Post by Johnkenn on Jun 21, 2024 9:11:35 GMT -6
Asking how you personally judge whether and eq is good or not? Obviously, sound…but they’re eq’s. Maybe it’s a given, but if I put on a flat eq and it sounded worse - that’s easy to identify. But sometimes - like comparing say a stam 73 and BAE 73…or really any brands. At some point, shouldn’t all eq sound the same? A -10 db cut at 78hz with a q of 2 or whatever…shouldn’t that be the same sound on every piece? I’ve actually never owned a HW stereo EQ - just because I’ve always thought that was a job for software…any true believers here that think a HW eq (one master or whatever) is a “gamechanger?” (Love that word)
Post by Tbone81 on Jun 21, 2024 9:30:27 GMT -6
HW eqs that use inductors can saturate in a very pleasing way. I think that’s what people like about neve style eqs. For me, when I can boost any frequency and it sounds good, that’s the mark of a really nice eq.
Post by mjheck on Jun 21, 2024 9:40:01 GMT -6
Your point about putting a plug in EQ on the channel and asking of it sounds better or worse immediately? Certainly that. I work in Logic, and have wanted to love the stock EQ but I swear there is a sort of "glossy coating" thing that happens as soon as it is on. Pro Q 2 (and now3) was the first time I put something on and thought it had no negative impact at all. And if I make moves that do seem to have a resonance, I can click through the phase options and typically mitigate that issue.
For hardware - completely different. I had a pair of RND 5033's that sounded fantastic, and experienced that thing people talk about where it was almost impossible to make something sound bad. Those were really great. Any other analog eps I had were part of a channel strip. In those cases, the moves were pretty broad - rolling off lows, removing low mids - that sort of thing. Certainly nor surgical. Except maybe for the API Channel Strip (or Vision Strip or whatever it was called when I had a pair of those). I found that to be an extremely helpful and nice sounding EQ.
Really, my search stopped after Pro Q3. That had the right combination of sound, GUI and options that I just seem to get along with.
Post by svart on Jun 21, 2024 10:12:06 GMT -6
I used to be a true believer, but the years of struggling to hear differences, accidentally leaving them off or switching in the wrong ones and finally struggling to do things like no being able to narrow or widen bands on some eqs has really worn down my beliefs.
Now, EQ is a necessary evil and I generally only use one plug-in for all EQ because the functionality is 95% of the make/break for me.
If I'm leaning on an EQ to give me "tone" then it could probably be done better with something else (saturation) in conjunction with a generic eq.
So I no longer believe there's some inherent magic in some EQs.
Post by Dan on Jun 21, 2024 10:16:08 GMT -6
I pick eq based on the tone. The Slick EQs are better than the fabfilter, weiss, psp, and mdweqs at single sample rates. More immediate. I will pick one based on it. double sampling rate, it's a toss up. Weiss I generally prefer at 88.2 and 96 khz and up but the Slick EQ M is a fabulous broader EQ. Sometimes I will use Oxford EQ for a more digital vibe but at 192 khz, it can null almost perfectly with the Slick EQs. No SVF filter structure stock eq exists outside of ableton (mixed phase anti alias filters) EQ8 and the JS:ReEQ add on in reaper (not updated in a few years). Filterscape and Reaktor are a pain in the ass to use as normal eqs and not synth shit.
Post by matt@IAA on Jun 21, 2024 12:09:57 GMT -6
My opinion:
The EQ sound can be broken down into two: the sound of the unit itself as a unit, and the sound of the curves it can produce as chosen by the designer.
The first contains the usual suspects of any piece of gear - distortion (both good and bad) and noise. Some units sound better than others.
The second takes off into sound as well as efficiency and ease of use.
If you match EQ curve shapes, you'll be left with the unit sound - which can be pretty minimal, depending on the EQ.
I think the gain elements matters a WHOLE lot more than the specifics of the filter (inductor vs RC vs whatever).
My .02.
Post by ericn on Jun 21, 2024 13:23:50 GMT -6
My opinion: The EQ sound can be broken down into two: the sound of the unit itself as a unit, and the sound of the curves it can produce as chosen by the designer. The first contains the usual suspects of any piece of gear - distortion (both good and bad) and noise. Some units sound better than others. The second takes off into sound as well as efficiency and ease of use. If you match EQ curve shapes, you'll be left with the unit sound - which can be pretty minimal, depending on the EQ. I think the gain elements matters a WHOLE lot more than the specifics of the filter (inductor vs RC vs whatever). My .02. Matt is absolutely right it’s curves and tones. I always judge an EQ by the task at hand, what works as a general tone shaper is probably not going to work if I need to notch out a specific frequency and vise versa. Like wise my Lawson Neve Prism clone is a great channel problem solver but if I need to EQ some speakers I’m grabbing either the BSS’s Ashly or TDM, though I did once use an API 560 as a room EQ ( it was the only EQ I had, the room was EQ’ed with a weird curve on a password protected White 4700 digitally controlled Analog EQ)
Post by ab101 on Jun 21, 2024 13:37:02 GMT -6
I have not found a digital eq that works so well on kick and snare as the Iron Age V2.
