Post by russellcreekps on May 29, 2024 20:47:22 GMT -6
Admins, could you put the page buttons at the bottom of the page as well as the top? Much easier to click at the bottom of the page (to go to the next) instead of scrolling all the way back up. Thanks!
Post by Ward on May 30, 2024 5:06:22 GMT -6
^^ great suggestion if the pro boards template allows it!
Post by Ward on May 30, 2024 5:07:07 GMT -6
Post by Johnkenn on May 30, 2024 8:17:48 GMT -6
What device are you viewing on? If you go down to the bottom of the page, click on “desktop” and it will show desktop view. Then the page numbers “in theory” float along with you. Unfortunately, this is a Proboards design thing…I’ll ask and see if PNs can be added to the bottom with some setting.
Post by Johnkenn on May 30, 2024 8:24:04 GMT -6
Actually, in mobile view, all of the page numbers are at the bottom. In desktop view, they should be floating along at the top as you scroll.
Post by russellcreekps on May 31, 2024 17:55:23 GMT -6
Actually, in mobile view, all of the page numbers are at the bottom. In desktop view, they should be floating along at the top as you scroll. Ah thanks, probably because I’m on an iPad then. Don’t seem to have the ‘desktop’ option either.
Post by Johnkenn on May 31, 2024 21:10:01 GMT -6
Actually, in mobile view, all of the page numbers are at the bottom. In desktop view, they should be floating along at the top as you scroll. Ah thanks, probably because I’m on an iPad then. Don’t seem to have the ‘desktop’ option either. Yeah - they should be floating for you then.
Post by russellcreekps on Jun 1, 2024 19:28:47 GMT -6
Ahh, there it is….thanks!
