Post by EmRR on Oct 7, 2024 12:55:53 GMT -6
2 Shure A15LA 50db line pads. Perfect for feeding line level sources into mic preamps, such as DAW mix to preamp. $40/pair, US shipping in a priority mailbox would be $8. 1 Shure A15A 15dB mic pad. ‘O’ pad rather than the modern ‘U’ pad. 150 ohm load to both mic and preamp, for 'matching' condition rather than 'bridging' giving a heavier load. They don't make'm like this anymore. With dynamics and ribbons should give a darker sound. Passes phantom better than the current ‘U’ pad, though really both are fine in that regard. $20, US shipping in a priority mailbox would be $8. 1 Sound Devices XL-TP 12-15V phantom to 12V T-power. This is a special use piece for sure, needs a home! Found this blurb: With the 12 or 15 V phantom power setting on Sound Devices MP-1, MixPre, and MP-2 field production products, the XL-TP efficiently provides T power for microphones which require it. Because it works at a the lower phantom level on these products, the XL-TP extends battery life when powering T-powered microphones. NOT for use with 24V or 48V phantom. $20, US shipping in a priority mailbox would be $8.