Post by Johnkenn on Jun 21, 2024 13:52:42 GMT -6
I have not found a digital eq that works so well on kick and snare as the Iron Age V2. Kind of the way I feel about most HW vs. SW. My AS 1178 and the Pulsar are pretty similar…it doesn’t sound exactly alike, but it sounds good…but it’s the attack that never completely attacks like the real one…I can completely shut down a snare on the hardware. Not nearly as much with the plug. I definitely have had the experience of “you can’t make things sound bad” with Helios and Matt’s V2. I wonder if it’s just the broad strokes? I was playing around with the Pulsar Massive Passive and its Q is still wide at the tightest setting…and it’s hard to make shit sound bad…
Post by Dan on Jun 21, 2024 14:49:39 GMT -6
I have not found a digital eq that works so well on kick and snare as the Iron Age V2. Kind of the way I feel about most HW vs. SW. My AS 1178 and the Pulsar are pretty similar…it doesn’t sound exactly alike, but it sounds good…but it’s the attack that never completely attacks like the real one…I can completely shut down a snare on the hardware. Not nearly as much with the plug. I definitely have had the experience of “you can’t make things sound bad” with Helios and Matt’s V2. I wonder if it’s just the broad strokes? I was playing around with the Pulsar Massive Passive and its Q is still wide at the tightest setting…and it’s hard to make shit sound bad… Pulsar 1178 attack is probably internally aliasing horribly even at 8x oversampling at 44.1 kHz because it runs a circuit model that aliases in digital. Mostly why I do not use "emulations" to do anything as tools. The only great one I've heard is the Glue and it still lacks the SSL sound. Softube Chandler Germanium and the weirdo Fuse plugs are cool too but only when they're doing weird stuff. The new Softube FET II almost totally clamps down and reduces the initial peak but it doesn't basically hammer it down like something like the Weiss DS1 and Molot GE (that limiter whoa) can.
The broader eqs often don't let you mess up the audio with weirdo resonances unlike your typical software parametric or surgical hardware. Exceptions being some weird resonant Neve shelves and resonant filters in older EQs.
Post by deaconblues on Jun 21, 2024 15:55:51 GMT -6
I had a similar opinion about hardware eq's and was quite happy with using software, but then I got the Zähl EQ1. Some combination of sound, hands-on controls vs a midi controller or mouse, and instantly better mixes did the trick for me. I think my ears focus more when I use hardware eq's. Results are results. I do a lot of sound design / experimental work and found out how much further a sound can be pushed without screwing it up when using hw. Fast-forward: I got hooked on hardware eq's that allowed for unique curves and had nice (or interesting) box tones -- like the Valley People Maxi Q, IRP Transversal EQ, KT DN27a, Chandler Tone Control, and Massive Passive, and +1 on how great the RND 5033 eq sounds. That one is a desert island piece.
So to answer the original question: the judgment of good or not is purely based on process and results. I enjoy the process and results from hardware for tracking as well as general sound design and mix/master bus. I also enjoy the process and results of software for precise corrective and surgical eq-ing, for example, those Tokyo Dawn Special Filters are absolutely incredible.
Post by vintagelove on Jun 21, 2024 16:31:20 GMT -6
Well, first and foremost I like when an eq does what you think it should. Some eq's like a massive passive, you twist the knob, but don't get what you imagined. A GML... that does what it says on the box. If you're the type that hears a problem and goes I need to take x db off at y k, that's an important thing.
As for sound, I don't like when you can hear the "Q of the boost". Not really an issue in 2 ch high end eq's, but in fixed ones like you find in channel strips... not a fan.
