, and it continues to get better with every iteration IMO PT continues to get better because Avid keeps putting in bits and pieces that Steinberg has had for years Tony. One tiny thing at a time per update mind you. Everybody knows that PT is the pro studio standard. Not front page news. But what a lot seem to forget is Steinberg has been at digital audio every it as long as Avid. As someone said earlier an entire platform of dsp was created by them. They're business model is and has been impeccable over the years. Now concerning the "which one sounds better" debate, seriously, does it matter? I can screw up a perfectly good mix on any of them. Which sounds better never really enters my mind personally. To be honest, anyone worth their salt can take Garage Band using it's stock plugins and make a record ready for the radio if they know what they're doing. Like Kennedy says, it's the Indian, not the arrow. The WORKFLOW is what I love about Cubase. Seemless to me.
Post by porkyman on Feb 14, 2015 1:54:26 GMT -6
Many have been inclined. Every "proper shootout" Ive heard the files nulled. So an outside observer would assume it all comes down to user bias. just curious. did these proper tests go out through converters and back into a different DAW. same set up of course for both. i contend the differences ppl are hearing are in the DAW's as media players, and not digital summing. if you take the same wav files and print them in two different DAW's, of course they are going to null. they are the same file. it would be like moving a file from one folder to another. the difference is in playback of audio. in other words, you can play the same file through two different media players and they will sound different. but if you put those two files in the same DAW they will of course null, because they are in fact the same file. i posted this in the other forum and got a bunch of sh?t of course. audiofest.info/2011/video_player.php?video_id=20in this video Dr. Rob Robinson, who wrote driver code for Apple for 27 years explains why. clumpy data delivery causes jitter. here is another source www.audiostream.com/content/media-player-qa-q4-what-makes-one-media-player-sound-different-another where 8 other media player developers confirm the same thing, "the efficiency of getting music to the DAC is the main determinant of sound quality." in my experiences, and ive tried pretty much all of them, there are significant differences between them, and not just between different DAW's but between older and newer versions of the same one. especially cubase. there is a big difference between cubase 5 and cubase 7. IMO protools sounds the best, and is the best. i wish to god that weren't the case. that being said, i know i will eventually be leaving PT, and am 99% sure i will end up on cubase. so i hope it was 8 you tried and it really does sound better.
Post by drbill on Feb 14, 2015 10:55:56 GMT -6
Many have been inclined. Every "proper shootout" Ive heard the files nulled. So an outside observer would assume it all comes down to user bias. just curious. did these proper tests go out through converters and back into a different DAW. same set up of course for both. Nope. You've got to keep the converters out of the variables. Should be mixed internally in both DAW's, pan laws, levels, etc. same. No FX, EQ, etc. Internally mixed, then imported into one or the other DAW, polarity invert one or the other files. Listen.
Post by swurveman on Feb 14, 2015 11:39:34 GMT -6
I have both and don't hear a difference. There are some things that I like about Cubase and some Pro Tools. If the Pro Tools software engineers had showed some consideration for ASIO based interfaces, I'd use it a lot more.
Post by tonycamphd on Feb 14, 2015 12:25:53 GMT -6
I have both and don't hear a difference. There are some things that I like about Cubase and some Pro Tools. If the Pro Tools software engineers had showed some consideration for ASIO based interfaces, I'd use it a lot more. ? Why would they do that? Use a window computer or help steinberg I mean 8) asio is steinbergs baby right?
Post by swurveman on Feb 14, 2015 12:37:20 GMT -6
I have both and don't hear a difference. There are some things that I like about Cubase and some Pro Tools. If the Pro Tools software engineers had showed some consideration for ASIO based interfaces, I'd use it a lot more. ? Why would they do that? Use a window computer or help steinberg I mean 8) asio is steinbergs baby right? ASIO may be Steinberg's baby, I don't know, but interfaces like my RME also have the option to utilize ASIO if you want to. I don't understand why any seller of software would tailor a product to one computer type. I don't think Avid did that with Pro Tools 11 software. As for the reason why they would include ASIO: they would do it is to keep customers coming back to their company. Not building in ASIO makes it more difficult for me to do my job. When I go to purchase something that Avid sells- like perhaps a DAW Controller- I will keep in mind that they could have added ASIO, but didn't and made my life more difficult. I certainly will never buy their HD system, it doesn't make any financial sense. I can get the same results (if not better- my RME-Aurora is stable as hell) for way less $$$$.
