Post by Shadowk on Apr 28, 2024 12:08:21 GMT -6
Can someone with the Core 59 give be a couple dimensions? I will be standing them up so the tweeter is on top. I need to know the distance from the bottom of the speaker to the midpoint between the midrange driver and the tweeter. That is supposed to be the ear height so I'm try to make some stands so I'm ready when they arrive. Thanks, Mine has the baffle in a horizontal rotation so from the reflex port to the mid tweeter it's a bit longer (41CM). With a bit of guesswork I'd say it's probably going to be around 35 - 36CM when the baffle is rotated for standard verticle positioning. That's because the treble tweeter is on the top in that configuration so the mid range is lower..
Post by mcirish on Apr 28, 2024 12:13:42 GMT -6
Thanks Danny
Post by mcirish on Apr 30, 2024 20:29:06 GMT -6
I got the Core 59 monitors in. The boxes were in pretty bad shape but fortunately the speakers are fine. Yes, they are quite big for my studio but surprisingly, they don't seem too big. I just finished a mix last night that is heading off to mastering. I did it on the LYD48's. As you can see from the Arc Studio corrections, the speaker behave completely differently. The dip between 80-100hz is due to front wall reflection, even though I have 14" of treatment. From all my study, that will never change. The Core 59 has a front port and the LYD 48 has a rear port. I found that made a huge difference in the way the low end sound. I have a lot more test to do and it may take a few weeks to get used to them, but I plan on keeping them. QUESTION: The Input Sensitivity and SPL Level switches interact and I'm not entirely sure I got it right. From my reading, they ssay to set the SPL Level to whatever your normal loudest level will be. They use that to calibrate the DSP, so that's important. I set it to 96dB. I set the Input Sensitivity to +4, as my interface (Lynx Aurora (n)) is +4. The levels seem pretty close to what I'm used to now. Anyone with more experience have a different preference? I will write more after I get a couple days into these. One thing that surprised me is the lowend. It doesn't feel as big as the LYD48 but my table and floor do vibrate a bit with the Core59. Maybe some isolation will help but I think it just naturally has deeper bass and the front port changes everything.
Post by kcatthedog on May 1, 2024 5:26:19 GMT -6
Interesting: enjoy the ride!
Post by doubledog on May 1, 2024 7:32:29 GMT -6
my table and floor do vibrate a bit with the Core59. Maybe some isolation will help but I think it just naturally has deeper bass and the front port changes everything. obviously these are much larger than my BM6a II, but I recently got some acoustic isolators and it helps. I got the Auralex Pro Pod Lite for one pair, and Rab Audio ProJax 40 for another. They seem to work about the same and depending on the weight of your monitors you may need something different, but the biggest difference I noticed is that the vibrations from the speaker do not transfer into where the speakers are located (for me on some desk side racks) . I would definitely recommend trying some. One of these days I'll have to get REW out again. I used to have some "ringing" (shown in some waterfall graphs) and I wonder if these will have helped.
Post by Shadowk on May 1, 2024 8:51:51 GMT -6
QUESTION: The Input Sensitivity and SPL Level switches interact and I'm not entirely sure I got it right. From my reading, they ssay to set the SPL Level to whatever your normal loudest level will be. They use that to calibrate the DSP, so that's important. I set it to 96dB. I set the Input Sensitivity to +4, as my interface (Lynx Aurora (n)) is +4. The levels seem pretty close to what I'm used to now. Anyone with more experience have a different preference? I will write more after I get a couple days into these. One thing that surprised me is the lowend. It doesn't feel as big as the LYD48 but my table and floor do vibrate a bit with the Core59. Maybe some isolation will help but I think it just naturally has deeper bass and the front port changes everything. Congrats, mine are set to 96dB as well although I have experimented. For most part they just get noisier and louder.. As you have sufficient treatment and room correction yours should most likely be setup as anechoic and wall on the DSP settings. I've frittered between anechoic and desk as I fall somewhat into both catagories in the manual..
