Post by Deleted on Dec 7, 2014 15:37:37 GMT -6
I've seen a lot of chatter about this but no real final answers.
Is anyone using a workaround that is functionable and if so, what is it? Thanks.
Post by Johnkenn on Dec 7, 2014 16:22:01 GMT -6
Nothing yet...I guess you could use that Blue Cat thingy. VCC is supposed to be done sometime in December.
Post by jcoutu1 on Dec 7, 2014 16:23:24 GMT -6
I've seen a lot of chatter about this but no real final answers. Is anyone using a workaround that is functionable and if so, what is it? Thanks. The update is supposed to be here this month. If he misses this deadline, people will lose their minds. Personally, at this point, I would just hold off for the new version.
Post by kcatthedog on Dec 7, 2014 18:34:25 GMT -6
I've goy the blue cat skin and vcc i'll check
With other slate plugs sonetimes they work but then you can't load session so pointless unless u r doing final mix and printing .
Post by Deleted on Dec 7, 2014 19:34:47 GMT -6
Thanks guys - I will hold out.
Post by Bob Olhsson on Dec 7, 2014 22:18:59 GMT -6
I actually stopped using VCC after starting to use VBC because I thought it sounded better even with no compression. These models are seasoning and I think it's easy to overdo it.
Post by popmann on Dec 8, 2014 20:12:21 GMT -6
I still use the busses. But, honestly...,on my own stuff? Since buying the Butl to track through, I rarely even use analog modeled anything....save the drums, which I don't track here...,which will change next time around, I think. I pulled up some old tracks I did with 4 mics on a kit and MUCH lesser gear....I think I'm gonna do it next time. I've already formulated how I'd make it go with the limited weird mismatch of overdub gear I have.
Post by joey808 on Dec 8, 2014 21:24:29 GMT -6
Blue Cat Patchwork, make sure you use the AU version.
Post by jcoutu1 on Dec 10, 2014 13:52:02 GMT -6
From Slate...
Post by Deleted on Dec 10, 2014 15:33:39 GMT -6
Yeah, jcoutu1, when I saw the first email today about VBC, I got excited but then saw what it truly was. My VBC works just fine. Love the Red.
Post by Johnkenn on Dec 10, 2014 16:25:25 GMT -6
