Post by tonycamphd on Aug 31, 2024 10:54:34 GMT -6
Curious to see how you guys deal with drums entire song by song process, from room, tuning, capture of individual tracks, compression, bussing and other treatments, reverbs, delays yada yada yada
Post by drumsound on Aug 31, 2024 12:22:38 GMT -6
OK, I'll bite. In tracking, I almost always compress BD and SD. I feel that helps them to be present and drive the song. I have a two channel comp pretty much always patched into their channels, and I don't change the settings all that often. It's kind of obvious in solo, or whole drumset solo, but in context with the rest of the band, they just speak. I often EQ the inside BD and sometimes the outside.
For a long time, the Sennheiser e602II was my BD choice (and I know it will come back) but I got my D12 repaired recently and I'm having fun with it right now. I have a borrowed FET47 that is doing its thing outside the BD. I've been changing up SD mics a lot lately. MC012 in hyper (with pad) EV 408, Gefel 295 (I think that's the number), and my staple ATM23he all make appearances.
My room seems to like SDC more than LDCs for overheads. I can't quite explain it, but I'm usually happier with SDCs. I generally go with ORTF and use the diagonal line bisecting the SD and BD for positioning. For a long time I used Octava MC012, but I bought a set of Muro mics, and I like the way they image a little better. At times I'll use the Røde TF5s on OH as well. From time to time I'll put up ribbons. Bottom snare is an EV re10 for a while now.
Toms I like pretty close to the head, to give them a similar presence and feel as sitting behind the drums. Currently, I have sE X1d titanium capsule LDCs up, but I use M88s just as often. I used 421s for many years but sold them to a friend a few years back.
Room mics usually are up for a while until I get bored, or they bother me in context of what or who I'm working with/on. Right now it's a 12-Gauge Black stereo mic. It's got a cool brightness that, even if just peppered in adds a lot to the sound. The Rødes pointed at the wall opposite the drums sounded good (sometimes with a lot of compression...maybe too much), 4050 in omni on straight stands at the lowest was my staple for a long time, but really worked better on tape than digital. 635as taped to the floor are a really great room option as well.
Hats get an M201 or other dynamic. Ride cymbal, right now, is an MC012, but recently has been the Gefel, or a 414EB.
When it comes time to mix a couple of things happen as default starting points. I set up a drum parallel compressor with a UAD Zener and the Ryan Hewett "drum parallel smash" preset. It often gets tweaked, but it's a damn good place to start. I set up send on all of the drum tracks, but in digital world I mute OH, Room, and cymbal spots. Back in the tape days all the tracks into the parallel worked more often. I also made a preset for inside BD. It's the UAD SSL E strip and it's used pretty aggressively, EQ, gate, comp and filters all engaged. It also gets tweaked for the song, and sometimes even removed. Snare and toms EQ'd if necessary. I'll sometimes duplicate the snare to have separate snap and body faders. BD also might get dupes.
I sometimes delay the room mics, right on the channel insert. Kind of the Albini thing, though I don't think it sounds the way he conceptualized it, it can sound really good. Soundtoys Echobor JR is PERFECT for this because it's dead simple and sounds great.
Reverb is a total crapshoot. Often I don't use it, because I spend time with my room mics, and parallel compressor for both tone, balance, and feel. That said a few things in the last year or so had a reverb from the Eventide SP2016 or UAD Capital or Oceanway. If I'm not digging my room mics on a particular track, the OW can sometimes make me feel like I got a good/more fitting room capture.
Post by doubledog on Aug 31, 2024 13:23:17 GMT -6
My standard setup (right now) when I'm tracking drums for a client is... Usually a Pearl Reference Pure kit (usually 12x8/16x16 and 22x14 [but I've got 10x8, 13x9, 14x14 as well as other kits]). Snare always changes (I've got a bunch). Telefunken M82 in the bass drum port, sE X1D and a DIY subkick on the outside. Overheads are a spaced pair of Lauten LA-220 v2 (with HPF and LPF engaged). Room mics are a pair of AT4033 facing the back wall and sort of up in the corners (I've got vaulted ceilings so it's not a typical corner) - the idea is to catch the reflection off the back wall/corner first which makes the room sound a little bigger (even though it's not tiny either at 19x25ft, 15ft peak). Toms right now are ATM-230 and snare is Telefunken M80. I sometimes switch the tom mics for 421's or Lauten Tom Mics, and the snare mic for a 57, or Lauten Snare Mic, or an old Revox M3500 (like a Beyer M201) if I feel like something else is not working. HiHat and Ride get a spot mic from a Slate ML-2 (and sometimes I remember to use the modeling software and sometimes I don't - if I do, I usually choose the Schoeps M222 model aka S-222). Bottom snare is a 57.