On the whole bass thing, that's called accuracy. I had a pair of 5 inch speakers that appeared to have more bass than a 12" woofer pair of Geithains with a 30Hz response. I thought that just ain't right is it? The difference is when you go outside the room the top shelf monitors are shaking the house whilst the other is just a bloated LMF mess.
Post by mcirish on May 1, 2024 9:27:02 GMT -6
Danny, I blame you for my loss of money... Just sayin' 😀
Thanks for the help. I reworked my stands and filled them with a mix of pavers sand and pea gravel. Quite dense and heavy. Waiting on a couple coats of paint to dry and I can finally get back to working on music.
Post by Shadowk on May 2, 2024 20:35:12 GMT -6
Danny, I blame you for my loss of money... Just sayin' 😀 Thanks for the help. I reworked my stands and filled them with a mix of pavers sand and pea gravel. Quite dense and heavy. Waiting on a couple coats of paint to dry and I can finally get back to working on music. Just try Tiesto Boom ft.GUCCI MAIN , then you'll say Shadow screw the money.. These monitors are stunning.. For this song skip the correction and just enjoy..
Post by mcirish on May 2, 2024 20:55:40 GMT -6
I'm already thinking that. They sound amazing. You were right that they are kind of like the LYD48, only more of everything. Clearer and bigger. I have a number of test songs but Seals song Loves Devine is great to check vocal center. Woman in Chains by TFF is also great for checking tightness of the low end. I did more sweep tests tonight. They are so close to the top of my work desk/table that I thought if I set it to Desk mode that it might lower the 250 boost. Well, it does do that, but it also messes with 100hz as well and I didn't like that. Instead of a single dip at 80 in anachoic, the desk mode basically notched out 80-250 by a lot. More than 6 dB. So, I set it back to anachoic. It sounds best there.
One last question. On the input sensitivity switch, what do you have yours set for? For me, I get the best usable range from my Dangerous Monitor ST with the input at +4 and the SPL at 96. I'm not entirely sure that's the right way to have it but if I go to +18 input, it is too quiet unless I jack the SPL all the way up to 112,
These are stunning.
Post by drbill on May 2, 2024 22:09:00 GMT -6
I have a number of test songs but Seals song Loves Devine is great to check vocal center. Woman in Chains by TFF is also great for checking tightness of the low end. I like your listening material!!!!
Post by mcirish on May 3, 2024 5:52:20 GMT -6
OK, I figured out the proper input and spl settings for my setup. I updated the Lynx NControl and it has a 20dBU setting. I set the speakers for 24dBU and it was a touch too quiet with my monitor controler almost maxed, so I set the speakers to 18dBU and the SPL to 100. very good now and no worry about distortion at higher levels. The Arc Studio is also in a good range, so I'm all set.
Post by kcatthedog on May 3, 2024 6:12:04 GMT -6
Enjoy your investment!
Post by theshea on May 4, 2024 0:27:23 GMT -6
great. but i would also test the desk. from what it looks like, it could reflect some. i would make a measuring with the desk removed.
Post by mcirish on May 4, 2024 6:58:41 GMT -6
great. but i would also test the desk. from what it looks like, it could reflect some. i would make a measuring with the desk removed. Oh I'm sure the desk is playing a large part in the issue I have in the room, but I have to have a workspace that two people can work at. So for now it has to stay. I did also do a sweep test with all the various positions settings on the speakers. That was interesting to see what each is really doing. In the end, Anachoic, Wall worked best and needed the least correction.
