Post by russellcreekps on Jul 25, 2024 20:29:33 GMT -6
I find when using a tape plug on an acoustic guitar (or electric for that matter) that it puts it slightly out of tune. Is that just a standard thing with tape, or maybe a setting I need to adjust on the plug?
Post by russellcreekps on Jul 25, 2024 20:32:02 GMT -6
Ah I just found this amazing new site called Google that tells you everything! . Seems it’s the wow & flutter settings, my bad. Thought it was odd the acoustics and electrics sounded out of tune with each other…couldn’t sort out why since we tune religiously when tracking.
Post by drumsound on Jul 25, 2024 23:59:25 GMT -6
Listen to piano recordings from the tape era. There's tons of wow and flutter.
Post by thehightenor on Jul 26, 2024 2:26:32 GMT -6
I find when using a tape plug on an acoustic guitar (or electric for that matter) that it puts it slightly out of tune. Is that just a standard thing with tape, or maybe a setting I need to adjust on the plug? Record a sine wave and listen back to the effect the emulation is having on it. Personally, that slight “falling of a cliff” effect of tape echo is something I love on guitars.
Post by frans on Jul 26, 2024 2:38:33 GMT -6
There was a plugin by Celemony (the Melodyne guys) that took the variations in imprinted bias in the tape and then took care of wow + flutter. The name is Capstan. So you could, in theory, put on a tape plugin.. and then - oh, i forgot you'd need a nother plugin to simulate the bias part of the signal...
Post by niklas1073 on Jul 26, 2024 3:27:16 GMT -6
That modulation of the wow and flutter would actually be the reason for me to use the tape plug. Guitars often sound pretty flat without a hunch of modulation blended in. I usually reach for dimension d but a tape will give similar quality to create depth.
Post by svart on Jul 26, 2024 6:15:14 GMT -6
That's why folks wouldn't put critical tracks on the channels that were near the edges of the tape back in the day. The edges of the tape would flap a little more than the rest and give more wow/flutter than the rest of the channels.
That's why Kick always ended up on track 1 or 24 on 2"..
Post by damoongo on Jul 26, 2024 9:49:25 GMT -6
That's why folks wouldn't put critical tracks on the channels that were near the edges of the tape back in the day. The edges of the tape would flap a little more than the rest and give more wow/flutter than the rest of the channels. That's why Kick always ended up on track 1 or 24 on 2".. Wow and flutter are functions of motor and transport fluctuations, and on a well maintained machine will be fairly uniform across all tracks. The edge tracks are more susceptible to damage though…. So yeah, while wow and flutter wouldn’t even have a huge impact on a kick compared to something like piano, with lots of harmonic sustained information, I’d rather put less critical elements on the edge tracks. Around here, hi hat always ends up on track one. (And always sounds best with the fader at -infinity.)
Post by chessparov on Jul 26, 2024 12:46:16 GMT -6
Jackie Wilson and Sam Cooke caused a lot of Wow and Flutter with the Ladies live.
Post by thehightenor on Jul 26, 2024 13:29:37 GMT -6
That's why folks wouldn't put critical tracks on the channels that were near the edges of the tape back in the day. The edges of the tape would flap a little more than the rest and give more wow/flutter than the rest of the channels. That's why Kick always ended up on track 1 or 24 on 2".. You know, it's so long ago since I tracked to 16 or 24 track tape that I'd forgotten all these little idiosyncrasies. Like storing tape tail out because of print through. I always went to the trouble of splicing in red or green leader tape so I knew how the tape was being stored. Ah .... the good old days :-)
Post by svart on Jul 26, 2024 13:45:50 GMT -6
That's why folks wouldn't put critical tracks on the channels that were near the edges of the tape back in the day. The edges of the tape would flap a little more than the rest and give more wow/flutter than the rest of the channels. That's why Kick always ended up on track 1 or 24 on 2".. You know, it's so long ago since I tracked to 16 or 24 track tape that I'd forgotten all these little idiosyncrasies. Like storing tape tail out because of print through. I always went to the trouble of splicing in red or green leader tape so I knew how the tape was being stored. Ah .... the good old days :-) I like the leader tape idea. I've gotten a number of tapes that were not respooled/rewound and otherwise not marked which side was up so when I installed them to play they were backwards. Be kind. Rewind.
Post by thehightenor on Jul 26, 2024 13:49:16 GMT -6
You know, it's so long ago since I tracked to 16 or 24 track tape that I'd forgotten all these little idiosyncrasies. Like storing tape tail out because of print through. I always went to the trouble of splicing in red or green leader tape so I knew how the tape was being stored. Ah .... the good old days :-) I like the leader tape idea. I've gotten a number of tapes that were not respooled/rewound and otherwise not marked which side was up so when I installed them to play they were backwards. Be kind. Rewind. I think it was green for the start of the tape and red for the tail. I was a deft hand at splicing - I could even splice into a drum fill The faster the tape speed the easier the splice as the window was obviously bigger. Non-linear DAW has made me a lazy performer in many ways, with tape you rehearsed way more to keep edits to an absolute minimum!
Post by chessparov on Jul 26, 2024 13:57:56 GMT -6
How many of you guys "dumped" from Reel to Reel... Into Pro Tools, back in the day? Thanks, Chris P.S. The CLASP system was kinda arcane to me.
