Post by Johnkenn on Sept 12, 2014 20:46:22 GMT -6
I know this has been hashed around a bunch...but it's just perplexing to me. Is there no money in it? What gives?
Post by svart on Sept 12, 2014 21:08:59 GMT -6
47: VF14, PVC capsule.
67: dunno.
Both: Sennheiser barely puts money and time into the neutered U87i they make today.. so yeah, it's probably all about profit. They couldn't sell it for cheap, therefore they won't have enough people buy them to make up the costs of development, let alone make huge profits they require.
Post by ericn on Sept 12, 2014 21:23:57 GMT -6
Sennhiser is about makeing large quantities of mics, not a 100 or so a year. If you took all the 47 clone makers and added there output of top notch U47 clones. It would not come close to any of the current models. There also is a bit of the, " we feel what we make today is better and we are not going backwards." Mentality to but they would probably loose money. They still make the K47 capsule so the PVC isn't really an issue , since while not an M7, most don't care and many are surprised to find a k47 in their U47. I could ask Greg Bebee for the Offical line but I think we have pretty much covered it.
Post by aremos on Sept 12, 2014 21:29:04 GMT -6
From all the hashing we've been reading: 1) The 67 can be done completely but not cost effective? Because they're still making the capsule (ie: TLM-67) & the EF86 tubes is one of the most common. 2) The 47 (& 49) are a little more of a complex situation? Again, their capsules are still being made (both Neumann & Thiersch) but the tubes (VF14, AC701) are depleted or non-existent. Not sure about the transformers but Oliver Archut supposedly had them down pat. 3) The 12/251 is a matter of the capsule. But this one I never understood why AKG couldn't put an entire team to "recreate" the CK-12.
I guess it all boils down to cost effectiveness in all of them! And now with Harmon & Sennheiser running things who knows what is expected of these companies! But I think about the question a lot. Why can't they just do it & see what happens? Or am I too naive?
Post by Johnkenn on Sept 12, 2014 21:29:32 GMT -6
I'm just shocked they're not smart enough to even make dumbed down versions and pop the names on them. I mean, they could probably sell a ton of U-47 bodied and badged mics regardless of what's in them.
Post by kidvybes on Sept 12, 2014 21:47:59 GMT -6
...shake off the nostalgia...comparable options exist, in many cases for far less money than if Neumann (Sennheiser) or AKG reissued them...even the "unobtainium tubes" talk is a good part mythology...capsules, transformers, resistors and capacitors (of higher quality) are available...you can even buy the Neumann badges if it makes you feel better...
...and even if those classics were reissued by the original manufacturers, you know they would be critiqued to death for not living up to the vintage versions...it's all bullshyte...sorry, don't believe the hype...the only difference is "old" vs "new"...
Post by drbill on Sept 12, 2014 23:07:17 GMT -6
The 47 is kind of obvious, mostly a tube issue, but Neumann has said in print on numerous occasions that they don't believe there is enough demand for a U67 re-release.
Post by BradM on Sept 12, 2014 23:28:47 GMT -6
I think we would have to quantify "demand", huh? I wonder what the Sennheiser bean counters deem enough market interest to spin up design and manufacturing.
Brad
Post by tonycamphd on Sept 13, 2014 0:43:42 GMT -6
Max sold 50 diy MK U47 kits in about a month or so! (i believe maybe 3 left?), i also think they were about $1,300.00 each, and if my math's correct, thats a cool gross of $65,000!!! Sounds like demand to me!
Post by levon on Sept 13, 2014 2:01:30 GMT -6
The 47 is kind of obvious, mostly a tube issue, but Neumann has said in print on numerous occasions that they don't believe there is enough demand for a U67 re-release. Andreas Grosser has developed a FET version of the VF14 that sounds so close to the real thing, that I couldn't hear a difference when I tried both at his place. The tube was more noisy, but that was it. He gave me the option of building a 47 for me with the tube or with his FET replacement. I could have chosen the tube version, and I really, really wanted to, but I went for the FET, no noise, not problems down the road with an old tube, same price, no contest. And, if ever I decide I want a tube after all, I just pop out the FET and put a VF14 in. Simple as that. Andreas' FET uses the same socket as the tube. As for the 67, I really would like to see a faithful recreation at an affordable price. Old U67s go for over 6,000 euros here.
Post by svart on Sept 13, 2014 8:28:40 GMT -6
Max sold 50 diy MK U47 kits in about a month or so! (i believe maybe 3 left?), i also think they were about $1,300.00 each, and if my math's correct, thats a cool gross of $65,000!!! Sounds like demand to me! That's not even enough to pay the salary of a single engineer to work on the design, let alone a team of engineers, builders, machines, test equipment, prototypes, parts, etc. It's not uncommon for a company to spend 4-6 million on a new product line.
Post by Ward on Sept 13, 2014 9:20:20 GMT -6
For a U67 recreation, there would be no need of engineers or new processes. Most of the parts are on their shelves or in their bins, and if not can easily be obtained. It's not expensive, but it will take away sales from TLM67s, U87ais TLM103s, TLM107s and Sennheiser's other self-branded microphones. Therein lies the rub!
