Post by Deleted on Sept 13, 2013 19:33:21 GMT -6
is anyone gonna comment on the input impedance of each device? Impedance does affect the sound...
Post by tonycamphd on Sept 13, 2013 19:42:34 GMT -6
is anyone gonna comment on the input impedance of each device? Impedance does affect the sound... I noticed on the a/b/c clips, that the burl had a slightly louder db level, i'm curious to know as well, i think it has transformers?, i wonder what ratio those are also?
Post by Mark Kano on Sept 15, 2013 6:34:37 GMT -6
Ahh, I guess I would still need an actual interface to use the burl.. Would love to hear the box without the transformer mojo, just to have a clearer idea of how the converters stand on their own. Or just get a Symphony and be done with it... True... I'm on an imac though so I guess I'd either have to use usb or spring for the thunderbolt option. More $$. Did you do the Symphony - Apollo - back to Symphony dance?
Post by Deleted on Sept 15, 2013 6:55:08 GMT -6
I use the symphony and an iMac. if you don't need more than 16 channels of I/O, USB works fine!
Post by Mark Kano on Sept 15, 2013 7:08:56 GMT -6
I've personally never needed more than 2 channels of i/o! Most of these interfaces are way overkill for me, like owning a 4000 sq ft home and mostly hanging in the kitchen:) Good to know though.. thanks
Post by popmann on Sept 15, 2013 14:31:11 GMT -6
That's all gear does. I think the misunderstand of that leads to the Babel'esque discussions on the net. People seem to think that gear makes things sound better. When in reality, a recording of something is inherently a lossy process. We use tools and techniques honed over half a century to make the perception less lossy. Measuring it, they tend to to make it EVEN lossier, these tools of perception.
And the distinction never used to matter....because the gear was made by and for audio engineers. Now, with musicians, and many utterly unskilled/untrained in the engineering side, they want "truth". But, they don't get that measured accuracy does not equate "truth" in perception.
I recently looked back at my last round of mixes (of my own stuff--ie, that I tracked)...and the number one plug in category used was distortion (VCC/VTM/MPX/Saturn). Number two was Linear Phase HPFs. Excluding those, I could count on one hand the number of compressors and EQs used. So, it makes sense to bring some saturation into the tracking process.
Post by popmann on Sept 18, 2013 17:28:02 GMT -6
So, FYI...I finally downloaded these. The Apollo is missing. But, of the two still up, doing nothing, the Burl is the no brainer. I reduced it's gain by .75db. The RMS was 1db higher and peaks were .5 higher....so, I just met the two in the middle. So some thoughts....FWIW.
Anyone who wants to hear some rather nasty saturation just needs to flip the phase and go to the peak the loudest "MY" about 2/3rds of the way through. The Burl sizzles and crackles on that word where the symphony's clean.
Now...as soon as I heard the difference in low end girth, though, I immediately reached into my digital toolbox and grabbed two Neve input channel emulations. I would venture it would be tough for anyone to tell me the difference in several different options I've used in the past to increase the low end girth (different from amount, which is a simple EQ tweak)...Point being for MJB, or anyone who can't afford a Burl, and wants the "second best" of that sound....is not a different converter without a class A line amp. It's a digital model of a ClassA line amp.
But, of course--that's exactly what Cowboy meant when he said he din't have to slather on so much stuff. Or at least that's how I interpreted and responded above--most gear is a workflow enhancement. It's more forgiving. It gets us from A to B quicker. But, getting to B isn't the exclusively available via of more and better boutique gear.
I'm actually pretty surprised at how you had to get to -1dbfs to get that to crunch up. Not that vocals are transient heavy stuff...but, it does make me wonder if it will really have a significant cumulative tracking effect. Since it basically reduced the dynamic range by like .5db recording at nearly fullscale. That certainly doesn't deserve the reputation for saturating and clipping waveforms.
I am looking forward to my coming personal shootout. Mine won't include a Symphony, though. API A2D and the B2. Two DIFFERENT class A line amps+conversion. One just happens to have some mic pres that kick ass on amps...the API offering the choice to hit the transformers or go straight to the ADC. I'll be sure to post some clips. I thank Cowboy for posting these.
Post by Martin John Butler on Sept 18, 2013 17:48:05 GMT -6
Thanks popman. I have almost every Waves plug-in known to man, (a gift from a friend when I was first getting started), and some UAD plugs ATR-102, Massive Passive, EMT-140, Dimension D, LA2's 1176's, Fatso, and a few other brands.. Is there a particular digital model of a Class A amp you can recommend that might move me a little closer to the Burl sound?
Post by popmann on Sept 18, 2013 19:32:09 GMT -6
Waves NLS Neve. Drive it half way, then pull the output down 2DB.
