Post by jimwilliams on Nov 19, 2014 10:22:21 GMT -6
Turn the monitors down until they are off. Then bring them up until you barely hear the track. What then stands out? Then play "wack-a-mole" until the parts you want popping out first pop out first.
Or, use hardwired outboard and mix on an analog console, that usually does it for me.
Post by Martin John Butler on Nov 19, 2014 10:31:28 GMT -6
Thanks Jim. I do mix at different levels, often quite low, but I do like to check vocal levels at high volume too. Sometimes what seems OK at low volume, knocks your head off at high volume.
I did what you suggested, put my monitors at the lowest level possible, and was surprised that it was all sitting pretty damn good, with an honestly good balance overall. My only concern was when the vocal came in, was that it might not be forward or loud enough. I've tried to dial out some of the low frequency push, but this is the best I can do here. I'd love to run this all through a nice board, just to see.
What do you think?
Post by jcoutu1 on Nov 19, 2014 10:52:18 GMT -6
https%3A//soundcloud.com/martin-john-butler/somethings-coming-wideThanks to all of you here for taking some time to listen, and for your thoughtful suggestions. In this mix I did a few things to address the areas you guys made suggestions about. First, I put a vocal rider on the main vocal. That was Gannon from UAD's suggestion. I lowered the vocal .6 db, but tweaked the LA2 a little until it seemed to sit well. I increased bass by .8 DB and added a pinch more Waves Maxx Bass, which sort of widens it a little. Next, thanks to Tony, I placed the two 12 string electrics wider. Originally they were at 9:00 and 3:00, now they're at 7:00 and 5:00. The two acoustic guitars have stayed panned all the way left and right. Also, I tried to fatten the snare a little to fill up the middle as per Tony's suggestion. I played around with settings in the 2 bus a little, adding the FG-MU to the Slate VBC rack, which brightens everything nicely in this case, I put a little more Clariphonic on, dropped the A.O.M Limiter to 6.75 in gain, which gives around 2-3 db in compression, then I added 1.2 db Gain from Apple's Gain tool at the end of the 2 bus chain, for a high level for posting online. For real mastering, I'd run it without as much gain, then let the mastering take care of levels. The most effective change I think, was adding the FG-MU which helped a little to compensate for the loss of quality when bouncing. My main complaint is the difference I hear when comparing the Logic DAW mix and the bounce. The mix is great, the bounce, not so. The new "wider" mix is at the top of this post, below is the 2 bus signal chain screenshot. I'm still hearing this distortion on the vocal. I don't know if you blew stuff up while tracking or if it's blowing up in the mix, but it needs to be fixed IMO. If it blew up during tracking, you need to retrack. No two ways around it. The distortion ruins the track for me and I like your voice/the song.
Post by Martin John Butler on Nov 19, 2014 11:12:37 GMT -6
thanks jcoutou, I'll give it a listen flat, and see if I can figure out exactly what's happening.
I think it's a 50/50 thing, a combination of my proximity, and then mostly, all the compressors and gains in the mix. It's difficult sometimes choosing a vocal take. I did this just after a really nasty chest cold. I did another vocal that was actually much cleaner, but this one had the vibe I wanted.
I gave it a little thought, and I think I know where this issue begins. A while back, I ordered a John Hardy990+ opamp for my Warm Audio ToneBeast. Kcat had tried it, and I thought, since they're switchable, why not? Perhaps I might like it a little more than the stock opamp. It sounds warmer, but it had less gain, so it kind of forced me to use a lot of gain on the pre, and I think that might be where the grit begins, that, and my gritty "post" terrible cough and chest cold vocal cords.
The original opamp was a Jensen based 918, I believe. I also have the stock API style 731 opamp in the ToneBeast also, it's a different flavor, and I like it on guitars, but not so much for vocals. When I have some extra time, I may switch back. I have a friend who's coming in 2-3 weeks. He's a world class engineer, I'm hoping he has enough time to help me sort this out.
For jcoutou and friends, I ran a few seconds of the vocal with absolutely no plugs of any kind, none on the track, none on the 2 bus. If you turn it up, you'll hear a low frequency hum. That's the elevator engine shaft under my apartment.
https%3A//soundcloud.com/martin-john-butler/solo-vocal-empty-2-bus
Post by wiz on Nov 19, 2014 16:55:43 GMT -6
I find the distortion on the vocal distracting.
Personally, I think you might be mucking about with (over processing especially on the two buss) this mix a lot..I think trying to get a faux mastered level mix is a mistake.
Turn your monitors up, don't worry about competing with mastered versions of anything.
Get a great mix with bugger all on the two buss.
Then when thats sounding great...lets hear that version I would love to hear a LCR nothing on the 2 bus mix.
Then when you have that, spend a few bucks, get the song pro mastered.