For a rough mix (all ITB) I'll usually have the Waves SSL (E or G) channel on each track and EQ as I see fit for whatever the song is. I've been using that for a long time and I like the gates better than some others I've got some basic presets as starting points, but I'll always change it a little based on the song. Same for reverb (which is usually just an Aux with snare and toms sent to it). I tend to start with the Lexicon MPX (there's a preset "slammin drum room" or something like that) but that gets swapped out for a different setting or a completely different verb depending on the song. no preset works for everything. Then I've got a parallel compressor on an Aux. My default is the SoundToys Devil-Loc Deluxe, but that is sometimes too much so I often swap this for something else too (I've got a ton of choices unfortunately, or maybe fortunately?). Lately I like the Softube VCA, UAD Neve 33609, DBX 160, TDR Molot GE, an 1176... If it's not a rock and roll song, then I probably won't even use this parallel bus. if it's used, then kick and snare go to it and sometimes a bit of toms, or rarely a little overhead. I've usually got the Slate FG-X2 on the master bus.
of course all of this may change when it comes to a final mix and many times I'm sending the drum tracks off to someone else (although I try to get it sounding pretty good because I suspect [ok, I know] that at least half of them use my stereo drums-only mix in their final mix...)
Post by notneeson on Aug 31, 2024 13:48:59 GMT -6
Have been lucky to record some great drummers the last few years. Last thing I did was on a new Daking board, smattering of EQ and channel compression on kick and snare only. Zero outboard. Biggest improvements to the sound were made in tuning and damping. Yamaha Recording Custom kit. First time tracking one of those, very interesting and cool sounding drum kit. Drummer is an AE too and heard stuff (too much tom ring on other hits) I didn't even clock, but boy was it better when he fixed it. Great collaboration.
OH, Gefell pair— UMT 70s Josephson e22s on toms. Beyer m201 on snare D12VR on kick in Some kind of 47fet clone on kick out? (I forget, maybe Chad Kelly's mic) mono room LDC 414EB mono room dynamic SM57?(facing away from the drums)
Current rough mix has some ITB EQ and compression here and there, a snare reverb, not too much going on but it sounds great. Not even sure I have a parallel comp going.
Post by theshea on Sept 1, 2024 0:51:23 GMT -6
i have a very cheap trashy no name kit in my studio. the snare is an old supraphonic 5x14“ but the rest is cheap. but the heads are always either evans or remo‘s, really good quality. THOSE and the TUNING are the most important things to me. and that‘s why i can get various sounds (for various music styles) out of this cheap kit. and yeah, i forgot the drummer, also KINDA important … the cymbals can get annoying sometimes but nothing some de-esser or dynamic eq can‘t fix.
recording: mainly standard things. i really experimented a lot in the past (glyn johns, recorderman, xy) and i came to a point where i know how my room sounds, which is rather dry. so i prefer SDC as a spaced pair on overheads to capture mainly the cymbals. sometimes i use ribbons instead for darker cymbals. snare always sm57 top and bottom. you can change the sound so much more with the snare tuning or a towel or moving the angle of the sm57 thand by changing the mic. toms md421. kick any LDC in front. no inner kick mic. IF needed i use a sample. kick and snare always get some compression with 1176‘s when recording.
pre-mixing: really important phase! i won‘t start mixing before editing. checking phase, adjusting phase with melda alignment (cheap plugin and works wonders). i don‘t quantize 100%, maybe 80-85% and fills i don‘t do at all. another important step in this phase: i use audio acustica gold on all channels to give it another pass of color and it helps smoothing transients a bit making sounds more managable in the mix. tracks where needed also get some minor eqing with AA gold and maybe some plugin compression (max. 3db GR). and if needed some tape saturation (ik multimedia 80 machinge. after this the tracks should sound as recorded in a major studio with good gear. ready for mixing. i render all the tracks and export them. ready to import in a clean mixing session.
mixing: yes, the ssl channelstrips simply work. i use the PA E channel ones and gate kick and snare. toms i cut up manually. i use only plugins. i try to use a sample only on the kick if possible. but if so it helps clean up the drumsound a lot most of the time. parallel compression: the AA gold 2254 comp can get aggressive and bring up room sound around the snare pretty well. distortion bus: also used on kick toms snare, faderriding throuout the song to push the drums/energy more during certain parts. mostly i use softube one knob distortion or AA fire the clip or koanghelm sddr. overall drumbus compression: depends on the song and style. automation: very important to ride certain fills, parts etc.