Post by Shadowk on May 4, 2024 8:07:36 GMT -6
I'm already thinking that. They sound amazing. You were right that they are kind of like the LYD48, only more of everything. Clearer and bigger. I have a number of test songs but Seals song Loves Devine is great to check vocal center., These are stunning. I use a various suite of songs for testing, fleetwood’s big love is my main as the attack from the acoustics either translates through or doesn’t on some monitors. Also I’ve never heard a medium it sounds bad on. Tiesto as an example of modern house slamming bass to see how full range, headphone or PA translates. Then a bit if metal I’m familiar with, these really love to poke holes in all of my favourite metal tracks as they’re generally not all that well produced. Then some orchestral tracks and yada, yada songs from most genres. A couple of things I noticed when comparing a recent demo to a production track years back. Due to the crazy phantom centre thing going on I pushed the vox out past the point of comfortable. Also nothing will sound amazing on them because translatable and perfect is an oxymoron. You can’t have completely accurate monitoring without it feeding back all the damage we do to get these to translate to lesser mediums. On reflection adding in that extra lmf and backing off the compression, saturation and limiting made the monitors tell me this is what it sounds like as a relatively undamaged production and I can take it because I’m a super low distortion kick ass monitor but what about everything else? We need to compromise shadow. This is why I couldn’t care less about the HW vs. Plug debate, on certain non compromised playback systems a perfect mix on the Dyn’s will translate no issues. It’s amazing how good certain hybrid chains sound, decent HW in terms of audio quality is way above what’s ever going to reach end production. Even if some plugs are as good or better. This was one of my rationalisations for not upgrading past the core’s, mixing might be the art of smoke and mirrors but it’s mainly about damaging the audio tastefully. It’s sorta depressing enough with the dyn’s I don’t need an even more accurate system telling me how truly borked productions are. This doesn’t just apply to modern songs as well, so many 70’s and 80’s productions were crushed and warped they just didn’t have look ahead dead stop brick walls.
Post by Hudsonic on May 4, 2024 8:22:21 GMT -6
Dynaudio excellent and so useful as a reference. Huddy don't do windows and he don't buy the naysaying here. (nor the 50% discount rumor). As for the distribution in the USA, anyone can buy the Danish monitors any day of the week and receive them in less than a week. Stock is kept in USA for pro users. Bass response of Dynaudio monitors is one of their really strong points and the engineer needs to adjust and treat the listening room to get best results. Call GIK Acoustics to help.
Post by Hudsonic on May 4, 2024 8:23:53 GMT -6
Excellent service from Thomann DE.
Post by sean on May 4, 2024 8:28:49 GMT -6
I personally wouldn't worry about service/distribution with Dynaudio here in the states. I don't think where a company is based should have much barring on whether or not to buy something (except maybe Geithan which has no distribution at all here in the states). I have a pair of Barefoot MM27 MK II that has an amp that's been with them for over 2 months. They are in America. They don't have a spare amp they can send me. They don't have a demo model I can borrow while it gets repaired. 6 to 8 weeks is their turnaround time right now. If it was my only monitor that would be unacceptable in my opinion. And I'm sure when I get the bill for the repair my mouth will be on the floor. And I would consider myself a "pro" user. Maybe if I posted pictures of Grammys on my Instagram or selfies with artist I'd get them back faster...
Post by Shadowk on May 4, 2024 8:47:41 GMT -6
I might not be in the US but I’m not worried at all. They’re over engineered and specc’d. Dyn isn’t a small company, their support is stellar, I asked and they will have parts for a long time should you ever need them. I don’t understand how you could blow a tweeter with these unless you were set on doing so.
I’ll get 10 - 15 years out of them no issues, by then Dyn will have released something new and I’ll end up buying them anyway. 😂
Also I had the Lyd’s six years and they never missed a beat.
Post by kcatthedog on May 4, 2024 8:53:29 GMT -6
I haven’t heard Core, but they idea that they are a big step up from lyd48s, is impressive and intriguing: lucky you guys !
