Post by mulmany on Jan 9, 2015 19:14:59 GMT -6
I Just completed the build. I know some of you have built this unit. Getting some odd readings for the voltages. I am getting +10v where I should be reading +30v and -30v where I should be reading -10v. It is very odd. Build Docs , Schematic if anyone cares to look. Thanks
Post by jeromemason on Jan 9, 2015 19:39:19 GMT -6
Is everything around and the lambda right? That's where I would start. I've got two of them to build soon myself. I never had any issues with my previous one though, fired up pretty much perfect.
Post by mulmany on Jan 9, 2015 20:55:27 GMT -6
Is everything around and the lambda right? That's where I would start. I've got two of them to build soon myself. I never had any issues with my previous one though, fired up pretty much perfect. I need to actually pull the board and go over in really well. It's a little funny that the voltages look like they are just swapped in polarity, the -10 is not even created on the converter board.
Post by tonycamphd on Jan 9, 2015 21:01:52 GMT -6
Is everything around and the lambda right? That's where I would start. I've got two of them to build soon myself. I never had any issues with my previous one though, fired up pretty much perfect. I need to actually pull the board and go over in really well. It's a little funny that the voltages look like they are just swapped in polarity, the -10 is not even created on the converter board. pictures please P
Post by jeromemason on Jan 9, 2015 23:56:07 GMT -6
Is everything around and the lambda right? That's where I would start. I've got two of them to build soon myself. I never had any issues with my previous one though, fired up pretty much perfect. I need to actually pull the board and go over in really well. It's a little funny that the voltages look like they are just swapped in polarity, the -10 is not even created on the converter board. Yeah, I think you've got something crossed, good news is there was no smoke and you actually saw voltages! So, you should be able to trace it down and I'm sure it's a simple fix. Pictures would be great, I remember that build pretty well.
Post by svart on Jan 9, 2015 23:59:47 GMT -6
You've got your 10V zener backwards I'd bet.
The ground is floating due to the switcher isolation, so a backwards 10V zener would limit your 30V to 10V and wouldn't limit your -30V up to 10V.
Pretty sure that's it.
Post by unit7 on Jan 10, 2015 1:52:01 GMT -6
mulmany Just a general tip when you need help w DoN's kits. He doesn't seem to care about replying at GDIY (or haven't got the thread subscription setup properly) but I've found him very helpful via email. And he knows his kits very well!
Post by mulmany on Jan 10, 2015 10:12:52 GMT -6
Thanks Boys, I pulled the DC/DC board and checked and checked my 10v Zener orientation all was as spec'ed. I am emailing Dave, then going to do a resistor check. I will let you know what I find.
Post by svart on Jan 10, 2015 10:24:10 GMT -6
Hmm. I would have bet money on that zener. It's just too suspect that your difference is exactly 20V, which is what the zener would waste during regulation.
Post by mulmany on Jan 10, 2015 19:55:17 GMT -6
Yeah I was hoping... looks like it is a ground issue, all the grounds are not reading continuity. I am not quite there with reading how they all tie together. Pin 1/Pin 5/Pin 13.
Post by mulmany on Jan 11, 2015 16:16:52 GMT -6
Ok... well this was a simple fix.
Put the unit in the 51x rack from CAPI!
So my old rack has a ground issue which is no surprise since I have had odd random issues with modules installed in it.
I thought it was because the chassis ground was broke... fixed it. Problem was still there. I guess I need to trouble shoot and fix my rack now.
Post by mulmany on Jan 11, 2015 19:07:58 GMT -6
Its alive! Calibration complete. Sounds Great! No issues at all with the build, it was all the rack. Thought I was going crazy!
