Post by kcatthedog on Mar 9, 2024 5:07:42 GMT -6
Thoughts ?
Post by theshea on Mar 10, 2024 0:47:50 GMT -6
i think everyone knows this already and mastering engineers choose loudness to sound good for the songs and not for spotify/yt/etc. data. and yes the loudness war ain‘t over. it just got accepted as is and thanks to metallica‘s death magnetic everyone realized that too much is really too much. thanks metallica!
Lufs
Mar 10, 2024 3:32:16 GMT -6
via mobile
Post by kcatthedog on Mar 10, 2024 3:32:16 GMT -6
It didn’t seem earth shattering, more a teaser for his mastering course ?
Post by niklas1073 on Mar 10, 2024 3:47:13 GMT -6
Yeah I dug pretty deep into this Lufs charade a few years back really trying to understand it in depth. Have tried same mixes with both the -14lufs and full blast on spotify and came to the same conclusion as this dude. I have actually discarded the whole idea of lufs completely. It does not seem to make any difference as I see it, really frustrating actually. Load up your master as loud as it is and it will play just great. Anything at -14lufs will just sound weak on any streaming service have been my experience. I call bs on the whole thing to be honest, wasted too many hours of my life I will never get back trying to make sense of it.
Lufs
Mar 10, 2024 4:12:49 GMT -6
via mobile
Post by kcatthedog on Mar 10, 2024 4:12:49 GMT -6
And he says RMS is basically the same so why LUFs ?
Post by niklas1073 on Mar 10, 2024 8:56:21 GMT -6
And he says RMS is basically the same so why LUFs ? I suppose they are similar to some extent, but then again not, as I understand it rms is average voltage measured under a very short period while lufs is perceived loudness over the entire song. This makes in my mind rms closer to true peak, but with a short delay so to speak. I read rms measures around 300ms. So if you follow both meters during a mix, I'm not sure if they will correlate that much. I understand the aim of the lufs limitation to retain dynamics that loudness wars have in many cases ruined. But then again, a lot of what I listen to is dynamic enough and still plays loud as heck. So it doesn’t really correlate in real world. If a rule might only work if all music is normalized and everyone has to adjust to that we have set an even wider dogmatic rule and limitation to music production than loudness war. Music industry goes communism 🤣. In real life this would only work if we go back to vinyl and cd only, where we adjust our listening per album. As long as there is a button to turn normalization off and even one streaming platform decides to rogue from the -14 lufs dictated norm, the norm turns useless. I don’t remember ever hearing an album on spotify with normalization off that would be mastered to -14. So whom is this ruled actually aimed to?
Post by christopher on Mar 10, 2024 14:15:11 GMT -6
That’s for sharing! Man this is a lifesaver. In the comments of the YouTube video someone said most converters do loopback. Of course! I forgot about that, searched up RME loop back, now the internet streaming can go through my ARC3 room correction. So far so good.
And well I looked at Youtube Olivia Rodrigo Vampire, Weeknd, FooFighters.. seems they all left peaks around -5dB (!) for me. Averages around -14dB. Olivia was showing -20’s to -18 LUFS most of the track.
Made me wonder if my loopback and audio is setup right?
Does YouTube just turn everything down 5dB?
I do know since the change, YouTube ads have been more in-check, no more -2dB RMS ‘you need testosterone!’
Post by bossanova on Mar 10, 2024 21:31:14 GMT -6
I showed the results of a Chris Stapleton song from the album vs the streaming version on YouTube a couple years ago. It was the same mix and master but the YT version was turned down by about -3db if I remember correctly.
Post by niklas1073 on Mar 10, 2024 22:36:56 GMT -6
How does youtube actually work? And youtube vs youtube music? They don’t have a normalization switch right, but I’ve noticed youtube turn down the track some. Read somewhere that if it exceeds -7?dB it turns it down a few notches. That would explain the Stapleton album bossanova was referring to. So yt don’t seem to go by the same principle as spotify or apple.
Lufs
Mar 10, 2024 22:58:35 GMT -6
Post by Dan on Mar 10, 2024 22:58:35 GMT -6
I showed the results of a Chris Stapleton song from the album vs the streaming version on YouTube a couple years ago. It was the same mix and master but the YT version was turned down by about -3db if I remember correctly. And Chris is not even that loud! His records are some of the few hifi popular music productions out there now. Most everything else is ruined by the limiters and sounds pumpy or crappy on monitors or larger speaker systems dr.loudness-war.info/?artist=chris+stapleton&album=
Lufs
Mar 11, 2024 11:11:33 GMT -6
Dan likes this
Post by svart on Mar 11, 2024 11:11:33 GMT -6
And he says RMS is basically the same so why LUFs ? LUFS and RMS are mostly the same in practice. RMS is an arbitrary short duration, and LUFS was supposed to be a running average over a specified period of time. LUFS didn't even work that well because people gamed the system pretty quickly, so they now have LUFS-I (Integrated, the whole song) and LUFS-M (momentary, about 1/2 second) and LUFS-S (short-term, about 3 seconds) which are all different time windows.
