Post by audiospecific on Jan 19, 2024 20:27:12 GMT -6
I’m sorry but again I think you’ve got some things mixed up. Resistors have thermal noise that rises with resistance, sure. A 20k resistor at room temp is like -110 dBu or so just from its own self noise. There’s always a noise floor in every circuit. For lowest noise the amp should be coupled with a transformer to the mic that presents the optimum impedance. This is different for different amplifiers. Since BJT have lower impedance than JFET input amps, they have different current and voltage noise, and need different input transformers for lowest noise. That’s why jensen and others make so many different ones. Every circuit has an optimum source impedance for lowest noise. Gapped vs non gapped is just whether or not a transformer can tolerate DC current flowing through its coils. Matching is not better or worse. Matching gives optimum power transfer. In audio we don’t care about power, the voltage is the signal carrying medium. In fact, we want less current to flow, so we can drive higher voltages for a given voltage rail. There is a reason all modern audio devices are bridging. This is for maximum voltage transfer. Matching impedance also has an inherent 6 dB loss, which inevitably raises the noise floor.
I find you being clueless on how all of this suppose to work.
Post by matt@IAA on Jan 19, 2024 20:32:18 GMT -6
Post by ironinthepath on Jan 21, 2024 12:51:34 GMT -6
I’m in alignment, generally, with Matt. At same time, I definitely don’t want to discourage any conversation on DIY circuits or disparage anyone on their way to an improved understanding (especially on RGO). One way to build a “gut feeling” for noise tradeoffs, including impact of the transformer, is to simulate with LTspice. You can do .noise simulations and model your mic’s impedance. To get deeper (and this is the only “professional” way to approach design) you can compare to hand calculations that are only as complicated as necessary to describe what’s seen in SPICE results. It’s also good to question the results because SPICE is as valid as what’s put in: for me, most issues have been “user error “ on my part. So start with a simple resistor and see if the noise floor matches the theory: a 1kOhm resistor should exhibit a noise density of 4 “nV per root Hz”. Solid books/resources on the topic are: Motchenbacher and Fitchen (or the similar book by Motchenbacher and Connelly) Art Kay's book Operational Amplifier Noise, Techniques and Tips for Analyzing and Reducing Noise Bill Whitlock’s chapter: www.jensen-transformers.com/wp-content/uploads/2014/08/Audio-Transformers-Chapter.pdfSee 8-5 of this ADI app note which basically explains choosing optimum turns ratio for best SNR once the input referred voltage noise and input referred current noise generators (modeling opamp’s self noise) and source resistance Rs are known. Of course, with discrete transistors the designer can optimize first the discrete opamp’s noise and then follow up with best chosen transformer: www.analog.com/media/en/training-seminars/design-handbooks/system-applications-guide/Section8.pdfThe design info on the 990 and twin servo preamp also helped me build a better understanding of these topics: www.johnhardyco.com/pdf/990.pdfwww.johnhardyco.com/pdf/TSMP2015-03-01.pdfwww.johnhardyco.com/pdf/M1M2M1p.pdfand Deane Jensen’s original AES paper: www.technicalaudio.com/pdf/Jensen_Transformers/Jensen_OpAmps_990_and_related/Jensen_JE-990_opamp_JAES_reprint_1980.pdf
Post by ironinthepath on Jan 22, 2024 14:57:54 GMT -6
Another related quote from www.jensen-transformers.com/transformers/mic-input/"Transformer selection Turns ratio is generally selected for lowest total noise. Lowest noise will come from matching the “optimum source impedance” of the amplifier to the transformer’s “secondary source impedance” – shown in the table above to the right of the colon under “Impedance Ratio.” The optimum source impedance for any amplifier can be calculated by dividing the amplifier’s voltage noise spectral density in V/ √ Hz , such as 1.2 nV/ √ Hz (1.2 nano-volts per root-Hz) by its current noise spectral density in A/ √ Hz , such as 2 pA/ √ Hz (2 pico-amps per root-Hertz). In this example, using figures for the AD797 low-noise op-amp, the answer is 600 Ω, making our JT-16A with its 600 Ω source impedance the best choice. This matching is not critical and mismatches of ±50% generally make less than 1 dB change in total noise. For vacuum tubes, voltage and current noise numbers are difficult to find. However, when they are available, the calculation will generally indicate an optimum source impedance higher than 15 k Ω. Due to the complex tradeoffs in transformer design, our JT-115K-E is the highest ratio (and secondary source impedance) we can produce and stay within Jensen performance criteria. The JT-115K-E gives outstanding results and we recommend it for all vacuum-tube applications. Special Note for Vacuum Tube Applications If the above calculation is performed for Vacuum Tubes, the value obtained will normally be much higher than the secondary impedance of even our transformer. We do not manufacture Microphone Input Transformers with ratios higher than 1:10 due to the limited bandwidth that is possible in designs of this type. The will work very well in most Vacuum Tube applications."