Post by tonycamphd on Feb 14, 2015 12:42:33 GMT -6
? Why would they do that? Use a window computer or help steinberg I mean 8) asio is steinbergs baby right? ASIO may be Steinberg's baby, I don't know, but interfaces like my RME also have the option to utilize ASIO if you want to. I don't understand why any seller of software would tailor a product to one computer type. I don't think Avid did that with Pro Tools 11 software. As for the reason why they would include ASIO: they would do it is to keep customers coming back to their company. Not building in ASIO makes it more difficult for me to do my job. When I go to purchase something that Avid sells- like perhaps a DAW Controller- I will keep in mind that they could have added ASIO, but didn't and made my life more difficult. I certainly will never buy their HD system, it doesn't make any financial sense. I can get the same results (if not better- my RME-Aurora is stable as hell) for way less $$$$. I agree with this, considering the greedy nature of Avid, i assume they excluded it for fear of losing money, not making it? i wonder why they don't? a deal with apple maybe? inquiring minds want to know.
Post by swurveman on Feb 14, 2015 12:59:22 GMT -6
ASIO may be Steinberg's baby, I don't know, but interfaces like my RME also have the option to utilize ASIO if you want to. I don't understand why any seller of software would tailor a product to one computer type. I don't think Avid did that with Pro Tools 11 software. As for the reason why they would include ASIO: they would do it is to keep customers coming back to their company. Not building in ASIO makes it more difficult for me to do my job. When I go to purchase something that Avid sells- like perhaps a DAW Controller- I will keep in mind that they could have added ASIO, but didn't and made my life more difficult. I certainly will never buy their HD system, it doesn't make any financial sense. I can get the same results (if not better- my RME-Aurora is stable as hell) for way less $$$$. I agree with this, considering the greedy nature of Avid, i assume they excluded it for fear of losing money, not making it? i wonder why they don't? a deal with apple maybe? inquiring minds want to know. Unless the development costs are huge, I don't see how it would lose them money. Perhaps there's a software engineer that can chime in. They know that there are tons of people using hybrid converter/interface systems. They created a software for that market, but kept out a key component that Pro Tools HD has-being able to monitor musicians inputs/cue mixes from within the Pro Tools interface. Did they think I'd sell my system and buy an HD system because I don't have direct monitoring from their interface? Hell, I'd have paid a premium for ASIO in the software. Maybe that's their next move. I don't know. But like I said, it left a bad taste, and they should have been thinking about the money they could lose on their other products as well. The PT HD domination for DAW's is over. They lost.
Post by drbill on Feb 14, 2015 13:21:57 GMT -6
Every manufacturer makes a calculated decision on what they BELIEVE will net them a better bottom line. Steinberg obviously believes that open source will net them a better bottom line, AVID takes a complete different tact and keeps things proprietary. Neither approach is necessarily evil or better or worse. It's all in how it's implemented. Ultimately they are both in it for the money and both companies are trying to make the most money they can. Pick your poison.....
Post by tonycamphd on Feb 14, 2015 13:27:28 GMT -6
JMO, I think they blew it with their squeezing big time, if you look at the digi002, the basic layout of the thing was ripe for upgrades, they dumbed down the build and components to limit it's quality, if they would have just done 2 things, i'd bet they would be the only daw co. in existence right now. Those 2 things would have been, upgrade the PSU, component path and clock to the standards of what the BLA signature mod did to the 002, and make them linkable up to 32 channels(how many guys would have bought 4 each of those units!), then keep the HD stuff for the really big guys, which would have been totally feasible considering they would have had the entire market share, and wiped the competition clear off the map. Word.
Post by Johnkenn on Feb 14, 2015 15:05:01 GMT -6
I have to admit, there are some routing things in Cubase that make more sense to me...but I DO miss the multi-tool in PT's...