Post by svart on Mar 11, 2024 11:13:33 GMT -6
Yeah I dug pretty deep into this Lufs charade a few years back really trying to understand it in depth. Have tried same mixes with both the -14lufs and full blast on spotify and came to the same conclusion as this dude. I have actually discarded the whole idea of lufs completely. It does not seem to make any difference as I see it, really frustrating actually. Load up your master as loud as it is and it will play just great. Anything at -14lufs will just sound weak on any streaming service have been my experience. I call bs on the whole thing to be honest, wasted too many hours of my life I will never get back trying to make sense of it. I aim for around -12 to -10dB RMS for my mixes and don't really have any issues with loudness when comparing to commercial releases.
Lufs
Mar 11, 2024 11:20:38 GMT -6
via mobile
Post by kcatthedog on Mar 11, 2024 11:20:38 GMT -6
And he says RMS is basically the same so why LUFs ? LUFS and RMS are mostly the same in practice. RMS is an arbitrary short duration, and LUFS was supposed to be a running average over a specified period of time. LUFS didn't even work that well because people gamed the system pretty quickly, so they now have LUFS-I (Integrated, the whole song) and LUFS-M (momentary, about 1/2 second) and LUFS-S (short-term, about 3 seconds) which are all different time windows. Sounds ridiculous!
Post by mcirish on Mar 11, 2024 11:34:35 GMT -6
Lately, I've come to the conclusion that it really doesn't matter. Mix and master to make the song sound the best it can. Some songs just naturally need more compression and maybe even a little pumping. Some need to be more open and clear. Whatever sounds best will be fine... as long as it's somewhat louder than the streaming service is set for. For instance, Spotify is going for -14LUFS-I. If the song I uploaded is -10LUFS, Spotify will turn down the whole track by 4dB. That is fine. It will sound the same. I'm just glad no one (to my knowledge) is using a limiter to turn down the tracks. That would alter how the mix sounds, which would be very bad. I believe they run the song through some program that tells them the LUFS-I. From that, they apply a loudness penalty to bring it into the required LUFS.
On a side note, LUFS-I is a pretty horrible way to judge loudness. You can have a song that is 80% around -14dB and then the last 20% can be absolutely slammed at -5dB and the integrated LUFS will still show a moderate level. So, it can get pretty confusing. I think it's pointless to shoot for a specific LUFS. -7 to -10 seems to be working fine for everything I've been involved in for the last few years. It all depends on the style of music and the specific track. Just make it sound how you want it to sound. They will apply a loudness penalty anyway, so stop worrying about it.
Post by EmRR on Mar 11, 2024 13:38:03 GMT -6
This can be interesting www.loudnesspenalty.comI treat it that anything under -14 will definitely sound too low, above some other random number some services apply limiting, some don't, so there's an unintended consequence. At least used to be the case. Acoustic records are easy to make louder than Metallica, without bus processing to get there. Fast rock records are the hardest to make loud and sound good. I put on modern so called rock records all the time that just sound tiny congested and thin, no matter the LUFS. FWIW YMMV.
Lufs
Mar 11, 2024 15:44:33 GMT -6
Post by niklas1073 on Mar 11, 2024 15:44:33 GMT -6
Yeah I dug pretty deep into this Lufs charade a few years back really trying to understand it in depth. Have tried same mixes with both the -14lufs and full blast on spotify and came to the same conclusion as this dude. I have actually discarded the whole idea of lufs completely. It does not seem to make any difference as I see it, really frustrating actually. Load up your master as loud as it is and it will play just great. Anything at -14lufs will just sound weak on any streaming service have been my experience. I call bs on the whole thing to be honest, wasted too many hours of my life I will never get back trying to make sense of it. I aim for around -12 to -10dB RMS for my mixes and don't really have any issues with loudness when comparing to commercial releases. yes, sounds about right in my mind too. I don’t really look at RMS during mixing, only true peak to avoid clipping, but masters I like to see around 8ish RMS, so that would probably leave the mix somewhere around what you are describing.
Post by kcatthedog on Mar 20, 2024 3:42:59 GMT -6
Post by Dan on Mar 20, 2024 7:38:40 GMT -6
This can be interesting www.loudnesspenalty.comI treat it that anything under -14 will definitely sound too low, above some other random number some services apply limiting, some don't, so there's an unintended consequence. At least used to be the case. Acoustic records are easy to make louder than Metallica, without bus processing to get there. Fast rock records are the hardest to make loud and sound good. I put on modern so called rock records all the time that just sound tiny congested and thin, no matter the LUFS. FWIW YMMV. How do you limit a 5150?
Post by EmRR on Mar 20, 2024 10:22:15 GMT -6
It's drums, that's the LIMITING factor.
Post by yewtreemagic on Mar 20, 2024 17:00:07 GMT -6
That's funny - I was reading that article only a few hours ago myself.
Lufs
Mar 20, 2024 18:56:09 GMT -6
via mobile
EmRR likes this
Post by chessparov on Mar 20, 2024 18:56:09 GMT -6
Luf is a many spleen doored thing.
I fooled around and fell in Luf.
Lufs
Mar 20, 2024 18:56:33 GMT -6
via mobile
Dan likes this
Post by chessparov on Mar 20, 2024 18:56:33 GMT -6
This can be interesting www.loudnesspenalty.comI treat it that anything under -14 will definitely sound too low, above some other random number some services apply limiting, some don't, so there's an unintended consequence. At least used to be the case. Acoustic records are easy to make louder than Metallica, without bus processing to get there. Fast rock records are the hardest to make loud and sound good. I put on modern so called rock records all the time that just sound tiny congested and thin, no matter the LUFS. FWIW YMMV. How do you limit a 5150? Carefully.