Post by spacecowboy on Jan 22, 2024 15:36:10 GMT -6
Another related quote from www.jensen-transformers.com/transformers/mic-input/"Transformer selection Turns ratio is generally selected for lowest total noise. Lowest noise will come from matching the “optimum source impedance” of the amplifier to the transformer’s “secondary source impedance” – shown in the table above to the right of the colon under “Impedance Ratio.” The optimum source impedance for any amplifier can be calculated by dividing the amplifier’s voltage noise spectral density in V/ √ Hz , such as 1.2 nV/ √ Hz (1.2 nano-volts per root-Hz) by its current noise spectral density in A/ √ Hz , such as 2 pA/ √ Hz (2 pico-amps per root-Hertz). In this example, using figures for the AD797 low-noise op-amp, the answer is 600 Ω, making our JT-16A with its 600 Ω source impedance the best choice. This matching is not critical and mismatches of ±50% generally make less than 1 dB change in total noise. For vacuum tubes, voltage and current noise numbers are difficult to find. However, when they are available, the calculation will generally indicate an optimum source impedance higher than 15 k Ω. Due to the complex tradeoffs in transformer design, our JT-115K-E is the highest ratio (and secondary source impedance) we can produce and stay within Jensen performance criteria. The JT-115K-E gives outstanding results and we recommend it for all vacuum-tube applications. Special Note for Vacuum Tube Applications If the above calculation is performed for Vacuum Tubes, the value obtained will normally be much higher than the secondary impedance of even our transformer. We do not manufacture Microphone Input Transformers with ratios higher than 1:10 due to the limited bandwidth that is possible in designs of this type. The will work very well in most Vacuum Tube applications." I find you being clueless on how all of this suppose to work.
Post by audiospecific on Jan 26, 2024 10:24:20 GMT -6
Another related quote from www.jensen-transformers.com/transformers/mic-input/"Transformer selection Turns ratio is generally selected for lowest total noise. Lowest noise will come from matching the “optimum source impedance” of the amplifier to the transformer’s “secondary source impedance” – shown in the table above to the right of the colon under “Impedance Ratio.” The optimum source impedance for any amplifier can be calculated by dividing the amplifier’s voltage noise spectral density in V/ √ Hz , such as 1.2 nV/ √ Hz (1.2 nano-volts per root-Hz) by its current noise spectral density in A/ √ Hz , such as 2 pA/ √ Hz (2 pico-amps per root-Hertz). In this example, using figures for the AD797 low-noise op-amp, the answer is 600 Ω, making our JT-16A with its 600 Ω source impedance the best choice. This matching is not critical and mismatches of ±50% generally make less than 1 dB change in total noise. For vacuum tubes, voltage and current noise numbers are difficult to find. However, when they are available, the calculation will generally indicate an optimum source impedance higher than 15 k Ω. Due to the complex tradeoffs in transformer design, our JT-115K-E is the highest ratio (and secondary source impedance) we can produce and stay within Jensen performance criteria. The JT-115K-E gives outstanding results and we recommend it for all vacuum-tube applications. Special Note for Vacuum Tube Applications If the above calculation is performed for Vacuum Tubes, the value obtained will normally be much higher than the secondary impedance of even our transformer. We do not manufacture Microphone Input Transformers with ratios higher than 1:10 due to the limited bandwidth that is possible in designs of this type. The will work very well in most Vacuum Tube applications." I find you being clueless on how all of this suppose to work. He just has a different point of view. Granted, it looks like he copy and pasted that from a Jensen transformer website. Technically, since everything is mid impedance now (2K-47K) , the 600 ohm and lower transformer impedances are an outdated convention and should go into obsolescence.
Post by ironinthepath on Jan 26, 2024 13:49:05 GMT -6
Yes, it would make sense that Jensen Transformers is misinformed about how to best select transformers for an application using their transformers (kidding).
In case we are having some communication error, to clarify, the quote from Jensen above is regarding the use of a transformer on the input side, to interface between the (typically low-impedance, i.e. 150 ohms) mic and the preamplifier circuitry.
When "looking back" into the output of the input-transformer we want to "see" the most optimum resistance possible to keep noise floor to a minimum (best case being the noise floor of the ~150Ohm thermal noise generator of the mic if preamp were ideal, we can only make it worse in practice). The goal of the transformer selection method above is to minimize the impact of the added noise from practical preamp circuitry since the SNR can't get any better that what the mic exhibits.
I think the whole conversation got turned upside down because a transformer (apparently) designed for duties on the input side was being considered for duties on the output side --> it's of course possible to do this, but it wasn't optimized for that role (larger signal levels more likely to result in distortion, etc.).
Post by stratboy on Jan 26, 2024 20:18:15 GMT -6
Kudos, ironinthepath, for your patience and calm. Same to you, Matt.
Post by matt@IAA on Jan 26, 2024 22:15:16 GMT -6
Transformer input or output rating has nothing to do with the actual impedance it presents to the adjacent device in the chain.
Post by Johnkenn on Jan 27, 2024 0:40:45 GMT -6
No more name-calling.
Post by ironinthepath on Jan 27, 2024 5:57:01 GMT -6
Transformer input or output rating has nothing to do with the actual impedance it presents to the adjacent device in the chain. Agreed. If transformer is ideal (ignoring core loss, saturation, etc.), I think this is referred to as “load reflection rule”, which goes in both directions since transformer itself is completely passive and has no knowledge of input vs. output (designation of primary vs. secondary can be reversed if we simply apply our “input” from one side or the other): hyperphysics.phy-astr.gsu.edu/hbase/magnetic/refload.html(This was also covered in some of the resources I listed in a post above, i.e. Bill Whitlock’s book chapter)
Post by audiospecific on Jan 27, 2024 9:34:39 GMT -6
Correct. if you stay within the levels of operation, the transformer doesn't care where it is. Because I have used that output transformer as a line input transformer and vise-versa without issues. I don't see why not the isolation transformer would not work. because its just another 1:1 but with more turns which should be a better load for the DOA op amp in an API output stage. I'm surprised no one got rid of the transformer, and have a unit with three DOAs in it, one for the mic pre and two arranged in an electrically balanced output circuit or use the typical NE5532 arrangement.
Selection of transformer for me starts with its DC parameters, then I look at AC loading effects like you described or copy and pasted from Jensen's website. But you only really touched on input and not output. On the output circuits, I either look at the datasheet of the op amp or plot it myself, the graph called: " distortion at load impedance ". I fallow that instead of an i/o convention. I don't care if the op amp can handle a 200 ohm load. Especially when its lowest distortion output in its chart says a 2K load renders the lowest distortion rating and set the circuit design to a 2K output.
Post by matt@IAA on Jan 27, 2024 11:17:54 GMT -6
Transformers are designed to go between certain source and load impedances. An input transformer is expecting to be fed from a certain source impedance and be loaded by a certain load. The turns ratio is only a part of the transformer design. Total inductance and the expected load play a role as well.
For starters, if you look at the JT-11P datasheet it shows the typical source impedance is 14k. An op amp has near-zero output impedance. And, in a 14k source impedance to 10k output, it has a 3 dB loss. If you look at an output transformer like a JT-123 set up for 1:1 the expected input impedance is ~700 ohms, and for the rated maximum output level the input impedance Rs is zero ohms - exactly what you would expect for a transformer being fed directly from an amplifier output. The 11P is also designed for very high common mode rejection, because it is designed for a different purpose than output transformer. Even worse, maybe the real problem, is that if you use an 11P as an output transformer you're presenting a source impedance to the next device of 3.2k ohms. If you use a 123 in 1:1 your source impedance is only 112 ohms. What that translates to is a loss of signal level as you go from less bridging to more matching configuration, as well as potential high end loss due to cable capacitance. And, if we're talking about noise - a higher impedance circuit will have more noise in and of itself.
