Post by Johnkenn on Aug 30, 2024 23:05:21 GMT -6
Post by drumsound on Aug 31, 2024 2:52:12 GMT -6
Sounds good. What processing (besides reverb) is happening on this?
Post by keymod on Aug 31, 2024 5:57:20 GMT -6
We have Chad's u47, and a very rare u67. Love 'em !!
Post by Johnkenn on Aug 31, 2024 7:07:16 GMT -6
Sounds good. What processing (besides reverb) is happening on this? I took a few notches out for resonances around 2.5 and 3.5. But other than the reverb, that’s it.
Post by drumsound on Aug 31, 2024 10:36:11 GMT -6
Sounds good. What processing (besides reverb) is happening on this? I took a few notches out for resonances around 2.5 and 3.5. But other than the reverb, that’s it. Nice that just a little touch of EQ does it. I think it suits your voice well.
Post by chessparov on Aug 31, 2024 12:17:56 GMT -6
Sounds great! Chris
Post by ericn on Aug 31, 2024 14:41:34 GMT -6
Post by Johnkenn on Aug 31, 2024 15:47:19 GMT -6
OPR. Chad said he thought it was the most authentic. I’d say it kinda sounds like an M7 imo. Always thought M7s were a little smaller on bottom - well, more frowny face curve
Post by ericn on Aug 31, 2024 17:02:27 GMT -6
OPR. Chad said he thought it was the most authentic. I’d say it kinda sounds like an M7 imo. Always thought M7s were a little smaller on bottom - well, more frowny face curve Yeah, poorly maintained ones sort of built this reputation, a great M7 has a pretty impressive LF response, hence its popularity as a main mic for minimalist stereo work. Sounds damn impressive , especially for the $. Chad knows his stuff. The sample sounds damn good through 7506’s in he gym, would love to here the raw track.
Post by timcampbell on Sept 1, 2024 19:21:25 GMT -6
Sounds great John.
Post by Martin John Butler on Sept 2, 2024 16:37:31 GMT -6
That’s one of the smoothest tracks I’ve ever heard you make John. I have a feeling if you put that into the track, it’s gonna sit beautifully. I can hear it’s a little bit thin on the low end, but I have a hunch that you would cut those frequencies out anyway when you put it in a mix.
Post by Johnkenn on Sept 2, 2024 18:21:07 GMT -6
That’s one of the smoothest tracks I’ve ever heard you make John. I have a feeling if you put that into the track, it’s gonna sit beautifully. I can hear it’s a little bit thin on the low end, but I have a hunch that you would cut those frequencies out anyway when you put it in a mix. Yeah - it like it’s pre eq’d. I think id like a little more bottom and then be in charge of cutting that out myself. It’s also occurred to me talking to stam the other day that I might be totally misleading when I talk about “low end.” Because I mostly only track vocals and acoustic instruments here at my place…so I guess I kind of use those things as my reference when talking about frequencies. So all this time I’ve been saying stuff like “the sta is really big on bottom.” Well, it’s big on the bottom of my vocal…so it’s actually the lower mids I’m probably talking about. Like 100-300 hz. Not 60 considering a vocal doesn’t reach that low. (The sta does actually add a lot of that lower octave on stuff like bass) Chad’s information says this capsule has a bigger sub response than any of the other capsules - and I guess it doesn’t come up far enough to affect my vocal. Idk. I’d like to see a polar chart. The Heiserman k47 was huge on the bottom. To the point of being a little trouble dialing out of a vocal. I’d imagine some screws could be twisted to maybe give it a little more push in that bottom octave. BUT - like Martin John Butler said, I’d most likely be dialing it out anyway.
Post by Johnkenn on Sept 2, 2024 18:25:49 GMT -6
I should save my thoughts for the review…but man - this is worth a ton more than he’s making them for. I’ve had extensive time and owned several 47 variants. Wunder CM7 and both glass tube versions (sound great but could never tame the bite in the 2khz range), Heiserman - sounds fantastic and should absolutely be on anyone’s radar. Probably a little more modern sounding in my opinion. Telefunken and tried the Flea before. The quality of this mic is absolutely in with those.
Post by ab101 on Sept 2, 2024 18:34:27 GMT -6
Does the Heiserman capsule have more low end? The Heiserman 47s have plenty of low end.
Post by Johnkenn on Sept 2, 2024 18:45:33 GMT -6
Does the Heiserman capsule have more low end? The Heiserman 47s have plenty of low end. Well, like I was saying, it has more low end on my voice than this one…but that probably means it has more 150-300 or whatever. The SAE is a kk47, so I imagine some screws could be twisted. I don’t know if that’s laughed at by some mic people, but I’ve seen Shannon do it in front of me, and it definitely changed things. Obviously, I would let a pro do that. Not sure I want to though.
