Post by swurveman on Nov 11, 2014 13:46:25 GMT -6
Hi guys,
One of my AKGC414 XLS mics is having a problem with volume when in the Cardiod Polar Pattern. It works in Omni and Figure 8, but when I switch it to Cardiod it works initially, but then the volume disappears. Has anybody had this problem? If so, I sure could use some advice on if its possible to fix the problem.
Thanks in advance to anybody who can help!
Post by Ward on Nov 11, 2014 14:20:05 GMT -6
Best advice: If it's out of warranty, get in touch with Shannon at Mic-rehab. @sinsay is here to serve, for a price!
If it's still under warranty, it's up to Harman/AKG to fix in association with the dealer you purchased it from.
Post by swurveman on Nov 11, 2014 14:36:44 GMT -6
Best advice: If it's out of warranty, get in touch with Shannon at Mic-rehab. @sinsay is here to serve, for a price! If it's still under warranty, it's up to Harman/AKG to fix in association with the dealer you purchased it from. Thanks Ward. It's out of warranty. I called Harmon. I'll see if they have an easy fix. If not, I'll check out Shannon.