All that adds up to - wrong tool for the job, and you'll end up paying twice or three times as much for worse performance.
Jensen knows what they're doing. There is a reason they have different transformers for output and input duties.
If you want to pick an output transformer you need to consider
- the current drive capacity and maximum voltage output level of your driving amplifier - the source impedance of your driving amplifier - the range of loads expected for the transformer
From there, you have a box to pick from.
For example if you're designing a 312 style preamp with a beefy 2520 output, you have a maximum of 60 mA current capacity into 75 ohms and 20 dBu output voltage from your op amp. Your transformer source impedance is near zero, and you should expect a load range anywhere from 600 ohms to >10k ohms. We have gobs of current drive so we can consider 1:2 or even 1:3 output. That changes our load range minimum from 600 ohms to potentially 150 or even 67 ohms. (Aside - when you add the DC resistance of the transformer windings, you'll get a minimum load from a 1:3 step up driving a 600 ohm load to around 75 ohms - not coincidence that API puts the 75 ohm load capacity on the 2520 datasheet). Since we can handle the current required for step up, going 1:2 gets us a 'free' 6 dB of gain, increasing our maximum output voltage to 26 dBu. A quadrifilar output transformer gives the designer the freedom to select ratios from the same windings (1:1, 1:2, 1//1:2, 2:2, 1:3), which gives a range of inductance and load to match different driver and load scenarios.
Transformer windings have their own imperfections, and as you load them there will be losses and frequency response distortions. A transformer rated for 600 ohms will usually have a bit more high end when loaded with 10k and a bit higher than nominal voltage gain. This is why you'll often see a load resistor selected, to narrow the effective operating range to minimize the potential difference in performance when you plug a different device in on the other side of the chain.
A transformer's DC parameters are very nearly irrelevant in audio. Yes, their DCR is added to the impedances, but in most cases they're negligible compared to the impedance of the circuit. Transformers are fundamentally AC devices. They exist to transform AC signals.
You're not wrong to examine the distortion curve at rated output into different loads. Most IC op amps cannot happily drive a 600 ohm load, though 2520 style DOA will do it all day (API 2520 datasheet says 0.2% THD 20-20kHz at rated output, meaning 20 dBu into 75 ohms!). However, the transformer does not present the load to the op amp! It only reflects the load, through its turns ratio plus its own DCR / impedance, back to the driver.
Post by audiospecific on Jan 28, 2024 11:49:49 GMT -6
Transformers are designed to go between certain source and load impedances. An input transformer is expecting to be fed from a certain source impedance and be loaded by a certain load. The turns ratio is only a part of the transformer design. Total inductance and the expected load play a role as well. What that translates to is a loss of signal level as you go from less bridging to more matching configuration, as well as potential high end loss due to cable capacitance.
I was trying to figure out your confusion with transformers when they are used as a coupling device rather than a matching device.
Coupling transformers are a source point that seeks a destination load, as its circuit function is to establish a balanced transmission line that is loaded on the end of the transmission line to achieve differential, or common mode rejection mode. When the next device is a transformer, a resistor the size of the working transmission line impedance is used. Some input circuits have to be fed a pre terminated run instead of terminating at the input but this is a use case scenario where there is no resistance across the input. Since most things are capacitor coupled, most are terminating across the input resistance, which is the coupling capacitor's Xc plus the input resistance of the circuit. Since this load is an AC load, it incorporates the coupling capacitor's Xc in series to the input circuit resistance.
Bridging transformer is different as its not design to set up a transmission line, rather to adapt a signal into a certain set of signal parameters. Like a DI or the transformer in a dynamic mic.
Everyone has moved away from 600 ohm i/o a long time ago. So its very subjective to why even use that or the 250 ohm line convention anymore. Capacitance in a 10K balanced cable run in a rack is insignificant, and that standard has been adopted know for the past 20 years without anyone complaining about it.
A transformer could be used for an input or an output. Providing it meets correct signal level requirements.