Post by paulcheeba on Sept 3, 2024 1:43:57 GMT -6
I should save my thoughts for the review…but man - this is worth a ton more than he’s making them for. I’ve had extensive time and owned several 47 variants. Wunder CM7 and both glass tube versions (sound great but could never tame the bite in the 2khz range), Heiserman - sounds fantastic and should absolutely be on anyone’s radar. Probably a little more modern sounding in my opinion. Telefunken and tried the Flea before. The quality of this mic is absolutely in with those. Love my Heisermen they sound almost as good as my original 47’s &48. I have a couple of Flea’s with Beesneez K7 which also sound great but the OPR sound the same in the top and the mids but bass lite. I keep nearly buying CM7’s and then thinking why do I need more than 10 47’s. I’d like to hear a CM7 with a K49 though.
Post by drumsound on Sept 3, 2024 7:57:37 GMT -6
I should save my thoughts for the review…but man - this is worth a ton more than he’s making them for. I’ve had extensive time and owned several 47 variants. Wunder CM7 and both glass tube versions (sound great but could never tame the bite in the 2khz range), Heiserman - sounds fantastic and should absolutely be on anyone’s radar. Probably a little more modern sounding in my opinion. Telefunken and tried the Flea before. The quality of this mic is absolutely in with those. Love my Heisermen they sound almost as good as my original 47’s &48. I have a couple of Flea’s with Beesneez K7 which also sound great but the OPR sound the same in the top and the mids but bass lite. I keep nearly buying CM7’s and then thinking why do I need more than 10 47’s. I’d like to hear a CM7 with a K49 though. You're a sick man, Paul.
Post by Ward on Sept 3, 2024 10:52:47 GMT -6
I absolutely adore my cdkelly 48! Every vocal track on an album I'm mixing now. had to brighten in the mix at times, but otherwise virtually nothing. EDIT: That being said, I've heard recordings of you on a H47 and 251 and prefer those sounds to this one.
Post by jasontodd on Sept 3, 2024 11:00:49 GMT -6
I absolutely adore my cdkelly 48! Every vocal track on an album I'm mixing now. had to brighten in the mix at times, but otherwise virtually nothing. Do you have the Heiserman or O.P.R. capsule in yours, Ward? I think the O.P.R. sounds really nice on John's voice, but am concerned about it potentially being a little bass shy. What's your experience? Thanks.
Post by Ward on Sept 3, 2024 11:10:56 GMT -6
I absolutely adore my cdkelly 48! Every vocal track on an album I'm mixing now. had to brighten in the mix at times, but otherwise virtually nothing. Do you have the Heiserman or O.P.R. capsule in yours, Ward? I think the O.P.R. sounds really nice on John's voice, but am concerned about it potentially being a little bass shy. What's your experience? Thanks. Mine has the OPR capsule which is allegedly like an M7 but sounds 50% M7 and 50% K47 to me.
Post by drumsound on Sept 3, 2024 11:28:04 GMT -6
Do you have the Heiserman or O.P.R. capsule in yours, Ward? I think the O.P.R. sounds really nice on John's voice, but am concerned about it potentially being a little bass shy. What's your experience? Thanks. Mine has the OPR capsule which is allegedly like an M7 but sounds 50% M7 and 50% K47 to me. That doesn't seem like a bad thing to me.
Post by chessparov on Sept 3, 2024 11:42:05 GMT -6
You're a sick man, Paul. So is it wrong for me to have a U47 Poster... Next to my pinup of Ava Gardner? Up there. Night and Day. Chris
Post by drumsound on Sept 3, 2024 11:46:06 GMT -6
So is it wrong for me to have a U47 Poster... Next to my pinup of Ava Gardner? Up there. Night and Day. Chris I'll allow it
Post by ericn on Sept 3, 2024 14:40:15 GMT -6
Just Damn ! Chad nailed this one, his work with Warm & UT showed his talent on a budget, but this time he gave us a mic that can hang with the big boys at an exceptional price.
I sent him a PM saying I want to hear Vincent and Emily through one, what can I say I like to torture mics I really like😁
Post by Johnkenn on Sept 3, 2024 18:29:20 GMT -6
Do you have the Heiserman or O.P.R. capsule in yours, Ward? I think the O.P.R. sounds really nice on John's voice, but am concerned about it potentially being a little bass shy. What's your experience? Thanks. Mine has the OPR capsule which is allegedly like an M7 but sounds 50% M7 and 50% K47 to me. That’s probably a very good description. It sounds more like an M7 with a K47 top.