Post by russellcreekps on Jun 21, 2024 17:14:01 GMT -6
I really love my AS Pultecs for a little bump high (okay maybe more than a little) and low on the 2bus, and they really add something to vst’s as well. Always in-line tracking with no eq engaged, just tone. Also on the 2bus, you turn them off and the image reduces, which I guess is better for some mixes but rarely for my lane…it is noticeable btw. So to answer your question…what I look (listen) for in a hw eq is sweet tone and image, I guess it really doesn’t have much to do with the actual eq settings for me, but the pultec does handle boosts in a very elegant way…not harsh at all (like the Axe FM3). kisses! PS. I don’t understand why anyone buys a sterile hardware eq when u could do that itb…but I bet Vance Powell does, and does it for a very good reason! (Not that anything he does is sterile)
Post by drumsound on Jun 21, 2024 23:15:50 GMT -6
Basically, I think "does it do what I expect it to?" Of course I don't know what to expect when I first try an EQ. So, after I've messed around I get a feel for what it does (or doesn't) do. Then I choose which I need where when mixing, and I'm often right (and sometimes VERY wrong ). I only have 2 hardware EQs besides the console EQs. One is an Orban I haven't used in forever, the other is the Beirich03 BAX which I mostly use on mix bus, but it's made its way to some acoustic tracks recently. I have (like all of us) a ton of software EQs and still use the same few most the time.
Post by thehightenor on Jun 22, 2024 5:54:09 GMT -6
Asking how you personally judge whether and eq is good or not? Obviously, sound…but they’re eq’s. Maybe it’s a given, but if I put on a flat eq and it sounded worse - that’s easy to identify. But sometimes - like comparing say a stam 73 and BAE 73…or really any brands. At some point, shouldn’t all eq sound the same? A -10 db cut at 78hz with a q of 2 or whatever…shouldn’t that be the same sound on every piece? I’ve actually never owned a HW stereo EQ - just because I’ve always thought that was a job for software…any true believers here that think a HW eq (one master or whatever) is a “gamechanger?” (Love that word) The Thermionic Swift stereo tube EQ is imho a “game changer” EQ. The sounds and tones it produces cannot ime be reproduced by digital EQ - not even close. It adds a gloss and sheen, size and depth to program material that sounds sonically glorious to my ears. Baxandall shelves Pultec passive inductor mids Magg style Air Band Unique proprietary Presence band. It’s expensive and sounds expensive (as is often the way) to me it defines great analog EQ and is everything digital EQ never is and cannot be. It’s a broad strokes analog EQ. For surgical corrective EQ - I will turn to digital EQ but for the mix bus and stand out channel EQ I want something very musical and special and that where The Swift shines and does its thing.
Post by FM77 on Jun 22, 2024 7:00:54 GMT -6
Alot of variety within active and passive EQs.
Passive EQs, resonant filters, cut only, make up gain later. Boosting when cutting surrounding frequencies. Or precision cuts, Super wide or narrow cuts. Slope, octaves etc.
Cool sounds, cool result? Do I need an adjustable Q setting? Is the cut shape the same as the boost shape? Am I hearing artifacts or phase?
Is a significant 3k boost a musical and pleasant result or does it sound harsh and nasty?
I am with ericn - application/tone/song/ dependent. We have alot of options. But to the fundamental question, at some point, shouldn't they basically sound alike? No, not in my experience.
Post by ericn on Jun 22, 2024 7:45:50 GMT -6
Yeah we also have to look at some other factors. First. What they do “wrong” can be so “right” sometimes the sound you’re looking for isn’t what the boost cut, but the phase shift it introduces. The graphical/ control interface, sometimes seeing the actual cumulative effect of multiple filters is a god send, sometimes our eyes tell us there is no way that curve is a good idea, but our ears tell us otherwise. With say graphics or simple fixed Frq console EQ’s people judge their curves mentally by where the controls are forgetting there is overlap of the filters. Since everyone today as the affordable option of a 1/60th octave RTA or TEF on their phone it’s really easy to look at what the actual curve you have dialed in even on an analog EQ.
Post by robo on Jun 22, 2024 9:09:36 GMT -6
PS. I don’t understand why anyone buys a sterile hardware eq when u could do that itb…but I bet Vance Powell does, and does it for a very good reason! (Not that anything he does is sterile) Because eq before analog compression sounds much better than trying to shape the tone post compression ITB.
Post by FM77 on Jun 22, 2024 9:13:53 GMT -6
PS. I don’t understand why anyone buys a sterile hardware eq when u could do that itb…but I bet Vance Powell does, and does it for a very good reason! (Not that anything he does is sterile) What is an example of a sterile hardware EQ? Alot of variety within active and passive EQs.
Yeah agreed. That's the real-world gist of it. Overlap, interplay, phase, sound quality versus visual perception. I think it is such a useful experience to work with a variety of EQs and tone stacks. This includes guitar amps and bass preamps. So much coolness is happening in the crossover.
Post by FM77 on Jun 22, 2024 9:21:17 GMT -6
@johnkenn - you would like this as a bit of a guitar tone head.
Ya want to see what is happening with classic tone stacks.
Post by popmann on Jun 22, 2024 9:36:45 GMT -6
How quickly and consistently it gets me what I want.