Post by Deleted on Feb 14, 2015 16:21:39 GMT -6
I have both and don't hear a difference. There are some things that I like about Cubase and some Pro Tools. If the Pro Tools software engineers had showed some consideration for ASIO based interfaces, I'd use it a lot more. Asio drivers have worked in PT Native (HD Native as well) for years, since about version 9 I believe. Even though it's not "officially" supported, you can even use ASIO4ALL if you wish. tonycamphdFor HD / HDX the idea was to create an all-in-one medium that was easy to support and had plenty of raw grunt for professional studios, I'm pretty sure Avid don't want to loose money. But in todays market the HDX all in one model doesn't work like it used to, hence them trying to retrofit native solutions to solidfy them for the ever exploding home recording market. Make no mistake PT is a heavy piece of complex gear and it's not simple to just change the infrastructure. Whereas new up and comers had no relative restrictions building a clean infrastructure from scratch.. Even though I love Samplitude, the UI / front end could do with a re-write but it's a massive job that takes years. drbillNull tests don't prove much, were talking about underlying libs here that correlate to PCM which is the same for Wav and Aiff. For example if I use QtMultimedia (A sub-lib) I can just play back raw PCM (PCM supplies the RIFF header, sample rate info, BPS etc.) it's universal and should never vary. The only thing that matters is how the DAW influences the process from beginning to end and it's very hard to create an accurate test at home, we use specific tools for testing all sorts of components. Even in the core libs like FMOD vs. Bass, I've noticed latency issues. So slapping some PCM data in and phase cancelling it out, really doesn't mean much in the grand scheme of things. @me Finally, all that should really matter is workflow and in-built tools. Again why I use Samp, it's very stable and I've no concerns with it whilst Samp comes with a metric ton of features. The final cherry on the top is how good the in-built plugs are.!
Post by cowboycoalminer on Feb 14, 2015 16:53:30 GMT -6
I have both and don't hear a difference. There are some things that I like about Cubase and some Pro Tools. If the Pro Tools software engineers had showed some consideration for ASIO based interfaces, I'd use it a lot more. Me too!
Post by cowboycoalminer on Feb 14, 2015 16:57:48 GMT -6
I have both and don't hear a difference. There are some things that I like about Cubase and some Pro Tools. If the Pro Tools software engineers had showed some consideration for ASIO based interfaces, I'd use it a lot more. ? Why would they do that? Use a window computer or help steinberg I mean 8) asio is steinbergs baby right? Well in a way, ASIO is our baby. It gives power to the users to decide what they want to use. The hammerlock that Avid seems hellbent on keeping with their software has been a piss poor business model IMO. Honestly, I hope Avid see's the benefit of giving us all the freedom we want. They would see a lot of native people flock to them if they did.
Post by cowboycoalminer on Feb 14, 2015 17:02:18 GMT -6
Every manufacturer makes a calculated decision on what they BELIEVE will net them a better bottom line. Steinberg obviously believes that open source will net them a better bottom line, AVID takes a complete different tact and keeps things proprietary. Neither approach is necessarily evil or better or worse. It's all in how it's implemented. Ultimately they are both in it for the money and both companies are trying to make the most money they can. Pick your poison..... I agree, but it makes me wonder why someone hasn't stood in a marketing meeting at Avid and say, "Hey fellas, I'll bet we could make more money if we designed our software for the masses." After all, there are way more masses than pro studios these days.
Post by Deleted on Feb 14, 2015 17:03:57 GMT -6
? Why would they do that? Use a window computer or help steinberg I mean 8) asio is steinbergs baby right? Well in a way, ASIO is our baby. It gives power to the users to decide what they want to use. The hammerlock that Avid seems hellbent on keeping with their software has been a piss poor business model IMO. Honestly, I hope Avid see's the benefit of giving us all the freedom we want. They would see a lot of native people flock to them if they did. What am I missing here? As said PT Native and HD Native has worked with Asio drivers for years, again not officially supported but works fine with ASIO4ALL. Are you talking HDX?
Post by cowboycoalminer on Feb 14, 2015 17:11:19 GMT -6
It's unstable as shit, Shadow. I can't get through 1 PT session without getting 50 error messages. And it's because the software was never designed to work with just any system. They threw a "bridge fix" into the software years later to try and gather a little more coin from the little guy.
