Post by Johnkenn on Sept 18, 2014 20:15:36 GMT -6
$399? Wth? Anyone know anything about it?
The successor to the acclaimed AM-20 equalizer, the Alta Moda Audio AM-25 is a versatile, high-performance four-band parametric equalizer module designed for the 500-series compatible rack system. State-of-the-art low noise/low distortion amplifier technology coupled with simple and elegant signal paths assure a smooth and robust sonic presence.
With it's classic layout, the AM-25 offers four continuously variable and overlapping frequency bands. This gives the AM-25 exceptional versatility for a wide range of audio applications.
The parametric center frequencies with continuously variable bandwidth adjustment offer the critical sonic and creative control needed for a wide variety of music styles and applications.
The unique interplay bewtween Q and gain controls make for a more intuitive experience - from subtle to surgical, parametric equalization has never been easier to use.
Hand-built in the USA, these units use some of the finest components available; 1% metal film resistors, high-quality plastic conductive potentiometers, and gold contact switches and relays.
Features:
Low Band: Shelving or peak/dip, continuously variable from 20Hz to 120Hz
Low Mid Band: Parametric, with variable Q. Sweepable frequency range 65Hz to 2kHz
High Mid Band: Parametric, with variable Q. Sweepable frequency range 1kHz to 7.5kHz
High Band: Shelving, with variable Q. Sweepable frequency range 4kHz to 20kHz
Hard Wire Bypass: old-contact relays completely remove unit from signal path when bypassed.
lghttp.17114.nexcesscdn.net/808784/vking/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/a/l/alta_moda_am_25.jpg
Features:
