Post by bgrotto on Jun 27, 2024 21:28:03 GMT -6
New upgrade gives it three band functionality. Sweet!
Post by sentientsound on Jun 27, 2024 23:33:46 GMT -6
Yes this is just awesome! Hugely useful on vocals and even mastering work.
There's an upward mode too and some workflow tweaks like moving the weighting and harmonic stremgth to the front panel.
The whole Special Filters Bundle series got small updates as well.
Post by antipodesjosh on Jun 28, 2024 0:38:34 GMT -6
Great update, I often use at least two instances!
Post by tasteliketape on Jun 28, 2024 2:12:57 GMT -6
All TDR plugins on sale for eight days .
Post by Dan on Jun 28, 2024 6:34:33 GMT -6
Killer! The best de-esser just got better.
Post by Johnkenn on Jun 28, 2024 11:03:26 GMT -6
New upgrade gives it three band functionality. Sweet! HEWLL YEAH...I was just thinking about that two days ago
Post by copperx on Jun 28, 2024 12:04:44 GMT -6
All TDR plugins on sale for eight days . The filters bundle is a steal! $12.50 per plugin
Post by bossanova on Jun 28, 2024 15:43:59 GMT -6
If you have an account with them, you might qualify for an additional discount from the library page. Mine is 41.
Post by phdamage on Jun 28, 2024 16:51:57 GMT -6
Sick! Just snagged for 41€!
Post by Johnkenn on Jun 28, 2024 18:18:06 GMT -6
So what does Infrasonic, Elliptical and Ultrasonic do in laymen’s terms?
Post by drumsound on Jun 28, 2024 18:59:16 GMT -6
So what does Infrasonic, Elliptical and Ultrasonic do in laymen’s terms? I'd also like to know
Post by Johnkenn on Jun 28, 2024 19:08:52 GMT -6
I read the descriptions, but not sure they’re really relevant for me?
Post by copperx on Jun 28, 2024 19:11:43 GMT -6
So what does Infrasonic, Elliptical and Ultrasonic do in laymen’s terms? Ultrasonic is a specialized low pass filter that removes the extra stuff that distortion generators and compressors leave in the signal that can trigger nasty intermodulation distortion. You use it when you're mixing with higher than 44.1 khz sample rates, after any non-linear process. You can try it in you mix and then hit bypass all so you can verify it's not snake oil (it isn't). Infrasonic is a high pass filter with very nice visualization and extremely sharp slopes. I'm using it on the kick drum today at around 25 Hz to get rid of unneeded low end and from bass at 40 Hz. What's cool is that you can easily switch from minimum to linear phase to minimize phase shift on the high end. Elliptical turns stereo low-end information into mono below the specified frequency. I just used it today on a pair of overheads. The kick was not exactly centered, and the low end was going towards one side. I tried panning the tracks differently but then the snare went off-center. Elliptical made all the low end mono, very neatly solving my problem.
Post by bgrotto on Jun 28, 2024 21:36:34 GMT -6
I read the descriptions, but not sure they’re really relevant for me? High pass, and low pass. The Low Pass (ultra sonic) plug is of limited use, for me at least. But the High Pass plug is kinda magic on mix buss. The harmonic section is key there and does some super cool stuff. I like it in sub mode very much, fwiw. It's a great way to shift LF energy around for fine-tuning translation.
Post by Dan on Jun 28, 2024 22:13:44 GMT -6
I read the descriptions, but not sure they’re really relevant for me? High pass, and low pass. The Low Pass (ultra sonic) plug is of limited use, for me at least. But the High Pass plug is kinda magic on mix buss. The harmonic section is key there and does some super cool stuff. I like it in sub mode very much, fwiw. It's a great way to shift LF energy around for fine-tuning translation. Ultrasonic was made for this gearspace.com/board/mastering-forum/968641-some-thoughts-quot-high-resolution-quot-audio-processing.htmlAnd is useful for cleaning up converted files from converters with inadequate band rejection for the material.
