Post by tonycamphd on Oct 24, 2014 10:59:26 GMT -6
What strings do you guys prefer as far as tracking/mixing electric bass guitar goes, i've had the same medium roto's on my 72 Jbass for about,...hmmm 5 years 8), love the tone, if i need some more middle to cut, i just drive a pre stage harder and get it that way, or finger over the bridge/rear pickup style, or use a pick... or...
open to anything, love to hear suggs
Post by mdmitch2 on Oct 24, 2014 11:22:24 GMT -6
I bought my bass (carvin SB4000) from an ebay pawn shop about 3 yrs ago and it still has the same strings on it, and sounds great.... no idea what they are though.
My old bass player liked Elixirs for his Ibanez 5 string.
Post by Johnkenn on Oct 24, 2014 11:24:01 GMT -6
Flatwounds any brand...
Post by matt on Oct 24, 2014 11:25:05 GMT -6
We have moved to flatwounds to reduce string noise when going DI. Can't remember the brand just now. My bassist likes them, and they seem to have an even tonality up/down and across the fretboard on his G&L ASAT. He does not use a pick. But, FW strings are not for everybody, so YMMV.
Post by levon on Oct 24, 2014 11:30:20 GMT -6
If it sounds good and you like it, don't change them. Trust your ears.
Post by Ward on Oct 24, 2014 13:07:09 GMT -6
Ground-wounds a.k.a. Half-rounds.
Post by jeromemason on Oct 24, 2014 13:08:41 GMT -6
Post by Guitar on Oct 24, 2014 19:21:13 GMT -6
Can't go wrong with D'Addario. But I can't go wrong because I've never tried any other brand! They sound good though, I like the clarity.
On guitars I have started going heavy on the Dean Markley brand's various lines of strings. Can't help but think they'd make good bass strings, too.
Post by tonycamphd on Oct 24, 2014 19:24:32 GMT -6
what about gauges fella's? any preference for light or heavy relating to styles of music?
Post by Guitar on Oct 24, 2014 20:09:50 GMT -6
only as heavy as I can comfortably play, is my basic rule, but no lighter
Post by winetree on Oct 24, 2014 20:45:17 GMT -6
Just bought A set of D'Addario EXL 170. 45-65-80-100. I use them on my 2 - Peavey T-40s, 1968 P- bass, Fender Jazz Bass. Rotos on the 1975 Rickenbacker 4001 Flat wounds on the Hofner. Trying to decide on the Alembic.
Post by mobeach on Oct 24, 2014 21:35:23 GMT -6
Rotosound RS-66 for everything. You are what you are.
Post by Deleted on Oct 24, 2014 23:12:02 GMT -6
RS66LD Rotosound was the only set i used for more than 10 yrs. on stage and for everything. Got the most out of them, and no other set did the same. I don't care about fret noise, though, rock set. If you don't like fret noise for expression at all, you probably go flatwound. Liked flatwounds on a 63 jazz bass i had the opportunity to play for a while, and surely would play flatwounds on a Höfner. Since i use a Bogart bass, it has a very open sound - fret noise is clearly audible - this bass has an incredible low end and with plectrum click and fret noise it works around all guitars easily. Always found the rotosound to be perfect and has a soft feel to allow more expression than other sets that feel like hard wire without flexibility. When i played them excessively every day, i replaced them every 2 weeks...old strings do lose alot of sound and magic, i could never understand how people could like old strings... Nowadays i play around with other sets, but 'til now, none of them could compete... Some lighter sets work better for modern funk slap'n'pop or similar, on certain basses. I like them on my old crispy Ibanez Roadstar II, which has something to it i really like nowadays...in the 80's i thought, it sucks, but it doesn't really...
Post by mobeach on Oct 25, 2014 7:31:35 GMT -6
I love Roto's throw in some extra bottom and those strings give you unbelievable punch and clarity. I've tried all the others and always go back to Rotosound.
Post by jimwilliams on Oct 25, 2014 10:02:23 GMT -6
Nickle wrap round wounds. D'Addario are good, but expensive. Rotosounds are steel wrap and have a bit too much midrange for me and they wear out nickle frets.
I switched to 105 gauge E string no name nickle wraps from Allparts for $5 per set wholesale. Sounds great, less filling.
