Post by Johnkenn on May 9, 2024 19:15:04 GMT -6
Just pulled up a project in logic and this isn’t the first time I’ve noticed, but the fader meters tell you absolutely nothing. They’re soooo small. And the gain staging is really weird. Like - all my faders are suuuuper low to avoid getting too much gain to the master. It’s just weird.
Post by geoff738 on May 9, 2024 19:27:28 GMT -6
This is in the arrange window?
Cheers, Geoff
Post by kcatthedog on May 9, 2024 19:47:55 GMT -6
There is more than one fader setting, which one do you have?
Have you used the utility Io plug in and the 1k signal to calibrate?
Post by Johnkenn on May 9, 2024 19:58:49 GMT -6
That would be the first time I’ve had to calibrate a daw
Post by the other mark williams on May 9, 2024 20:11:30 GMT -6
That would be the first time I’ve had to calibrate a daw I’ve never had to calibrate Logic in 22 yrs. Sounds like whoever sent you the Project file did something weird with gainstaging
Post by wiz on May 9, 2024 20:13:58 GMT -6
set the metering to pre fader....pull all the plugins off the channels (or bypass them) and what do the meters read on the channels now? That should be the level your tracks were recorded at...
Post by the other mark williams on May 9, 2024 20:20:39 GMT -6
Johnkenn , first make sure you've got the fader metering set how you want it, whether pre-fader or post-fader. (If you right-click in the transport at the top of the page, then click 'Customize Control Bar and Display', you'll see one of the options in the far right column is 'Pre Fader Metering'. Add that to your control bar / transport and you can toggle where the meters are reading from.) I usually use Post Fader metering when mixing, personally. if you're on Post Fader metering and the faders are down super low like how I think you're describing, then my guess is whoever tracked it tracked with their levels too hot. You could bring down the gain on all channels by selecting all the faders in the mixer and inserting a Gain plugin and gain it down there. Or you could select all regions in the Arrange page and go to the Inspector on the top left and gain everything down there. I'm just guessing based on what it sounds like you're saying is going on... EDIT: Peter beat me to the punch on the Pre/Post fader metering...
Post by theshea on May 9, 2024 23:23:32 GMT -6
this is something i only discovered recently but its a time saver if you get tracks to mix from other people: you can normalize ALL tracks with one click. than your fader should sit in the right position. i set the tracks to -10db and i am done. just watch out for stereotracks which were recorded on separate mono tracks. watch this:
and in the mixer on the far left side you can right click on the numbers and choose the meter setting you want.
Post by kcatthedog on May 10, 2024 3:29:08 GMT -6
That would be the first time I’ve had to calibrate a daw I just meant to check what is going on, never had the problem you described, so like Mark said, must be in the session. Was thinking, if you check, then you could let client know, so it doesn’t happen again ?
Post by kcatthedog on May 10, 2024 7:37:17 GMT -6
Post by chipbuttie on May 10, 2024 8:40:43 GMT -6
In project settings, under “ Audio” you can change the pan law , standard is -3 compensated, switching to the -3 (non compensated setting) gives a little extra headroom too!
Post by Ward on May 10, 2024 9:18:33 GMT -6
Sounds as if there's no Logic in their gain-staging