Then when you get it back, listen and compare to your attempts, and then decide if all the time effort and money buying plug ins is worth the result you are getting, when the whole point of you putting that stuff of the 2 buss is to get competitive levels in the first place.
Its a great song btw.
Post by Randge on Nov 19, 2014 17:27:35 GMT -6
It sounds to me like some background noise is a bit of the culprit as well. It is enhanced by the multiple compression stages.
R
Post by Martin John Butler on Nov 19, 2014 18:35:32 GMT -6
Wiz, thanks for the helpful suggestions, I may very well try that soon.
Thanks for listening Range, you're probably right. Where I live, I'm on the ground floor, and there's a laundry room and the main elevator motor room directly below me, humming all day long. Outside my window is the area where the garbage gets placed and picked up, outside my front door is the mailroom of my building, where people come and go and bang mailboxes all day. My mic picks all of this up, and I can't really get into building recording booths and isolation, as it's a rental apartment.
It's a drag to work like this, but for now, I have to do my best with it.
Post by levon on Nov 20, 2014 2:08:09 GMT -6
Nice track Martin, love the guitars. I agree with what was said before, I would still set the vocals into the track a bit more and bring up the snare. Grain o'salt, as Tony said, as I love my drums loud and it may not be to everyone's taste. For the bass, I often use headphones to judge initial bass levels, that takes the room out of the equation, then later adjust it on speakers
Post by Martin John Butler on Nov 20, 2014 9:39:17 GMT -6
Thanks for listening Levon, I really do appreciate all the feedback and tips.
I've been using headphones a bit more lately as a reference, and you're right, there's something good about double checking the bass on them. The thing I like the most about headphones is they're great for checking the soundstage. Thanks to Tony's suggestion, I did bring up the bass and snare a bit recently, and I panned the 12 string guitars wider, opening up the middle even more for the vocal, and it does work better to me.
I need to step back for a day or two, try some of these interesting and helpful suggestions for mixing , and see where it goes. The noise on the main vocal track is being exaggerated by compression, so I'll see if I can at least get 50% of it gone.
Post by Martin John Butler on Nov 23, 2014 16:16:36 GMT -6
https%3A//soundcloud.com/martin-john-butler/somethings-coming-tc-mix
Tonycamphd kindly sent me a note with some step by step suggestions, and I follow his instructions to the letter. First I took everything off the 2 bus and balanced the mix with no plugs, other than one's that were used as effects like the UAD Dimension D on a guitar. I panned everything LCR as he suggested, gave the snare and kick a little tweak to come up a bit in the center, then put a little UAD Pultec on them, other than that, I put no EQ, really zero EQ on anything except subtractive in one or two spots, and then I added +2db at 5k on the API EQ on the background vocals only, and that's it.
Then I listened to the vocal with no plugs, I then turned on the plugs of the main vocal one at a time to see what they were doing. I kept what helped, dumped what didn't. I backed the main vocal reverb off a little (ReLab 480XL) and the channel strip is now API EQ > Renaissance Desser, (only a pinch, too much killed the thing, so I left a few obvious esses , then Waves Vocal Rider with a very small range, then the UAD LA2A ( I discovered this was culprit #1 of the gritty vocal in the previous mix), then a little Kush Clariphonic, ( this is to return some of the air in the overtones lost in bouncing, it sounded fine without it until listening to the bounce.)
I then went to the empty 2 bus, and added one plug at a time, and only blended in about 30-40% of the Slate VBC, then to the UAD Ampex ATR-102, and right there I found the true source of the distortion, and simply changed the levels, the UAD ATR-102 was set too high, I then added a just little Clariphonic for the same reason as the vocal, for the bounce, but now on the whole track, and ran a mix, saved it. The level was quite low, but the balance was great when I turned up the monitor volume.
Only then did I pop the AOM Limiter on the track and mess with it to get some level for fun and for posting.
I plan to have this properly mastered at some point, and the version without the last Limiter in the track is saved, and ready.
I compared the mix three times to previous mixes, ran bounces, and erased them 3 times more until it sounded right. I chose to leave the vocal a little hot, adding the smallest amount more I could of the UAD ATR-102 because I was keeping in mind a quote from Jimmy Iovine who said something to the effect that the best vocalist is the one you believe, and for some reason, set this way, a little hot, I believed the vocal. Now, I feel like I have a RECORD, not a demo, and it's only because all of you took the time to write such great comments that I think I found my way there.
My friend Jay Messina, ( the real deal engineer) will probably stop by my place sometime in the next few weeks, and I'll see what he thinks of it all, and let you know.
Thanks so much guys, you've made an important difference to something that means the world to me. I hope I can return the favor some day.
I named this the TC mix in honor of Tony !
Post by formatcyes on Nov 23, 2014 16:28:15 GMT -6
Sounds fantastic. Seriously great work. No Mix is perfect unless its a Shipley mix . I cannot hear anything wrong with this one. Waiting for your next song..