Post by svart on Jul 26, 2024 14:01:54 GMT -6
That's why folks wouldn't put critical tracks on the channels that were near the edges of the tape back in the day. The edges of the tape would flap a little more than the rest and give more wow/flutter than the rest of the channels. That's why Kick always ended up on track 1 or 24 on 2".. Wow and flutter are functions of motor and transport fluctuations, and on a well maintained machine will be fairly uniform across all tracks. The edge tracks are more susceptible to damage though…. So yeah, while wow and flutter wouldn’t even have a huge impact on a kick compared to something like piano, with lots of harmonic sustained information, I’d rather put less critical elements on the edge tracks. Around here, hi hat always ends up on track one. (And always sounds best with the fader at -infinity.) Also of the tape tensioners.. On the older motors, the speed was not regulated well so the tape tension would bounce and the tensioners would take up the slack, but that springy nature would flap the edges of the tape some. Tape that is too tight tends to curl at the edges as well. Overall, yes, the less critical stuff got put on the outer tracks. Kick on one and maybe SMPTE on the other, or cowbell or something.
Post by svart on Jul 26, 2024 14:04:29 GMT -6
How many of you guys "dumped" from Reel to Reel... Into Pro Tools, back in the day? Thanks, Chris P.S. The CLASP system was kinda arcane to me. I'm a latecomer. I'm doing it today.
Post by Pueblo Audio on Jul 26, 2024 14:49:17 GMT -6
I find when using a tape plug on an acoustic guitar (or electric for that matter) that it puts it slightly out of tune. Is that just a standard thing with tape, or maybe a setting I need to adjust on the plug? Right, but only guitars. Pianos, clarinets and tubular bells should not be affected. Ok, I jest. A tape plug-in is just a PLUG-IN. It’s code, not tape. If some programmer fools around with latency or other alteration of time/speed, it’s the programmer’s intention. But it has nothing to do with real analog recording. If it was, we all could be not stand to listen to all those great 20th century records. Yes?
Post by chessparov on Jul 26, 2024 14:50:55 GMT -6
My 40-4 was a Plug-In. In fact it sometimes made my hair stand on end. Literally. Chris
Post by damoongo on Jul 26, 2024 15:25:48 GMT -6
Overall, yes, the less critical stuff got put on the outer tracks. Kick on one and maybe SMPTE on the other, or cowbell or something. What's more critical than kick?!
Post by damoongo on Jul 26, 2024 15:27:53 GMT -6
You know, it's so long ago since I tracked to 16 or 24 track tape that I'd forgotten all these little idiosyncrasies. Like storing tape tail out because of print through. I always went to the trouble of splicing in red or green leader tape so I knew how the tape was being stored. Ah .... the good old days :-) I like the leader tape idea. I've gotten a number of tapes that were not respooled/rewound and otherwise not marked which side was up so when I installed them to play they were backwards. Be kind. Rewind. Be kind and DON'T rewind. Tails out is the way...
Post by chessparov on Jul 26, 2024 15:42:29 GMT -6
Hey it worked for The Beatles though.
Post by russellcreekps on Jul 26, 2024 18:17:19 GMT -6
Wow, lots of great info here! Basically I was just having some fun experimenting on a mix a few weeks ago, I’ve never really used a tape plug on much more than the 2bus. I realized when coming back to the mix recently that the guitars sounded out of tune with each other…had one tape plug on the acoustic guitar bus and a different one on the electric guitar bus (from my time experimenting). Turned them off and all sounds right again.
Post by damoongo on Jul 26, 2024 18:57:28 GMT -6
Wow, lots of great info here! Basically I was just having some fun experimenting on a mix a few weeks ago, I’ve never really used a tape plug on much more than the 2bus. I realized when coming back to the mix recently that the guitars sounded out of tune with each other…had one tape plug on the acoustic guitar bus and a different one on the electric guitar bus (from my time experimenting). Turned them off and all sounds right again. Maybe try summing both of those busses to another "ALL GTRS" bus. and put it on that one. That would be more like how you'd hear it in the wild...
Post by russellcreekps on Jul 26, 2024 19:14:34 GMT -6
damoongo , good call, will give that a try thx!
Post by jmoose on Jul 26, 2024 19:15:28 GMT -6
Please allow a guy who's owned Studer's and made a bunch of records on analog tape to comment...
In a word? No. Any good real world, well functioning tape machine shouldn't make anything sound "out of tune" or even slightly detuned. If & when we did hear something like that? Sessions stopped until the problem is fixed.
And if / when there was any doubt -- OR -- just doing varispeed tricks -- Standard practice was to record A440 tuning note off a synth... plugged into the nice rack or strobe tuner (we do all have good tuners in the studio yes?!?) - and look at the output of the tape machine to verify that its actually in tune and not wavering.
The vast majority of 'tape plugz' I've tried, including the UAD stuff are almost like cartoon versions of tape machines. We get an exaggerated effect, kinda like kicking on a tube screamer or right... someone said dimension D. Actual tape is much, much more subtle. So subtle we shouldn't notice it much if at all.
Back in the day, and I came up at the very tail end of when making records on tape was the only option... we all busted our balls trying to keep the tape machines as well aligned as possible. Both physical transport & playback electronics would get tweaked & touched up daily. Not much unlike a racecar or a prayer ritual... or some of both really...
The goal was always to have the tape machine output, what's coming off the repro head sound like what was being fed INTO the tape machine input with as little coloration as possible. If there was a big drop, like a 2 or 3dB difference in top end... level... tuning wasn't stable? The machine has a problem. Work stops.
Prime example? Steely Dan. Black Cow. Roger Nichols. That's some of the cleanest, most digital sounding west coast shit we've ever heard and it was 1977 analog tape. Not dirty. Not out of tune. Love it.
Post by patrickp on Jul 26, 2024 19:23:17 GMT -6
damoongo , good call, will give that a try thx! what tape plugin are you using?
