Post by wiz on Oct 1, 2014 5:23:05 GMT -6
Anyone used one?
Thoughts?
Cheers
wiz
Post by Guitar on Oct 2, 2014 21:23:45 GMT -6
I'm interested, too. The problem is they seem limited in range, only 19" rackmount type styles available it looks like, up to 16 channels or so. The ZED range covers a lot more sizes.
Post by ericn on Oct 2, 2014 21:46:19 GMT -6
Mix wiz have always been a nice little rack mount board, but if I were in the market for a rack mount board I would spend a bit more on a Crest Xrack or APB !
Post by wiz on Oct 2, 2014 23:23:20 GMT -6
its part of a larger discussion I wanted to have about specs, and gear.
The specs on that thing, are pretty impressive....
How do we go about equating, specs and sound though... thats the tough question.
Not picking on him, but I have often seen Jim Williams talk about the quietness of a modified sound craft delta, well not quietness on its own, but how clean and good it is.
How is something like this mix wizard better or worse?
How is this vs the X desk from SSL , with regards to specs , worse.... how do we equate that worseness or betterillygoodness ......
I often see people, maybe they know, maybe they don't, quoting older consoles being great, say Delta, and newer consoles, say Toft, being crap.
How do we sort the wheat from the chaff?
Post by wiz on Oct 2, 2014 23:24:57 GMT -6
I would really love, someone who knows, say explain why say THIS console the mix wizard 4, is not as good as the X desk, on sonics alone, not functionality
Please don't read that as negative, I would really love to learn what separates them,and I am sitting here wide eyed and bushy tailed in anticipation 8)
Post by wiz on Oct 2, 2014 23:40:47 GMT -6
I thought I would try and make my question clearer, by talking and not typing....
I don't think I was that successful
8)
Post by tonycamphd on Oct 3, 2014 2:13:46 GMT -6
hey... great to see you Wiz! I'm not sure what the mixwizard does(it does have wiz in the name though 8), but i think the whole thing comes down to being in the voltage domain, ITB suffers from a virtual disconnect imo, i can't explain why at all, it just never really seems to come together for me. I have the delta as you know, and its pretty incredible sounding, the cross talk spec as you mentioned, is non existent at 92db @10k with the JW mods, so i think you could count that out, but it's got that "thing" we seem to love in spades... so? sorry i cant help you on your Q, i'll be looking forward to some good responses.
can you point me to that SSL summing vid you were referring to?
btw, cool accent, and absolutely no problem understanding you at all bromee 8)
Post by jcoutu1 on Oct 3, 2014 5:11:17 GMT -6
wiz, interesting thoughts. I have a WZ3 that I use for my live gig that I've been happy with. I've tried some quick tracking through the pres and have had better results through my external pres. Now sure how the 3 compares to the 4 though. I also probably wouldn't be using all desk pres unless I was on a Neve, API, or Wunderbar, so there's that. I also prefer having busses for the studio (live too really). I imagine that the WZ4 would be a sonically capable desk for a small rig though.
Post by wiz on Oct 3, 2014 8:33:19 GMT -6
Post by Guitar on Oct 3, 2014 8:58:17 GMT -6
I hope some real hardcore cats will answer. All I can say is great records that I have in my collection have been made on Mackie mixers, others on SSL, others on a computer with no mixing console at all, and I enjoy them as music all the same.
I think the answer might come down to design philosophy and sophistication. You can think of an electrical engineering design team like a reastaurant or a chef. SSL is a top chef with a fancy restaurant. They make good highly original "food," and it's expensive. They get mentioned in the same breath as Mr. Rupert Neve, for gosh sake.
If you look at two compressors that use the same THAT vca, one a DBX, and the other one an SSL, they provide the same function, both are built pretty solidly, but the price, and sound, is vastly different. If you were to trace the circuit, I think you would find that the SSL is a much more sophisticated, that is complicated, design. Specifically I think SSL made some technical advancement in compressor technology when they designed their bus compressor, I can't remember the details. But that takes a lot of work and sharp minds. I think you would also find at the component level that the SSL and similar units will have more expensive components in some cases, like capacitors and audio op amps. And the power supply might be quieter or more powerful or something like that, which you won't see on any spec sheet. Again, a design decision. Specifications do not even nearly tell the whole story.
