Post by Johnkenn on Jun 19, 2024 9:48:35 GMT -6
This sounds really good...was just looking for stuff in my mega subscription...about to try.
Post by yewtreemagic on Jun 19, 2024 14:52:34 GMT -6
If you haven't already found them, Dan Worrall has made two recent videos on the Bettermaker BM60 reverb plugin
...and his follow-up when he decides that it uses a convolution engine rather than algorithmic methods:
Post by Johnkenn on Jun 19, 2024 17:28:15 GMT -6
Thought the guy in the first vid said it wasn’t convolution?
Post by Dan on Jun 19, 2024 18:21:12 GMT -6
It’s a convolution. Or maybe an algorithm with a bunch of long irs from the pcm 60. There’s no lex chorusing or modulation but it sounds quite good.
Post by phdamage on Jun 19, 2024 20:31:06 GMT -6
I know some people hate it but I loved my PCM60 and kinda regret selling it. Granted I def have many great verb options these days
Post by drumsound on Jun 19, 2024 21:45:38 GMT -6
It’s a convolution. Or maybe an algorithm with a bunch of long irs from the pcm 60. There’s no lex chorusing or modulation but it sounds quite good. The PCM 60 doesn't have chorusing or modulation
Post by doubledog on Jun 19, 2024 22:05:10 GMT -6
Post by drbill on Jun 19, 2024 22:13:35 GMT -6
IMO, I question "why" they chose this to emulate? The PCM60 was my least favorite Lexicon, and I've owned most of them except the 960L. The PCM60 only got used on the smallest room. Which was pretty good. But not Bricasti room good. Was not sad to see it go.
Post by Quint on Jun 20, 2024 6:11:40 GMT -6
There’s no lex chorusing or modulation But isn't that why you use Lexicon reverbs? Edit: It’s a convolution. Or maybe an algorithm with a bunch of long irs from the pcm 60. There’s no lex chorusing or modulation but it sounds quite good. The PCM 60 doesn't have chorusing or modulation I've never used a 60. I didn't realize that the 60 didn't have chorus or modulation. I see now why maybe some people didn't like the 60.
Post by drumsound on Jun 20, 2024 7:56:59 GMT -6
IMO, I question "why" they chose this to emulate? The PCM60 was my least favorite Lexicon, and I've owned most of them except the 960L. The PCM60 only got used on the smallest room. Which was pretty good. But not Bricasti room good. Was not sad to see it go. Part of it is the simplicity factor. It's pretty easy to compare settings, find one and go. There’s no lex chorusing or modulation But isn't that why you use Lexicon reverbs? Edit: The PCM 60 doesn't have chorusing or modulation I've never used a 60. I didn't realize that the 60 didn't have chorus or modulation. I see now why maybe some people didn't like the 60. It was (I believe) the least expensive Lexicon unit. I think a good amount of them were sold to PA companies and venues.
Post by doubledog on Jun 20, 2024 15:55:50 GMT -6
btw, the WaveAlchemy "Pulse", which is inspired by the PCM60, has both delay and modulation (i.e. flux). I used it on a couple tracks today.
Post by nobtwiddler on Jun 20, 2024 16:00:38 GMT -6
I had 4 of the original PCM -60's and used them exclusively as a verb for my Furman HR-16 Headphone system.
4 x of the 8 stations I had, would have one of these so that, the musician could have their own reverb setting, and full control over it just for them. Four was usually enough, Drummer, Vocalist, Maybe a guitarist, and another just in case.
That's all I could use them for.
Post by nobtwiddler on Jun 20, 2024 16:02:12 GMT -6
4 x of the 8 stations I had, would have one of these so that, the musician could have their own reverb setting, and full control over it just for them. Four was usually enough, Drummer, Vocalist, Maybe a guitarist, and another just in case. Worked great, and was simple enough to use, (self explanatory) so that they got it pretty quickly.
Post by Johnkenn on Jun 20, 2024 16:42:31 GMT -6
Just tried it…probably not gonna use it
Post by ericn on Jun 21, 2024 9:08:48 GMT -6
IMO, I question "why" they chose this to emulate? The PCM60 was my least favorite Lexicon, and I've owned most of them except the 960L. The PCM60 only got used on the smallest room. Which was pretty good. But not Bricasti room good. Was not sad to see it go. Part of it is the simplicity factor. It's pretty easy to compare settings, find one and go. But isn't that why you use Lexicon reverbs? Edit: I've never used a 60. I didn't realize that the 60 didn't have chorus or modulation. I see now why maybe some people didn't like the 60. It was (I believe) the least expensive Lexicon unit. I think a good amount of them were sold to PA companies and venues. Yup the PCM series was the affordable lexicon till the LXP series came out in the late 80’s.
