Post by ben on Jan 14, 2015 17:52:40 GMT -6
I just bought the Mbox Pro 3 for my home setup, replacing a Presonus 26x26. Presonus no longer supports the 26x26 and the old drivers do not work properly with the latest Mac OS.
What I noticed is that the headphone volume is pretty low. I have to crank them up all the way when using PT11. Does anyone have this box? Is that normal or am I gain staging this thing wrong. I mean, my levels from the mic pres are hot, the level in PT is hot, but the headphones seem like they can't keep up.
Anyone know of a mod or something? I mean, I can route a couple of outs to a headphone amp, but I just bought this box and really don't feel like adding on when the thing should work just fine in the first place!
I tried a couple of different cans, just in case of an ohm mismatch, but the Presonus had plenty of headphone juice. Doesn't make sense.
Post by Johnkenn on Jan 14, 2015 18:03:43 GMT -6
That was always my complaint with using interface headphone thingys. You could buy that cheap presonus headphone amp to jack up the volume...
Post by jcoutu1 on Jan 14, 2015 19:06:35 GMT -6
My question was going to be about what phones you're using, but you tried a bunch. If the HD280's don't have enough juice, that's a bad sign.
Post by Johnkenn on Jan 14, 2015 21:45:06 GMT -6
Even the Apollo didn't have enough juice for my tastes.
Post by ben on Jan 14, 2015 22:41:51 GMT -6
My question was going to be about what phones you're using, but you tried a bunch. If the HD280's don't have enough juice, that's a bad sign. Yes, those are my recording cans. Cranked all the way and barely enough.
Post by ericn on Jan 15, 2015 8:41:04 GMT -6
Honestly I have found this to be the case with almost every interface and console over the years I have found that a cheap modded Symetrix headphone Amp solves the problem. Every manufacturer I know has seen the headphone amp as a box that must be checked off and never heard of one where it was an important part of the design, it's always been easy to save a couple of bucks and use the cheapest approach .
Post by jcoutu1 on Jan 15, 2015 8:58:09 GMT -6
I've been researching headphone amps over the past couple of days and there are a few that seem to get a fair amount of praise for low money. They would probably drive your HD600 (I think you said you have) nicely too. Schiit - schiit.com/ - I have a friend that just bought the Vali. We're planning on listening to that amp vs. my cmoy style amp with a variety of phones fairly soon. Fiio - www.fiio.net/en/productsJDSlabs - www.jdslabs.com/store/#featured The O2 headphone amp is supposed to be good and the ODac is supposed to be comparable to the Benchmark. I haven't used any of these, but from the research that I've done, they seem to be at the top of the budget amps.
Post by ben on Jan 15, 2015 22:41:50 GMT -6
i think i have an old symetrix unit laying around somewhere. I can't believe more people are not complaining of the same problem. Oh well.
Post by wiz on Jan 16, 2015 16:04:12 GMT -6
I haI have a custom-made headphone amp Made by pro harmonic here in Australia. Cost a couple hundred bucks. But it's the best sounding thing to listen to with cans on... And really helped me with mic placement being a one guy show.
Cheers