Post by Martin John Butler on Nov 23, 2014 16:40:55 GMT -6
Thanks so much formatcyes. I seriously appreciate the cats here taking the time to have a listen. I'm doing this all in my noisy living room by myself.
Post by wiz on Nov 23, 2014 18:13:27 GMT -6
Now THATS a mix I want to listen to.
nice work, really nice work.
Post by Martin John Butler on Nov 23, 2014 18:20:50 GMT -6
That means a lot to me wiz, really. Thanks.
Post by tonycamphd on Nov 23, 2014 21:56:22 GMT -6
really nice job Martin! glad to be of some help bud 8)
Post by Martin John Butler on Nov 23, 2014 22:17:38 GMT -6
Sometimes when someone takes care to point you in the right direction it makes all the difference, thanks Tony. I'll be trying the" TC Method" of mixing every chance I get now.
Post by levon on Nov 24, 2014 1:05:49 GMT -6
Sounds great, Martin, very nice soundscape. Those guitars sound great, is that a Rickenbacker? The vox is still a bit too hot for my taste, but that's just me. Well done.
Post by M57 on Nov 24, 2014 5:57:12 GMT -6
Agree with all. It sounds great. The vocal may be a tad too hot, but that is truly splitting hairs. Nothing on the stage is being stepped on or getting short-changed.
Post by matt on Nov 24, 2014 7:28:44 GMT -6
Martin, excellent work! Your latest mix sounds very good; however, I do agree with levon and m57 that the vocal is just a bit too hot - perhaps hotter than intended. Should be easy to fix, if you decide to revisit.
Post by Martin John Butler on Nov 24, 2014 7:37:59 GMT -6
Thanks guys. I was on the fence with the vocal level. One small click in one direction and it sat perfectly, but it didn't grab me, one click the other way, and it was a little hot. I'm going to let it sit for a few days or so, and then see with fresh ears if I want to tweak a little, but I'm happy where it is now, so it shouldn't be too difficult. My monitoring situation's not great, so it's a little more frustrating to mix here than it usually is.
That's the George Harrison model Gretsch Country Gentleman 12 string Levon. My friend loaned it to me, and it's expensive, ( like, $2,500.) but it's the sweetest 12 string I've ever seen. I liked it much more than a Rickenbacker.
Post by jcoutu1 on Nov 24, 2014 9:05:18 GMT -6
Yep. Nice stuff man. Guitars sound killer.
Post by Martin John Butler on Nov 24, 2014 9:24:34 GMT -6
Thanks jcoutou, lending your ears is much appreciated..
I had borrowed my friends Neumann K84, and discovered I love it in front of my guitar cabinets. If only I could keep it :-(
Post by Martin John Butler on Dec 3, 2014 13:31:04 GMT -6
OK folks, first, thanks for being so gracious when helping me figure out where the mix stood.
I just ran all my mixes onto a CD, played seven songs on my main system, put simply, my main system is really well chosen and sounds great. Well, ALL the vocals were too hot, and a little thin. You guys were right. In my corner where I mix, the sound just isn't right, and this is what it led to. I will begin running every mix again, lowering the lead vocal a little and hopefully, have a decent demo soon.
No wonder people hire good mixing engineers, this is difficult and time consuming. The rest sounds pretty good though, so I'll bump the bass up a touch while lowering vocals and hope I land somewhere I can I can actually enjoy listening to.
Post by matt on Dec 3, 2014 14:53:05 GMT -6
so I'll bump the bass up a touch while lowering vocals and hope I land somewhere I can I can actually enjoy listening to. Martin, based on my personal (in)experience, you might want to lower the vox and then bump the bass as separate actions. I have been guilty of changing multiple things in a single pass, only to wonder which "thing" improved (or degraded) the mix.
Post by tonycamphd on Dec 3, 2014 16:13:43 GMT -6
OK folks, first, thanks for being so gracious when helping me figure out where the mix stood. I just ran all my mixes onto a CD, played seven songs on my main system, put simply, my main system is really well chosen and sounds great. Well, ALL the vocals were too hot, and a little thin. You guys were right. In my corner where I mix, the sound just isn't right, and this is what it led to. I will begin running every mix again, lowering the lead vocal a little and hopefully, have a decent demo soon. No wonder people hire good mixing engineers, this is difficult and time consuming. The rest sounds pretty good though, so I'll bump the bass up a touch while lowering vocals and hope I land somewhere I can I can actually enjoy listening to. this is why the room is so friggin critical, it's totally confidence inspiring when you're mixing and you know what you're getting is actually what you're getting(i am not there yet either bud, so don't feel bad, i'd bet most of us are dealing with this to a large degree?), a couple acoustic treatments in that corner and on the wall behind you monitors goes a long way man. In the meantime, turn you monitors way down to take the room out of the mix, and listen to some of your favorite music at that volume, then go to your mix and touch it up at that volume. i hope this helps T