Post by honkeur on Sept 1, 2024 7:15:28 GMT -6
Not a general-purpose technique, but I’ll describe how I recorded a free jazz drummer on a recent session. The player and the musical style implied the best approach would be to capture the kit as a single instrument. Just two Beyerdynamic M160s: one at drummers right shoulder, pointed at the snare, and a second in front of the kit on the drummer’s left side, a mid-snare height, angled between kit and snare. Both mics the same distance from snare center.
In mix, the two mics panned maybe one-third L and R, but aince the kick was mostly in the front mic, every thing below 400hz was made mono. Across the drum bus, tiny subtractive EQ cuts and some preamp saturation. Very small amount of parallel 1176 all-buttons-in; Neve 33609 across bus at 2:1, fastest release, no limiting, doing maybe 2db gain reduction; SIR clipping, only hitting the exceptional transients. A touch of Bricasti room reverb and the tiniest hint of a 5-second cathedral verb — barely noticable if you mute/unmute it.
I enjoy fewer mics when the drummer is not performing the function of “timekeeper”. (I guess that means…jazz, or something like that.)
Post by doubledog on Sept 1, 2024 12:52:48 GMT -6
Totally agree that jazz drums (for acoustic jazz) are a totally different beast. Minimal mics usually necessary (and usually best - Glyn Johns style can work great in the right room) If you are doing more modern fusion or smooth jazz or something like that, then the other techniques usually still apply (multiple mics). not exactly jazz, but I did this with a Glyn Johns or Recorderman style (4 mics) setup and it worked perfectly for what I needed. (Vintage Ludwig kit 13/16/22 Miktek PM11 on kick, Revox M3500 on snare, pair of Warm 87 (v1) overhead/side) It was the middle of the pandemic and I was nerding out in my studio on remote projects...
Post by smashlord on Sept 1, 2024 14:10:26 GMT -6
Different every time.
Sometimes stereo, sometimes mono. Sometimes a big kit in a big room with lots of spot mics, sometimes dead dry in a booth with a miking scheme that favors a couple of mic capturing the overall kit. It all depends on the song.
Mic choice depends on desired result. I spend a good bit of time treating the source... getting the right drums, right tuning, right combination of dampening, etc... If you do that and the drummer has a good self balance, very little processing is needed on the way in.
I often EQ on the way in, but rarely compress anything other than the room mics and maybe overheads. I personally find its better to EQ and gate before compression for reasons pertaining to bleed as well as doing clip gain as needed to keep the compressors in their sweet spots.
Post by knucklehead89 on Sept 1, 2024 17:28:14 GMT -6
Different every time. Sometimes stereo, sometimes mono. Sometimes a big kit in a big room with lots of spot mics, sometimes dead dry in a booth with a miking scheme that favors a couple of mic capturing the overall kit. It all depends on the song. Mic choice depends on desired result. I spend a good bit of time treating the source... getting the right drums, right tuning, right combination of dampening, etc... If you do that and the drummer has a good self balance, very little processing is needed on the way in. I often EQ on the way in, but rarely compress anything other than the room mics and maybe overheads. I personally find its better to EQ and gate before compression for reasons pertaining to bleed as well as doing clip gain as needed to keep the compressors in their sweet spots. Pretty much same for me. I don’t compress kick or snare or Toms on the way in. For the same reasons and I also don’t really enjoy compression directly on those mics. I prefer to use parallel only on kick and snare 95% of the time unless the drummer is more dynamic than the track needs. Something about an uncompressed raw snare that just sounds right to me when a drummer is digging in and getting some rim on the hits. Although sometimes I do compressed the whole drum bus together maybe 3-4db for glue but most times parallel. But that’s just me. I do like to smash up some room mics for excitement and pumping if desired. Also sometimes like Smashlord, I might compressed the overheads for a bit of glue
Post by sean on Sept 1, 2024 19:00:57 GMT -6
The treatment of the drums and the player make all the difference. That was very obvious this week, during set up we had one drummer, and it turned out he had to bail, so someone else came in his place. Same kit, same mics, same room…totally different sound (for the better)
I think what I’ve learn makes the biggest difference in clarity/seperation is packing the lugs of old kits and snares to get rid of any spring rattles and noise. I took all the internal mufflers and accessories mounts off stuff because they usually just make noise. The more shit you have rattling around the more you’ll pull your hair out. The tuning of the drums and head choice is super important. I’ve found for most snares I like 12 or 16 strand wires, it just seems more controlled in the studio.