But it's practically unusable for someone who wants a smooth running, high powered native system.
To be fair I've heard from many that the PT 11 update has addressed many of these issues but I was done with Avid years ago so I can't say.
Post by Deleted on Feb 14, 2015 17:21:35 GMT -6
It's unstable as shit, Shadow. I can't get through 1 PT session without getting 50 error messages. And it's because the software was never designed to work with just any system. They threw a "bridge fix" into the software years later to try and gather a little more coin from the little guy. But it's practically unusable for someone who wants a smooth running, high powered native system. To be fair I've heard from many that the PT 11 update has addressed many of these issues but I was done with Avid years ago so I can't say. Thanks for clearing that up chief, I left ages ago so I'm not sure what's going on. I was testing with an Mbox pro and Lynx Aurora and never had any specific issues with the ASIO driver set. At the moment I'm using PT9 native, with the Audient ID22 and MOTU still not had any ASIO driver issues. Then again I've had issues with the Mbox's and had a lot of weird issues with PT in general. So it doesn't suprise me ..
Post by formatcyes on Feb 14, 2015 19:23:43 GMT -6
It's unstable as shit, Shadow. I can't get through 1 PT session without getting 50 error messages. And it's because the software was never designed to work with just any system. They threw a "bridge fix" into the software years later to try and gather a little more coin from the little guy. But it's practically unusable for someone who wants a smooth running, high powered native system. To be fair I've heard from many that the PT 11 update has addressed many of these issues but I was done with Avid years ago so I can't say. PT11 is a different beast. Feels like PT only it's fast and stable. I know shocking its taken me quite a while to become accustomed to it not crashing.
Post by Johnkenn on Feb 14, 2015 20:11:38 GMT -6
10 was pretty damn solid for me. I don't think 11 has ever crashed.
Post by drbill on Feb 14, 2015 21:49:42 GMT -6
Every manufacturer makes a calculated decision on what they BELIEVE will net them a better bottom line. Steinberg obviously believes that open source will net them a better bottom line, AVID takes a complete different tact and keeps things proprietary. Neither approach is necessarily evil or better or worse. It's all in how it's implemented. Ultimately they are both in it for the money and both companies are trying to make the most money they can. Pick your poison..... I agree, but it makes me wonder why someone hasn't stood in a marketing meeting at Avid and say, "Hey fellas, I'll bet we could make more money if we designed our software for the masses." After all, there are way more masses than pro studios these days. Certainly more semi-pro studios than pro studios. But what you're missing is that post production is AVID's cash cow, and it's one that keeps on giving and giving and giving. If they had to compete ONLY in record style audio studio's, they would have changed things up a decade ago. But they are not going to give up the hands that feed them, and it's been working. I've never seen a company that's pulled a rabbit out of the hat more times than AVID. And they did make an effort at the bottom of the market. They just couldn't get "with it", and it ended up coming close to tanking them. Remember Mbox. Also what was the super crippled version? PT Essentials? Im pretty sure they had that FS at Toys R Us. Designed to bring in all the kids at a low $99 price tag. SEriouisly. Then there was the whole M-Audio decade. Let's face it, they are far better at being focused on the high end of the high end than the low end. And there's nothing wrong with that unless you're forced to play in that realm and don't have the money to effectively play their game. THEN, it's a serious frustration.
Post by drbill on Feb 14, 2015 21:57:00 GMT -6
It's unstable as shit, Shadow. I can't get through 1 PT session without getting 50 error messages. And it's because the software was never designed to work with just any system. They threw a "bridge fix" into the software years later to try and gather a little more coin from the little guy. But it's practically unusable for someone who wants a smooth running, high powered native system. To be fair I've heard from many that the PT 11 update has addressed many of these issues but I was done with Avid years ago so I can't say. That's a config issue then. Set up correctly, PT (at least HD/HDX) is hands down the most stable system out there. There's a reason that it's the only system in the world that orchestral recording engineers trust and use when it's costing them thousands of dollars a minute to record. Same thing with Dub stages. Thousands of dollars an hour. No room for even one reboot a week. However, configured incorrectly (and that's a pretty easy thing to do - especially on a PC) yes, it can be nightmarish - just like any daw can be.