Post by mcirish on May 4, 2024 10:22:56 GMT -6
I'm not worried about repairs on the Dynaudio stuff. I've had Air 6, LYD48 and now Core 59. I did have a problem with the Air 6 many years ago. It was a bad cap in the switching supply. A friend is a true geek and he deengineered the supply and fixed it. At that time, I would have had to ship it away for two months. It's good to have smart friends. In many ways the Core 59 is similar to the LYD48. They have similar sonics. The core 59 is just clearer and tighter and it never feels like the low end is going to blow out at high levels.
My room is the only weak point. But, I have a ton of treatment. I don't really think I can make any substantial improvement at this point. I have 13 GIK 2" panels and 20 other panels ranging from 3" to 12". The room actually sounds very nice with the wood floor and cloud. Not too dead but no odd reflections or flutter. Just being in a smallish (20'x20' partially cut in half) room is going to have some room modes. No way around it. Room correction software is my best friend currently. No guessing. No "learning" the room. When it sounds right, I don't have to wonder if it is OK. Anyway... I have mixes I need to finish now on the Core 59. Check the classifieds if anyone is looking for LYD48s. I'd love to keep them but I'm at the point where I need to sell what doesn't get used every day.
Post by russellcreekps on May 4, 2024 21:07:52 GMT -6
I really like my LYD48’s, the first monitor I’ve not felt any ear fatigue, even after a full day on them. But, I set up the ARC Studio this morning and holy crap the difference is night and day! Made some changes on an old mix for fun and wow, could hear things so much better for mix decisions, and the translation to other listening environments is really on point too! Still my someday wish is for scm45a’s. The Core’s look fantastic as well, congrats and enjoy!
Post by theshea on May 5, 2024 0:26:32 GMT -6
I really like my LYD48’s, the first monitor I’ve not felt any ear fatigue, even after a full day on them. But, I set up the ARC Studio this morning and holy crap the difference is night and day! Made some changes on an old mix for fun and wow, could hear things so much better for mix decisions, and the translation to other listening environments is really on point too! Still my someday wish is for scm45a’s. The Core’s look fantastic as well, congrats and enjoy! tried the old ARC years ago and it changed the sound to much. was like listening to some different speakers. i had focal alpha‘s back than. thats my main worry: i still want to listen to MY speakers, have dyn lyd48 now. i have a dip at 90-100 Hz, apart from that i am used to how they sound in my room and mixes translate well. still curious if the new ARC could improve some 5-10% without giving me the feeling listening to new speaker i would try. can one demo the software only? i have a behringer ECM8000.
Post by russellcreekps on May 5, 2024 16:42:05 GMT -6
Apparently my room is not tuned so well, lol. I can’t even believe how well things are translating for me now, it’s truly a revelation! Sometimes I buy gear and no doubt it’s good, but then once in awhile I buy something that completely blows my mind and changes the whole game for me…this is one of them, along with a couple others I’ve made recently…I’m on a role, but no more money! Hehe
Edited: Sorry, missed your question at the end. Yeah you can demo the software, it’s called ARC4 and I think it’s pretty much the same as using the hardware, I bought the hardware just to have it out of the way and not think about it (no need for another plug on my master).
Post by mcirish on May 8, 2024 6:14:13 GMT -6
My feeling is that if Arc or Sonarworks changes the sound of the speakers too much, then you probably have some bad room modes it is fixing. The LYD48 sounded pretty great without any room correction software but my mixes didn't translate due to the 100hz dip. I treated the room as much as possible. I then started with Sonarworks. The difference was huge and my mixes translated fine then. I wish I could say the Core 59 didn't need any room correction, but I'm still in the same room. The room modes are in some different places due to the size of the speakers and the placement. The room correction software just makes them sound like what they DO sound like in a better room. I can't imagine ever going back to not using it. Heck, even Eric Valentine has to have some EQ in his new mix room and he certainly threw a lot of time and money at perfecting the room. I think room correction software is just a fact of life now. I could never trick my brain into hearing what wasn't there. I'm sure others are better at it than me though.
