Post by sean on Sept 8, 2024 16:46:05 GMT -6
Lots of stuff for sale. Pretty much firm on prices.
SPL MixDream: Incredibly flexible 16 channel summing mixer with inserts on each channel, direct outs on each channel, stereo width expander, and peak limiter. $1800
Dangerous Music Monitor ST with Remote and SR 5.1 Expansion. A studio stable for a reason, one of the best analog monitor controllers on the market. The SR expansion allows for 5.1 monitoring (more can be added to expanded into ATMOS monitoring). $1750 for everything
AML ez627: Fairchild 627 tube equalizer. Comes with an extra set of NOS matched tubes if you want to get a second unit. $1500
Lexicon PCM96: The last great hardware reverb Lexicon designed. Amazing sounding unit. $1500
Maag Magnum K compressor: This is an incredibly flexible unit. Compressor section can be feedback or feed forward style with adjustable ratio, attack, and release as well as a range control which can limit the maximum amount of compression and a side chain filter. Next is the “K Comp” which compresses the 3K range to tame harshness. From there it hits the EQ2 and finally a soft limiter. Like new with original box. $1250
High Voltage Audio EQ-6S Stereo Equalizer. Inspired by the NTI EQ3. Beautiful on a 2 mix. $800
Sennheiser MD409 U3: Serviced by Cole Picks Vintage. $700
Advanced Audio CM800T: Sonically inspired by the Sony C800G. One of the best values on the market. Comes with case and all the accessories. $500
Post by Johnkenn on Sept 9, 2024 10:52:09 GMT -6
Are they DB25 to DB25?
Post by sean on Sept 9, 2024 11:29:32 GMT -6
Post by decasta on Sept 9, 2024 21:18:24 GMT -6
The Chandler REDD mic is amazing. Makes recording and mixing whatever I put through it so easy. Whoever buys it will surely not regret it.
Post by sean on Sept 16, 2024 7:14:21 GMT -6
Listed updated
Post by sean on Oct 1, 2024 19:15:46 GMT -6
Listing updated, priced dropped
Post by sean on Nov 18, 2024 16:48:37 GMT -6
Updated