Post by matt@IAA on Jan 28, 2024 15:22:04 GMT -6
It may be helpful here to return to first principles - what is a transformer. An ideal transformer has no impedance of its own. There is no leakage between the two coils - so no parallel capacitance etc. No core loss, and infinite permeability, and perfect coupling between the primary and secondary coils. If you hook an ideal transformer up to a circuit, the driver will see ONLY the load reflected by the square of the turns ratio. That is to say, a 1:1 transformer will present ONLY the load to the driver, and ONLY the source impedance to the next device. A 1:2 will present the load impedance divided by four, and the source impedance times four, and so on.
Transformers are always AC coupling devices, as they by definition do not pass DC. So all transformers are "coupling" transformers. And, likewise, all transformers are at least potentially impedance changing devices.
You are correct that transformers can also balance a line - but you don't need them to get common mode rejection. You can simply use a single-ended circuit with identical impedances on both lines for the same purpose. Transformers just happen to accomplish this along with presenting an inverted version of the signal on the low side. What does the "rejecting" is the receiving device, not the sending - by summing the two signals after inverting one. Op amps can do this, and so can transformers.
I don't really know what you're trying to describe in your coupling transformer paragraph, but I must admit it seems more than a little confused. In the end, the entire impedance of the load - whether from a resistor termination or series capacitors or parallel capacitors or inductance (ie from a cable) - can be rewritten as a single terminating impedance across the transformer windings, and if necessary a second impedance to ground. Transformers are designed for a certain terminating impedance; this is the "rating". So a transformer designed for 600 ohm loading is designed for a 600 ohm impedance within the specified bandwidth, regardless of what makes up that impedance (capacitance, resistance, and inductance can all factor in).
Saying a transformer can be used for input and output is like saying you can use any piece of glass for a door or car windshield or a window. It's technically true, but results may vary. Best to use the right tool for the job.
For optimum noise you need to present the correct source impedance to a circuit. This, along with clean gain, is the purpose of a mic input transformer - it increases the source impedance from the microphone to present the correct source impedance to the amplifier, which minimizes noise.
For optimum voltage transfer you use bridging impedance, which is used in ALL modern audio devices. Therefore you ALWAYS want to keep your output impedance as low as possible, and at a minimum 1/10 the amount of your input impedance.
XLR cables can have capacitances as high as 120 pF per foot. Even a modest 12 ft run with a 3k ohm source impedance would result in a -3 dB point of 36 kHz. Audible? Probably not. Degrading the bandwidth of the system? Absolutely. Never mind that a 3k source impedance into a 10k load also carries a -2.25 dB level penalty.
Post by ironinthepath on Jan 29, 2024 11:37:58 GMT -6
"....a -3 dB point of 36 kHz.... " --> and for the purists out there, even with the simplest low-pass filter approximation (first order) the phase starts to change appreciably a decade earlier (3.6kHz). Just agreeing about goal of low output-impedance. EDIT: reminds of some of the Rupert Neve interviews I've seen/read --> www.audiotechnology.com/features/interview/rupert-neve-interview-part-2"RN: That’s right. The RCMA (Remote Controlled Mic Amplifier, I believe, from Amek days) has a 200kHz basic bandwidth – like my other designs – but the resultant response is a function of cable length." "Most present day studio equipment, which doesn’t use output transformers, usually has some poor little IC chip trying to drive that impedance. The manufacturers will say it can drive full output into 10,000 ohms, or 1000 ohms, or even 600 ohms. That’s all right on a test bench where you have no more than a foot or two of cable. But when you try driving a long cable, the chips fall flat on their faces. They go into wild slew rate distortion. They are not designed to drive low impedances between 75 and 100 ohms, which is what you’re now asking them to do. So on the output stages of my equipment, I use transformers with quite beefy power amplifiers to drive the line. [2] I have done this for many many years." To my understanding, this is all fundamentally in agreement with Matt's points above.
Post by audiospecific on Feb 1, 2024 1:49:49 GMT -6
Op amps are current out devices and the difference between load impedance is higher voltage with higher impedance. Since the current is less, and the voltage is greater, there is less loss in the wire. Due to the wire's current limitations by length. Btw, "the function of the cable length" refers to operational impedance as its circuit function.