I don't like the product. It's actually laughable as a whole...but, there's some magic in the Neve CHANNEL...for vocals with digitilitus. Try different channels. Slate's Neve works, and sometimes does better, but you HAVE to follow it with a linear phase HPF. It creates such sub 70hz garbage. I rarely use it for that reason. If you don't own the NLS, don't buy it for that unless it's silly cheap...that one channel I've found that ONE use for.
Is there a particular type of track you'r lacking details on? Running at double sample rate?
Post by Deleted on Sept 18, 2013 20:34:25 GMT -6
soooo, Symphony output into outboard Neve preamps back into Symphony inputs = Burl? *scratches head*
Post by popmann on Sept 19, 2013 12:48:44 GMT -6
Well, you would need a line amp...with two stages...but, what's the head scratching part? MJB....want more proof a new chip isn't the answer? The Burl is the same AD chip as in the Digi192s from the year 2001. MOTU's HD192s from the year after. Some EMU and Metric Halo interfaces after that. So if you DO believe in the chip being the determination of conversion quality, Burl is using vintage digital technology, too!
Post by Johnkenn on Sept 19, 2013 13:08:05 GMT -6
Yes, I did the dance twice. I was hoping to save a little money, but just ultimately felt like the Symphony fit my needs better.
Post by tonycamphd on Sept 19, 2013 13:17:11 GMT -6
Well, you would need a line amp...with two stages...but, what's the head scratching part? Vp28= 2 stage line amp? In conjunction with "not burl" conversion, comes close? and it seems like a cheaper alternative w/more options than the burl, no? I think what chucks saying is you get a symphony and a burl(with a 2 stage line amp) instead of alternatively just a burl? unless I'm not understanding, which is probable lol! T
Post by Martin John Butler on Sept 19, 2013 17:15:15 GMT -6
Grat info popman, thanks. it's really interesting to know how crucial the implementation of the A/D is, and that it's more responsible for the sound quality than the conversion chip itself. Unfortunately, I don't have the Waves NLS Neve, or I'd give it a try. I do have quite a few Waves plugs, though I haven't really learned them all, I mainly use the SSL EQ. I find the presets packages useless.
Post by popmann on Sept 19, 2013 19:16:13 GMT -6
I tried MPX and VEQ for you this evening. The VEQ was closest--I just used FreeG to pump 10db in front of it and another instance to pull 10db off on the other side.
Forget MPX. One trick pony....magic on a snare drum.
You could give that a shot. It's not quite the NLS or VCC+HPF....but, if you own it, give it a shot.
If you don't mind my asking, though...you've made reference to using mostly virtual instruments, no? What about amps? I guess....long way around to asking what are you actually converting from analog into digital that you're unhappy with? I really do think this stuff is all pretty nuanced compared to other factors.
Post by popmann on Sept 19, 2013 19:46:15 GMT -6
Well, you would need a line amp...with two stages...but, what's the head scratching part? Vp28= 2 stage line amp? In conjunction with "not burl" conversion, comes close? and it seems like a cheaper alternative w/more options than the burl, no? I think what chucks saying is you get a symphony and a burl(with a 2 stage line amp) instead of alternatively just a burl? unless I'm not understanding, which is probable lol! T I would indeed that was his assertion. But, if you're gonna "reamp", just use a digital plug in. Or get an analog compressor with a particularly nice transformer sound--so that you're getting something other than subtle line amp "color". This is the stuff of subtlety. And since recording tools, to me--get you where you're going faster and easier....building it into the converter makes more sense to me. The point is it's converted to digital as intended. Mic?Preamp>EQ or comp if needed>ADC. I really am trying my best to move more and more IN the box. I'm not there yet...but, that is my goal. Make the recording/mix platform as irrelevant as possible.
Post by Mark Kano on Sept 19, 2013 20:48:03 GMT -6
Thanks popman. I have almost every Waves plug-in known to man, (a gift from a friend when I was first getting started), and some UAD plugs ATR-102, Massive Passive, EMT-140, Dimension D, LA2's 1176's, Fatso, and a few other brands.. Is there a particular digital model of a Class A amp you can recommend that might move me a little closer to the Burl sound? That is one heck of a friend!! From your Waves list I think the r-deesser is great and the bass amps in the GTR plug are highly useable in my opinion. Also the Maserati guitar plug has some clean settings that do something I haven't been able to achieve on my own. Kramer tape, while not being the greatest tape emulation, has a pretty cool slap delay that works for some vox and acoustics. Puigchild is smooth too.
Post by Deleted on Sept 19, 2013 21:18:52 GMT -6
lol that friend is called "a torrent site". The mercury v9 bundle has been out for years already.