I think the story is very much the same in the mixer world. If you pick apart an Allen and Heath (I've done it) you'll find cheap bottom of the barrel capacitors, cheap faders, bog standard op amps and transistors, and just a generally inexpensive internal construction. Frankly, it's ugly to look at. I would think the inside of an SSL would look quite a bit different. Very specifically, you can buy the Allen and Heath fader by itself for about $10. But a professional grade fader like a Penny and Giles or something you'll find on some of the LFACs is closer to $100, and it will be much more robust, physically much larger, and built with long term service in mind. You can take them apart and service them, unlike the cheap fader in the A&H desk. Now just imagine scaling this price difference across 16 or 32 channels or whatever and you can see how the total cost (and quality) will skyrocket. The same is true for op amps or any component. The Allen and Heath is made to a price point, which means lower-cost components, both mechanical, and in the audio path. The SSL is made with an allowance for more high grade parts, a no-compromise design, and that is reflected in the cost. Their gear is more consummately professional.
Regarding sound quality, this is highly subjective. I think a lot of people would agree that higher quality components allow for better sound quality. I know I prefer more expensive capacitors to cheaper ones, generally speaking, for example. And this is partly why Behringer gear sounds worse than what it's directly copied from. But also, the circuit itself determines the quality of sound, probably even more than component choice. Just look at the legacy of the API 312 schematic. Input transformer, discrete op amp, output transformer, to put it basically. This became a starting point for many future successful preamps. The SSL G bus compressor schematic was so brilliant, there are now a dozen knock offs on the market. It's the same story with the Tube Screamer, the Moog ladder filter, and the Fender guitar. Some designs are just blindingly brilliant. I bet the SSL console's mix bus and EQ count too.
I think the essence of what you're asking about comes down to actual circuit design and quality standards. Critical listening is a huge part of audio design, also. I'm curious to hear what other people have to say. I am not an expert, but I have designed a few pieces of gear. This is just my humble .02 cents.
Post by jcoutu1 on Oct 3, 2014 8:59:50 GMT -6
I thought I would try and make my question clearer, by talking and not typing.... I don't think I was that successful 8) Seriously, great accent, great questions.
Post by tonycamphd on Oct 3, 2014 9:17:09 GMT -6
^ great! thanx Wiz, this is exactly accurate to my experiences, the width, the focus and density is sooo much better! I always get a fly away/disconnected feeling that i'm listening through a very light loose cotton diffusor when ITB mixes are played.
The rig i'm building= I'm pulling every individual channel OTB 32x8x2, i'll be using pro q2 in linear phase mode for filtering duties and heavy lifts(yes, an instantiation on every channel for DC), then it's OTB all the way, including real reverb plates 8) I will be using my hardware comps and such at insert points, and automate the analog faders so volume changes are also in the voltage domain(i have a DIY automation system i "designed" thats going to blow your mind, but not for the reasons you might think, remember, i'm an idiot 8), i'll show you before too long)
it's a ton of work/$, but it'll be worth it in the end... please God lol
Post by wiz on Oct 4, 2014 17:14:51 GMT -6
^ great! thanx Wiz, this is exactly accurate to my experiences, the width, the focus and density is sooo much better! I always get a fly away/disconnected feeling that i'm listening through a very light loose cotton diffusor when ITB mixes are played. The rig i'm building= I'm pulling every individual channel OTB 32x8x2, i'll be using pro q2 in linear phase mode for filtering duties and heavy lifts(yes, an instantiation on every channel for DC), then it's OTB all the way, including real reverb plates 8) I will be using my hardware comps and such at insert points, and automate the analog faders so volume changes are also in the voltage domain(i have a DIY automation system i "designed" thats going to blow your mind, but not for the reasons you might think, remember, i'm an idiot 8), i'll show you before too long) it's a ton of work/$, but it'll be worth it in the end... please God lol Often, I find that some piece of gear will come along, and there will be testing put up online, you know, $1000 mic pre vs $50 mic pre... ITB vs Summingator 9000 and you listen and either the testing is obviously flawed, or even if done well, then sometimes there is really small incremental differences... and the dollar to change ration is not great. This is the first of these tests (the ssl video I linked above) that I heard the OTB as being CLEARLY better and the testing didn't seem flawed, as far as I could tell. Even on a youtube video, it really is (in comparison to all others I have heard) night and day. Usually improvements I have heard, are marginal at best, perhaps a little wider here, a little wider there.... bit of coloration ... I often wondered if passing the two track mix through some of these devices, and utilising just two channels of the summing device, would yield almost identical results in some of those boxes in particular things like the NEVE summing mixer.... or others that have transformers and purpose built "sound" in them. Often you also hear, "oh you really have to split out more than 8 tracks to do this, you would get the benefit unless you have 45 to the power of 9 outputs going...." Well, that SSL Video with just 8 has the most positive impact I have heard on a mix, short of mastering. Lets assume , its real. SSL didn't do any shenanigans. for 3 grand, I am in. But I am curious, why aren't these things every #^&^#ing where? ? People salivate over the difference between converters... I have heard less tangible difference between a ADA8000 and RME converter than just 8 channels of SSL summing in that video. I would have loved to have heard just the two track going through the SSL, so I could see how much the basic super analogue design thingy, was contributing. Hence why I ended up wondering about specs. I wish I could demo one of these things. Anyone here got one? Anyone able to run a pass of a song of mine out as 8 outputs into a X desk? If that video is real, and its the X desk that is doing the heavy lifting in the improvements there, and its not the convertors used... Its got to be the best thing since sliced bread.... doenst it.?