Post by spacecowboy on Feb 1, 2024 8:14:20 GMT -6
more gibberish. losses arent a function of a single impedance, its the ratio of the source and load impedance. "function of cable length" means the longer the cable, the more the response changes.... because cables have parasitic capacitance per unit lenght.
at this point youve argued with 3 different engineers - one who does RF design, one who does IC design, and one who does audio product design specifically. you think youd get it after the fourth or fifth time.
Post by ironinthepath on Feb 1, 2024 9:40:59 GMT -6
"Op amps are current out devices" - I fundamentally disagree with this based on EE convention. An "ideal opamp" (operational amplifier) is typically designed and configured (via feedback connections) to have high (ideally infinite) input resistance (drawing zero current ideally) and low (ideally zero) output resistance --> thus it can ideally drive any load current necessary while FORCING the output voltage at its output. It's a voltage output device because it's forcing a voltage at the point where the feedback connection is applied (sometimes called the "Kelvin connection", but this term has another similar meaning in the field). So it's a voltage input, voltage output device.
Even before feedback is applied, with the ideal opamp, the output voltage is always expressed as a voltage equal to the product of the differential input voltage (Vin+ - Vin-) and an ideally large scale factor (the "open-loop gain"). When designing actual opamps we try to mimic this behavior with exceedingly high open-loop gain (at least at DC) and by including an output stage often with inherantly low output resistance before we even apply feedback (with "rail-to-rail" opamps often being an exception). So, Opamp = voltage output device.
Also in EE convention we have something called an ideal OTA (operational transconductance amplifier) which has a similar high input resistance but simultaneously has HIGH output resistance and it forces a current at it's output, so in this case the voltage at the output can take on whatever value but it's the current that is being forced by the conceptual device. This is a voltage input, current output device.
An opamp with appropriate choice/connection of feedback elements can be configured to mimic an OTA in practice - see the Howland current pump or opamp "V-to-I converter" (voltage-to-current converter) using a FET or BJT.
We can also configure an opamp to mimic a "current amplifier" (current input, current output device) or even a "transimpedance amplifier" (current input, voltage output device). This has to do with the nature of feedback connections having the ability to modify both input and output impedances.
In practice, with finite input resistance and non-zero output resistance none of these conceptual devices exist perfectly, but of the four I think the opamp acting as a voltage in, voltage out device might be the easiest / most natural concept to apply based on behavior of most commercial IC opamps in the non-inverting feedback configuration.
Johan Huijsing's book on Operational Amplifiers is probably one of the best resources to understand these details, especially his chapter on Macro models.
Post by audiospecific on Feb 1, 2024 9:48:09 GMT -6
more gibberish. losses arent a function of a single impedance, its the ratio of the source and load impedance. "function of cable length" means the longer the cable, the more the response changes.... because cables have parasitic capacitance per unit lenght. at this point youve argued with 3 different engineers - one who does RF design, one who does IC design, and one who does audio product design specifically. you think youd get it after the fourth or fifth time.
Because all of this is based on a theory and not an electronic law, that most have ignored in the industry. As a result, two other impedance conventions are implemented in balanced audio equipment. Its more accurate to say 'load seeking' and 'source seeking' than a set impedance. Set impedance only happens when both units are transformer coupled, and you would power match the connection by impedance and terminate the connection on the destination device.
Mid impedance wire loss is insignificant to the bandwidth gain and lower operating distortion. Hence, that is why the low ohm transmission line theory has been debunked as a studio interconnect. Because it is not a transmission line especially when its less than 500 feet. Which you will always have significantly less cable than 500 feet connecting a mic pre to a compressor in a rack.
People moved away from that transmission line convention long ago. I imagine someone probably have said something about it, but was discounted as someone who doesn't know what they are talking about.
Post by ironinthepath on Feb 1, 2024 10:31:19 GMT -6
I think to address this we need to move to Maxwell's equations, asap!
Post by matt@IAA on Feb 1, 2024 10:57:17 GMT -6
Post by audiospecific on Feb 1, 2024 11:01:47 GMT -6
You still don't get it . That people moved away from that a long time ago. And just because I say to this doesn't change anything other than your perception of what is going on. You can easily ignore it like people have for the past 20 years.