Now, to address the point of the U47 recreation with anything thrown into it and just put it on the market... consider the TLM67. Blech.
Post by tonycamphd on Sept 13, 2014 9:33:47 GMT -6
I'd bet not a single mic company, in the history of mic company's, has ever spent anywhere near even 10% to the neighborhood of $4-6 million on developing a single mic line(and $400,000 is being generous). At that rate, Rode would have had to sell at least 16,000 k2's before they pocketed their 1st dollar of profit.
Post by jimwilliams on Sept 13, 2014 10:05:36 GMT -6
If Rode had paid me $65,000 for the design of the NT-2 I'd still be doing backflips. However, that is not the case in the world of semi-pro audio.
As to Sennheiser, look at what they are selling, they are into new, solid state electronic switchable pattern surface mount automated designs. It's the same reason Chevy doesn't go back and make the classic 57 Bel Air.
Post by jontheriffer on Sept 13, 2014 12:01:35 GMT -6
Put me down for a 57 Belair reissue
Post by Bob Olhsson on Sept 13, 2014 12:19:15 GMT -6
The U-47 isn't going to happen because the tube was discontinued during the '50s and the hand-made capsules had been smuggled in from their old plant in East Germany that is now back in the hands of the Neumann family.
They have reissued U67s a few times. I suspect at this point there are issues with both EU environmental laws and obtaining parts that make it next to impossible to do anything that wouldn't just be another emulation. Most people don't realize that integrated circuits have displaced most of the common electronic parts that used to be used for building audio gear. I've also never found a new EF-86 that didn't go noisy after just a few months.
Post by ericn on Sept 13, 2014 13:55:07 GMT -6
A former Senn. Guy told me this morning Never going to happen minimum run for them is 10K they have run the numbers, with all the clones , they would not move fast enough. Now here is what I have been told for 30 years, ifYOU front the money as a dealer they would build what ever you want but it won't be cheap! Because your buying all 10,000!
Post by tonycamphd on Sept 13, 2014 14:14:45 GMT -6
just build this and save $7,000, you'll probably never pick it out in a blind against a real U67 unless it's cowboycoalminer's 8)
Post by lpedrum on Sept 13, 2014 14:31:29 GMT -6
I know this has been hashed around a bunch...but it's just perplexing to me. Is there no money in it? What gives? I think they will at some point. Zildjian eventually put out clones of the old K's because they came to realize that they owned the name and rights to the most iconic cymbal ever made. Even though it's not their top seller it gives the Zildjian brand legitimacy and a link to their historic past as the world's foremost cymbal maker. Perhaps Neumann will eventually see the value of owning their own history.
Post by aremos on Sept 13, 2014 15:39:58 GMT -6
A former Senn. Guy told me this morning Never going to happen minimum run for them is 10K they have run the numbers, with all the clones , they would not move fast enough. Now here is what I have been told for 30 years, ifYOU front the money as a dealer they would build what ever you want but it won't be cheap! Because your buying all 10,000! We, the People, of the forum, will unite to form a perfect union that will become a dealership in order to provide 10K of the membership a microphone worthy of their talent & investment in this venture.
Post by ericn on Sept 13, 2014 17:22:53 GMT -6
A former Senn. Guy told me this morning Never going to happen minimum run for them is 10K they have run the numbers, with all the clones , they would not move fast enough. Now here is what I have been told for 30 years, ifYOU front the money as a dealer they would build what ever you want but it won't be cheap! Because your buying all 10,000! We, the People, of the forum, will unite to form a perfect union that will become a dealership in order to provide 10K of the membership a microphone worthy of their talent & investment in this venture. Sure we will 10.000 at say dealer of say $4000 = $40,000,000 since we have no dealer history that will be cash with order. And that's why they haven't done it!
Post by drbill on Sept 13, 2014 17:44:27 GMT -6
The reality is, there's no market for it. People SAY they will pay $6k for a re-release, but when it comes time to put up their CC number, that number shrinks to next to nothing. Neumann et al are smart businessmen and they would do it in a heartbeat if they met their numbers.
Post by Johnkenn on Sept 13, 2014 20:00:00 GMT -6
The reality is, there's no market for it. People SAY they will pay $6k for a re-release, but when it comes time to put up their CC number, that number shrinks to next to nothing. Neumann et al are smart businessmen and they would do it in a heartbeat if they met their numbers. Probably true. Wonder how Tele USA Is doing it?
Post by mrholmes on Sept 13, 2014 20:08:40 GMT -6
I'm just shocked they're not smart enough to even make dumbed down versions and pop the names on them. I mean, they could probably sell a ton of U-47 bodied and badged mics regardless of what's in them. That would be an insult to all employees at Neumann here in Berlin.
Post by ericn on Sept 13, 2014 20:16:25 GMT -6
The reality is, there's no market for it. People SAY they will pay $6k for a re-release, but when it comes time to put up their CC number, that number shrinks to next to nothing. Neumann et al are smart businessmen and they would do it in a heartbeat if they met their numbers. Probably true. Wonder how Tele USA Is doing it? The differance is the number they are set up to build, plus Tele USA out sources a lot where Senn. Is a manufacturing company. It's like Mclearen VS GM!