Post by Guitar on Oct 4, 2014 18:18:14 GMT -6
I think you have just had the Analog Summing Experience. I had the same one a few months ago. For me, there's no reason to turn back. I can hear it, too, and it's good.
If you want to know how popular this sound and equipment really is, just look at the 2 dozen or more analog summing boxes for sale on the big gear sites from almost every major and some minor companies. And after that, start looking at all the people that are still mixing on an analog desk, or just summing on the desk (yes people do that too), and analog summing sound is a big part of why that's still popular also, it's about the sound. The workflow is obviously different as well.
You know what though, the X-Desk has got my attention also, and I kind of want to save up for one, because I like the SSL sound so much, and it's ahead of a lot of simple summing mixers with its true mixing board capabilities such as 8 faders, aux sends, and a control room section, talkback, etc. It looks really appealing. The thread on gearslutz is 30 pages long or something, I think these actually are decently popular. I know some pros are using them too, like Luca Pretolesi.
Once you find out how simple it is to get true high end sound out of a hybrid rig, assuming your skills are adequate, well, that feels like a happy day for me. I think it is dawning on a lot of people right now, sort of a subtle revolution, after so much in the box stuff going on for a lot of us. Obviously you need outboard to get the 100% sound, but, going 50% is still really good too if you ask me. I'm not a big digital audio fan. I think the future of sound quality is looking really good right now, even on a moderate budget, and that's exciting. It's almost like the Abbey Road paradigm is almost completely melted down, and almost (almost!) we're all, all the serious music people, we all got our Baby Road Home studios popping up all over the planet. That's really cool if you ask me.
Post by Guitar on Oct 4, 2014 18:45:03 GMT -6
wiz... I will say also that Allen and Heath actually has a really cool summing sound. It's not as high fidelity as an SSL, but it does actually have a sound and a mood to it that's pretty cool, and better than some of its direct competition in the price range.
If you can't afford an SSL I would think an Allen and Heath would be a really smart investment. I just ordered a ZED 14, really looking forward to running a bunch of stuff through it. My hybrid rig is getting pretty complex, all the sudden. 1 summing mixer, and two analog boards. Obviously I don't need to use them all at the same time, but I could, or can. By the way you can find a used or b-stock ZED 14 in the $300 USD price range. That's equal-ish functions to the SSL at 1/10th of the price. Obviously they sound different. Might be a good experiment, though, if you're just feeling curious. I really am thinking about saving up for an X-Desk, though.
Post by popmann on Oct 4, 2014 21:08:14 GMT -6
Dbox.
Audient 2802.
Standout, forwad looking designs aimed at marrying analog summing to a midrange home studio. I was planning to buy an Audient for my mix rig....until I laid hands on....and man...SO small....I have big hands. I play 50 s U necks on my Strat....know what I mean? Chicklet sized buttons....kind of awkward MCU emulated layout....but, the idea is golden.
Analog master/monitor control. Analog Cue. 16ch Analog summing with 8 of them on faders, but AUTOMATED (ths fully recallable) faders. DAW control via MCU emulation on the same faders. Analog buss compressor. 8 solid preamps--which is enough for a small ensemble.
Post by swurveman on Oct 5, 2014 17:34:49 GMT -6
In my old life I sold copiers. We routinely delivered and installed for 1-2 weeks 20K demo units to small businesses who had no more investment than my partner and I have in our studio. So the question I have is why don't music dealers have demo units that people who already have made serious investments can try, instead of having to rely on audio and video a/b comparisons on the internet? And its not like a 20K copier didn't have sophisticated electronics and photo conductors. They do.
Post by popmann on Oct 5, 2014 18:09:53 GMT -6
SSL will post a comparison with software, but they won't a comparison with a cheap analog mixer. For good reason, IME. There's a myth out there that if you can't afford a big expensive discrete console, you'll get better results in software. Not my experience.
Post by Guitar on Oct 5, 2014 18:26:39 GMT -6
SSL will post a comparison with software, but they won't a comparison with a cheap analog mixer. For good reason, IME. There's a myth out there that if you can't afford a big expensive discrete console, you'll get better results in software. Not my experience. I could not agree more. It's a really strange idea that only "expensive" analog sounds analog or good, vs digital. Get a Mackie, I say, and your opinion might very well change. It must be some kind of snobby gearstlutism or something. If people are willing to believe this about compressors, microphones, then why not mixers? Well I'm certainly out of the box, now, and not for a queen's ransom either. I think computers generate a false sense of quality and security, well a little at least. At least if analog is your goal.
