Post by kcatthedog on Feb 4, 2024 2:12:27 GMT -6
How do I change the IP address on my Mac mini ?
We have 4 computers in house: 2 macs, 2 windows.
I regularly get a pop up saying another computer is using my iPad address, this prevent UA connect from linking, so can’t get l in net work in mix with UA plugs .
I know how to reset tcp/ip, but this doesn’t fix the problem?
Thx!
Post by Blackdawg on Feb 4, 2024 3:19:13 GMT -6
Post by kcatthedog on Feb 4, 2024 3:22:57 GMT -6
Thx, link takes me to article about email attachments?
Post by Blackdawg on Feb 4, 2024 3:37:47 GMT -6
thats fishy....
works for me.
here:
Setting a Manual IP Address on Mac Launch ‘System Preferences’ from the Apple menu (or Spotlight)
Click on the “Network” icon
In the lower right, click on the ‘Advanced’ button
In the pulldown menu next to “Configure IPv4” select “Manually” (or DHCP with manual address, if that’s what you need)
Fill in the IP address, subnet mask, and router, as appropriate to the network you are accessing
Note: If you do not have these details necessary to be compatible with a specific network, ask the network administrator for the proper assigned IP, subnet, and router to use Tip: Picking your own manual IP address? The key is to pick a manual IP address which does not conflict with existing IP addresses on the joined network. For example, if the network router IP is “192.168.1.1” and the network has 5 computers in total, manually pick an IP far outside the range of those potential computers (which are likely to be 192.168.1.1 through 192.168.1.6, and so forth, as IPs are typically assigned in a sequential order), so a potential IP address could be “192.168.1.75” or some other number which will not conflict or match an existing network resource
Click ‘OK’
Click ‘Apply’ to set the change
If you set a static IP you need tomake sure the subnet is the same so it can be seen still.
That said, idk why you are having issue. I'd check all the machines to make sure they are DHCP which should mean they get assigned an IP from the "server" which should be whatever router/wifi youre using handing out IPs. None should match.
Post by Blackdawg on Feb 4, 2024 3:42:41 GMT -6
Post by svart on Feb 14, 2024 9:23:08 GMT -6
Whatever your gateway is (probably your wifi router) should have no problem assigning unique IP addresses via DHCP. You should never have to set a manual IP on anything.