I don’t compress much to tape but I’ll usually do some EQing. At least in my space I find I’m usually taking out a little around 400Hz in overheads to get rid of boxyness in toms and or snare, and if I use a ribbon I might boost a little 12K/wherever the stick on the ride sound is if it’s lacking. I usually use a mic with a low cut filter on the hi hat and find myself cutting around 500Hz to 700Hz to take out some of the snare bleed. Inside kick similar in that there’s usually not anything I want around 300-500Hz so I’ll dip around there. A little 36Hz from an API 560 can really be nice, sometimes a bit of 3-5K for attack. Room mics I have some omnis on the wall up high and again usually taking out some of that low mid boxyness and I do like to compress those with my Compex. It’s great for that because I can control how much I compress the room with just the gain of the preamp…it doesn’t really get any louder it just gets more compressed. So, you can dial in what feels appropriate without being fooled by volume.
Inside kick I like my old Sennheiser e602, outside changes but lately it’s been a Beyerdynamic M380, snare top and bottom I’m in love with the Shure SM57 with the Crimson Audio White handles, toms either Josephson e22s or AKG C414B-ULS, hi-hat AKG C480B-ULS, overhead is usually a Royer SF-12, and rooms are Line Audio Omni1.
Sometimes it’s fun to throw up a “trash” mic. I got an Ampex 1101 which is cool but I think the Shure Green Bullet is a bit more fun/extreme
Post by jampa on Sept 2, 2024 1:35:56 GMT -6
First depends on:
- if the song needs it (can we just use a shaker) - how much time we have - how good the drummer is - how good we can make the drum kit or not (tuning, damping, position in room, cymbals, etc.)
Then if:
- tracking live - tracking isolated drums (e.g. to click or feed in the cans) - adding triggered hits in post (typically avoid)
Then:
- musical style - how big the set is - how many channels and what mics available
I will do whatever I can to get the core sound with four mics: kick, snare, overheads.
Then I would add toms and rooms (total: eight). Then if relevant, I would slowly add more if I think the phase relationships will work out
I always get the drummer to listen to takes, to get them to 'self balance' ahead of mixing
Post by jampa on Sept 2, 2024 1:36:58 GMT -6
I have also long accepted to treat drums as a hole in my pocket
Post by doubledog on Sept 2, 2024 8:23:25 GMT -6
A drum kit that is setup for "live sound" or gigging, is not always the optimal setup for a studio recording. Sometimes it can be, but many times the gigging kit is more open and live, which might work great in clubs (or larger) where you need projection, but may not sound right in a studio setting, which will likely have different kinds of reflections off walls/floors/ceilings. So in other words, the drummer may have to treat or tune the kit differently, or use different heads or different cymbals, or even different drums in the studio. I think sometimes a lot of new drummers want to just drag their kit in they use for gigs, but many times it is better to use the "house kit" if one exists (it hopefully has decent heads, less "self-noise", etc.). And then once in awhile somebody drags in a piece of crap that looks like it was pulled out of the river, and they still sound like magic... so no rules, right?
Post by drumsound on Sept 2, 2024 8:53:22 GMT -6
A drum kit that is setup for "live sound" or gigging, is not always the optimal setup for a studio recording. Sometimes it can be, but many times the gigging kit is more open and live, which might work great in clubs (or larger) where you need projection, but may not sound right in a studio setting, which will likely have different kinds of reflections off walls/floors/ceilings. So in other words, the drummer may have to treat or tune the kit differently, or use different heads or different cymbals, or even different drums in the studio. I think sometimes a lot of new drummers want to just drag their kit in they use for gigs, but many times it is better to use the "house kit" if one exists (it hopefully has decent heads, less "self-noise", etc.). And then once in awhile somebody drags in a piece of crap that looks like it was pulled out of the river, and they still sound like magic... so no rules, right? Good Point! I always have Moongel, a couple of the Snareweight leather mufflers, Big Fat Snare, 'rings,' I bought the 4-pack of Drops recently, and when in doubt, gaffer tape (with ot without paper towel). Plus the 13 snares and 25 or so cymbals that I can alter someone's set or use with mine.