Also that you can offset the output level. I set my EQ to there’s no perceived level loss or gain. I say that because there was a freebie tilt EQ that had a solid sound (and was prior to Fabfilter implementing that) but it had no output level….so I found it functionally unusable.
Mostly these days I use the Harrison 32c except the filters. Plugs come in when I need a HPF (without the LPF that Harrison engages)….ironically, it has no output level-but unless you’re doing something extreme, it’s circuit seems to mostly get close enough.
I have my stereo pair of ASCTs….but, honestly they don’t get patched in as much since acquiring the old BBE box.
Post by Dan on Jun 22, 2024 9:46:57 GMT -6
PS. I don’t understand why anyone buys a sterile hardware eq when u could do that itb…but I bet Vance Powell does, and does it for a very good reason! (Not that anything he does is sterile) What is an example of a sterile hardware EQ? Yeah we also have to look at some other factors. First. What they do “wrong” can be so “right” sometimes the sound you’re looking for isn’t what the boost cut, but the phase shift it introduces. The graphical/ control interface, sometimes seeing the actual cumulative effect of multiple filters is a god send, sometimes our eyes tell us there is no way that curve is a good idea, but our ears tell us otherwise. With say graphics or simple fixed Frq console EQ’s people judge their curves mentally by where the controls are forgetting there is overlap of the filters. Since everyone today as the affordable option of a 1/60th octave RTA or TEF on their phone it’s really easy to look at what the actual curve you have dialed in even on an analog EQ.
Behringer eq, dbx 530, Urei 546, uh current api sounds like pounding nails, neve 1073 clone high shelf and 3.2 kHz boost, a lot of this stuff sucks and just adds noise, removes detail, adds resonance, rings like a bell, or cranking the high shelf adds noticeable distortion and grit.
Post by Dan on Jun 22, 2024 10:04:21 GMT -6
For digital? If it doesn’t suck and does what it’s supposed to. The eqs with numerical errors sound like garbage and you feel you have to do double and then high pass filter them with something cleaner to get the same moves in. The stock daw eqs are fucked up and sound phasey and weird in the high end. The decramped eqs sound normalish but can be a bit hard up on top like Oxford, Renaissance, Pro Q zero latency. The eqs that apply a corrective linear phase warp to the sound to decramp it be normal minimum phase filters sound like mush: Pro Q natural phase mode, Equilibrium, DDMF grand eq, the Kush Q632. They are latent. The ones that upsample are less mushy but the anti alias filters can be audible at lower sampling rates. If they do not do anything non-linear they only need one anti alias filter and not two so less preringing and even less mush. These will always be better in the highs than the previous types mentioned but add latency and cpu cycles. The ones that run state variable filters have better numerical precision and sound better from less distortion near dc. Too bad most utilitarian plugins have not adopted these. They add a couple more cpu cycles but most developers are stuck in the past, copying from textbooks and white papers, or not even bothering to read dsp textbooks and releasing plugins worse than what comes with the daws. Oh and the bilineal transform eqs can all use different filter structures and sound different even if the frequency response is almost perfectly matched. And if the plugins round to 32-bit or have a 24-bit , they will still sound different and cannot even be null-tested so sorry null test bros mostly comparing phase shifts… Dan Good link vladgsound.wordpress.com/2015/01/12/a-classification-of-digital-equalizers-draft/
Post by phantom on Jun 22, 2024 12:02:17 GMT -6
I pick eq based on the tone. The Slick EQs are better than the fabfilter, weiss, psp, and mdweqs at single sample rates. More immediate. I will pick one based on it. double sampling rate, it's a toss up. Weiss I generally prefer at 88.2 and 96 khz and up but the Slick EQ M is a fabulous broader EQ. Sometimes I will use Oxford EQ for a more digital vibe but at 192 khz, it can null almost perfectly with the Slick EQs. No SVF filter structure stock eq exists outside of ableton (mixed phase anti alias filters) EQ8 and the JS:ReEQ add on in reaper (not updated in a few years). Filterscape and Reaktor are a pain in the ass to use as normal eqs and not synth shit. What do you mean by single sample rates and double sampling rate?
Post by russellcreekps on Jun 22, 2024 14:23:56 GMT -6
Behringer eq, dbx 530, Urei 546, uh current api sounds like pounding nails, neve 1073 clone high shelf and 3.2 kHz boost, a lot of this stuff sucks and just adds noise, removes detail, adds resonance, rings like a bell, or cranking the high shelf adds noticeable distortion and grit. I certainly don’t have a lot of experience with outboard eq’s, one I can think of is the 1073DPX stereo channel strip (which I sold), the eq wasn’t bad but it didn’t wow me (neither did the pre for that matter). Assume the vintage ones were much sweeter.