Post by itzprime on Jun 28, 2024 23:46:57 GMT -6
So what does Infrasonic, Elliptical and Ultrasonic do in laymen’s terms? Ultrasonic is a specialized low pass filter that removes the extra stuff that distortion generators and compressors leave in the signal that can trigger nasty intermodulation distortion. You use it when you're mixing with higher than 44.1 khz sample rates, after any non-linear process. You can try it in you mix and then hit bypass all so you can verify it's not snake oil (it isn't). Infrasonic is a high pass filter with very nice visualization and extremely sharp slopes. I'm using it on the kick drum today at around 25 Hz to get rid of unneeded low end and from bass at 40 Hz. What's cool is that you can easily switch from minimum to linear phase to minimize phase shift on the high end. Elliptical turns stereo low-end information into mono below the specified frequency. I just used it today on a pair of overheads. The kick was not exactly centered, and the low end was going towards one side. I tried panning the tracks differently but then the snare went off-center. Elliptical made all the low end mono, very neatly solving my problem. At first I was like, Ultrasonic - that sounds like a load of damn snake oil. So i tried it with a few Waves plugins, as I know their noise can be quite annoying. made a huge difference at 96 kHz
Post by seawell on Jul 2, 2024 9:24:20 GMT -6
I just picked up Arbiter, sounds great! I'm not seeing any multi band options though, is there a secret menu? 😁
Post by Johnkenn on Jul 2, 2024 9:58:01 GMT -6
I just picked up Arbiter, sounds great! I'm not seeing any multi band options though, is there a secret menu? 😁 Double click in a spot
Post by seawell on Jul 2, 2024 10:11:29 GMT -6
I just picked up Arbiter, sounds great! I'm not seeing any multi band options though, is there a secret menu? 😁 Double click in a spot Thank you! I was way overthinking it...shift-click, option-click, command-click LOL.
Post by phantom on Jul 2, 2024 10:27:18 GMT -6
Just got it too.
Is there a way to delete a new EQ point? I know I can deactivate it, but deleting would be "cleaner".
Post by Blackdawg on Jul 2, 2024 14:09:02 GMT -6
Just got it too. Is there a way to delete a new EQ point? I know I can deactivate it, but deleting would be "cleaner". Double click it. If you click the "?" mark in the top right corner it'll do floating pop ups which helps learn controls on all TDR plugins. Or read the manual ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by geoff738 on Jul 2, 2024 14:11:59 GMT -6
I really should pick this up.
And I was doing so well for a while there not buying sw and going for hardware.
Cheers, Geoff
Post by phantom on Jul 2, 2024 20:52:43 GMT -6
Just got it too. Is there a way to delete a new EQ point? I know I can deactivate it, but deleting would be "cleaner". Double click it. If you click the "?" mark in the top right corner it'll do floating pop ups which helps learn controls on all TDR plugins. Or read the manual ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Oh shoot. And I was thinking I was pretty smart to found out by myself that double click was to creat another band. But I've spent some good minutes and tried every combination on the keyboard to delete then and couldn't think of double clicking it again. #facepalm
Post by Blackdawg on Jul 2, 2024 23:35:10 GMT -6
Double click it. If you click the "?" mark in the top right corner it'll do floating pop ups which helps learn controls on all TDR plugins. Or read the manual ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Oh shoot. And I was thinking I was pretty smart to found out by myself that double click was to creat another band. But I've spent some good minutes and tried every combination on the keyboard to delete then and couldn't think of double clicking it again. #facepalm its both clever and not what your used too haha
Post by Dan on Jul 2, 2024 23:49:32 GMT -6
I really should pick this up. And I was doing so well for a while there not buying sw and going for hardware. Cheers, Geoff Dude. It's the best plugin to come out in AGES for solving problems. Since at least when I first used the Sound Radix stuff or Molot GE came out when yes, weird compression was available and fully functional itb even if it was just an updated version of an old, free, weird compressor named hammer in Russian.
For me honestly, Molot GE, Arbiter, and uh Celestion Shaper solve insane problems. Otherwise Izotope. Soothe I guess could solve problems for people using Chinese condensers.
