Post by chambordaudio on Jul 12, 2024 9:42:02 GMT -6
Introducing Version 2 of our TC-500 Compressor for 500 series
![](https://i.postimg.cc/wB7BgDym/temp-Imagez0-Ru-Hq.avif)
![](https://i.postimg.cc/g0Q2Jr8B/temp-Imagectv-CPI.avif)
First designed as the perfect dialogue recording compressor, the TC-500 is one of the best tracking tools available today. With its dual stage of VCA compression, audio sources with high dynamic range can be controlled with ease while maintaining the most transparent sound. The first stage of compression uses an RMS level detector to work on the overall loudness of the material. The attack and release are program dependant and will adapt to the incoming signal with very fast to medium timings. Engaging the slow switch replaces the adaptive detection with fixed slow timings. Perfect for processing drums or bass-heavy material. The second stage of compression employs a Peak level detector to tame loud transients. With a fixed ratio of 2:1, this is no limiter. Hence the term “Peak Attenuator”. It’s smooth sounding with the least amount of artefacts. Easy to use, with fast results, the TC-500 is your new companion for every recording session. Available now at a special intro price of $449 CAD.
For more information, please click here. Best regards, CHAMBORD AUDIO