Post by Martin John Butler on Sept 19, 2013 22:06:56 GMT -6
Hey Mark, I had no idea of the cost of plugins when I began recording at home again, around 15 months ago. In fact, I barely understood what a plug in was. It was a return of a favor from a wealthy friend, who's since passed away.
I do use the D-Esser which does work well. I used the CLA bass plug for a while and it wasn't bad, but the IK Multimedia Ampeg bass amp plug went on sale for $39, and it just killed any of the Waves bass rigs. The Ik Ampeg sounds exactly like the Ampeg bass I have, plus it has a few other models, without the noise/hum. I still use the amp 9 out of 10 times. but once in a while it serves the track better to have it be silent, with no amp hiss, so I use just the plug. Sometimes I record with the BA-12, the use the Ampeg BA500 plug to beef things up a little.
I actually like working in the box. I find the flexibility makes me become more creative. I can switch plates on myb EMT-140 reverb in seconds, or recalibrate a tape machine by simply clicking on presets, I can get much more variety of sounds by using multiple instantiations, or printing with UAD plugs. Popman, I do track electric guitars and bass with amps now, and use my Blackspade mic into for acoustic guitar, slide, harmonium, etc. , all into the Warm Audio ToneBeast.
What I like about the Burl mixes I've heard is the higher resolution of low level detail, and the smoother, wider, punchier bottom. If I can get those two things with a BLA Microclock or the BLA Apollo mod, that would be great. If it could be gotten with the the BLA Sparrow, cool, or the UAD 2192, OK, at least I'd know where to set my sights. And if not, a Burl later on down the road. That's about all I need to feel complete here, other than a new computer, things like more mics would be gravy.
I won't be buying much for a while, so I'll have time to figure out which one is my best move.
I used to write and produce music for radio and TV commercials. I did big budget spots in high end studios, and smaller budget things at home. I had a minimalist system at home, and I still like working that way. I had a Tascam 8 tk, Otari 2 tk. an Allen & Heath board, a Lexicon reverb. Lexicon delay, DBX 166X, a Neumann U87 mic, a drum machine and an Emu Emulator, a Kurzweil keyboard, and that was it. I produced at least 100 local commercials there. So, like popman, being mostly in the box is fine with me, especially with Slate's VBC, which gets me a little of the Burl tone I like.
Post by popmann on Sept 20, 2013 0:21:20 GMT -6
I just keep hearing you say the Burl "mixes" you've heard. I've never heard any entire projects cut with Burl and mixed. I've heard the output of an analog mixer captured by the Burl...I've heard individual tracks cut with the Burl...you seem like the type to do more research on gear than me, but...some of the mix comparisons have more variables than the converter that captures the mixes. Have you heard a digital mix done and sent out and back in through the Burl?
Whatever you do...you can improve the sound you're getting with what you have right now. Always. Keep working.
Post by Martin John Butler on Sept 20, 2013 8:07:07 GMT -6
Will keep that in mind popmann, thanks.
I feel quite close to a good sound now. I'll have to try jumping over one barrier I've imposed on myself. I prefer to just faux master on mixdown, as most tracks are of demo status now. Two tracks I've worked on will be released though, so I'll go the extra mile and try to bounce, and then do a new mastering track, as I don't have enough dsp power to use my Massive Passive plug, and it might be something that helps, I don't know yet. If mixing goes really well, I may forego the last step and send it out to be mastered, if I find I can afford it when it's ready.
Post by Johnkenn on Sept 20, 2013 11:13:22 GMT -6
Let's...ahem...leave cracks out of the conversation.
Post by Mark Kano on Sept 20, 2013 14:39:30 GMT -6
lol that friend is called "a torrent site". The mercury v9 bundle has been out for years already. Ha! Unfortunately... or fortunately I know that friend too. This thread has suddenly become incriminating Martin John Butler I think I have the Ampeg plug, will try that out. I like how easy it is to audition different bass amp sounds and eq curves within GTR though, I'm sure Amplitube nailed it, but I cant seem to get into their gtr emulations very much. I too tried my hand at the commercial world but it was too much hustle and not enough landing spots for me. I hate situations where I feel like the odds are akin to winning the lottery. Still, I was actually forced to mix my own stuff for the first time so I think it was a great learning experience. It's amazing what you can crank out in a day under pressure!
Post by Martin John Butler on Sept 20, 2013 20:18:28 GMT -6
Guitar sims are tricky. The Amplitude bass plug is the deal though. I use Apple's guitar sims, they sound as good as any, and their pedals are well done, and there's plenty of them. Maybe the Scuffham's a touch better, but with the ability to change amps, cabinet's, mics, the plugs do what you need. Apple's Fenders are surprisingly good.
Post by Johnkenn on Jul 25, 2014 18:07:01 GMT -6
I don't think I ever got a chance to hear this...gonna go listen!
