Post by Johnkenn on Aug 3, 2014 6:43:08 GMT -6
And hooooolllly Shiite. I had been noticing thinks were sounding a bit thin and "essy"...and then I could tell the tube(s) were microphonic. I could hit the desk with my hand and hear a spike of distortion. Anyway - I got a replacement tube set (kept my 6386 in) from Phil at Retro and WOW. I didn't realize how sick this puppy was. Before the new tubes, the needle was taking about 30 seconds to get to the zero position on startup. After - like 3 seconds. The compression is absolutely transparent.
The biggest thing I've noticed was on bass. Before, when I would switch to double or triple attack, I would inevitably get a farty sound with bass. Now, the compression is clear as a bell - and huge. So - if that's happening to yours, you should invest in a $100 tube set replacement from Retro. I'm as happy as a little schoolgirl.
Post by cowboycoalminer on Aug 4, 2014 12:58:17 GMT -6
It is happening to mine. I need to re tube again
Post by kcatthedog on Aug 4, 2014 18:05:42 GMT -6
cowboy : didn't you do that like a year ago ? whats up with that?
Post by cowboycoalminer on Aug 4, 2014 18:54:14 GMT -6
I don't know. Thinking of sending my unit to Phil for a check up.
Post by Warhead on Aug 5, 2014 12:24:08 GMT -6
Whoa, sounds like you guys are actually USING these things!
War
Post by matt on Aug 5, 2014 12:32:13 GMT -6
Swapped out the 6V6s when I installed the 6386. Performance improved as a result - less noise, more transparent compression. It's a beautiful thing.
Post by indiehouse on Aug 6, 2014 20:31:43 GMT -6
You know, my Sta takes about 15 seconds or so to get to zero on powerup. I can also tap the front of the case and hear it through the patched channel. Is that right? Do I have a microphonic tube or is that normal?
Post by Johnkenn on Aug 6, 2014 20:39:32 GMT -6
Do you hear a spike of distortion? Buy a re-tube set for $100 from Phil. It's worth trying.