Post by popmann on Oct 5, 2014 21:21:55 GMT -6
It's not exactly even "anaog vs digital"....I tell you--as someone who sat here with them piped into the same DAC for reverse engineering purposes, that my old 56bit fixed Akai mixer sounded better in it's clarity and imaging. Same pan law, etc....test tone calibrated...
But, yeah--I've heard countless examples of people mixing on little Mackie and Behirnger and A&H boards sounding better than most software mixes. Even if on some level you could kind of say it MIGHT be lower fidelity in some way (though I wouldn't be quick to call it that)--they musically WORKED and sounded like a recording more than the some how "disjointed mud" that's so easy to produce in software mixers.
I held out for as long as I could--hoping someone would address the elephant in the room. Why DOES my $99 Behringer "summing mixer" sound better than the digital one? Cause it does--I promise. Its couldn't be used for client work because it's not exactly calibrated professionally, you know--recall would simply not work--and that was 100% necessary. For ME? Who cares? Dod a mix, print it. If you don't like it next week, redo it. Oh, wait--you don't dislike it enough to spend a few hours redoing it? then it's not an issue--move on.
Post by Guitar on Oct 5, 2014 22:09:50 GMT -6
That's how I'm working now, too. Mix it analog as well as I can. Is it bad enough to recall? Probably not, and it sounds darn good, so get used to it and keep moving.
I'm my own only client right now for the past few months, haha, so it's a pretty easy audience to please. Also, when you've got a mixer and a patchbay set up, it makes it that much easier to use the racks of outboard, instead of plugins. I kind of found converter loops, what cubase calls "external processor," to be a bit of a drag, just to get some compression or whatever. The delay compensation just bugged me for some reason, as well as the gain staging.
Post by popmann on Oct 6, 2014 15:23:25 GMT -6
Yeah, I don't know why that bothered you. It's MUCH easier than a patchbay**. You insert it just like a plug in....and turn the knobs on the hardware. I'm not sure how patching shit into a patchbay is easier. I did that for the first few decades of recording. No way it's easier. I haven't even HAD a patchbay for 15 years. And FWIW--mine was normalled when I did so I didn't have to patch stuff day to day--only if I needed to do something out of the ordinary.
**but, you DO have to have enough computer IO to have permanent devices defined....otherwise--sure that's a PIA. Constantly dicking around with the VST Connections....
Post by wiz on Oct 6, 2014 16:19:53 GMT -6
Heres my thoughts after some good time thinking more about this.
I think there might be a couple of things at play here.
Two thoughts. Colour and Summing
Colour.
the external box you use, gives you in whatever manner that its achieved a colour to the sound the you prefer.
Summing. (that doesn't introduce colour of a magnitude that influences the sound)
If you have tracks that are running at such a level, within the DAW that when they are being spit out by the DA of your interface, its operating the output of the interface at a output level that is less than ideal, and imparts a colour that you don't like.
I am not convinced that "separating" the outputs from the DAW has any magical effect in the summing sense.
I think that the reason some summing shootouts show marked differences between ITB and whatever summing box is being demo'd is really about "levels" and how they are handled by the particular interface. Remember thats with "colour" out of the equation.
I think that may be a large part of what is at play here.
Post by Guitar on Oct 6, 2014 16:36:57 GMT -6
I disagree. Summing introduces crosstalk across the channels, so there is a technical and audible difference there.
I've done a shootout (on the other site, you can check it out) where you can hear "color" (2 mic preamps) on a stereo mix, vs "summed" (into the same preamps) and there is a definite difference in width and separation.
Post by wiz on Oct 6, 2014 16:42:08 GMT -6
Fair enough, and I would agree with you except in my mind I am thinking that the crosstalk is wayyyyy down.
Whats the crosstalk on resistors in a passive network?
heres the specs from just something I grabbed now the DBox
Summing Section
Frequency Response: 1Hz-100kHz within 0.1dB THD+N: < 0.003% IMD: < 0.004% Crosstalk: < -97dB Noise: < -89dBu total energy in audio band Maximum Input: +27dBu
Monitor Section
Frequency Response: 1Hz-100kHz within 0.1dB THD+N: < 0.003% IMD: < 0.0035% Crosstalk: < -100dB Noise: < -91dBu total energy in audio band Maximum Input: +26dBu
D/A Converter:
Locks to standard AES or SPDIF signals 32kHz-100kHz Crosstalk: < -101dB Noise:< -92dBu THD+N: 0.005%
Nominal operating level: +4 dBu
Input impedance: 25 kohms balanced
Output impedance: 50 ohms balanced
look at the specs on crosstalk there.
