Post by gravesnumber9 on Jan 8, 2024 16:32:13 GMT -6
Linking to my post in the other section to keep this organized but I got no replies over there. I'm driving an hour tomorrow to check out this Gemini VI that's being sold for $400. I've never actually played one of these but heard great things. Would love to hear from folks who know the amp. Reply here if you'd be so kind! realgearonline.com/thread/16564/eying-gemini-weber-neo-thoughts
Post by nick8801 on Jan 8, 2024 16:42:49 GMT -6
Used to have one! It was phenomenal. Big, warm, all the buzz words. That’s a great price!
Post by gravesnumber9 on Jan 9, 2024 18:21:33 GMT -6
So yeah... obviously I bought the amp. Let's be real, nobody is driving an hour out to the country with $400 cash in hand to NOT buy the amp they're checking out.
But it did sound great. The echo and tremelo worth the price of admission alone. I was a bit surprised at how easily it broke up (pretty much anything past 12 o'clock) but the break up sounded good and the clean sounds sounded fantastic. If I was looking for a stage amp though I would have passed on this one. It really doesn't get all that loud before it starts getting more driven than I like to get.
Overall though? Hell yeah. Considering a Strymon pedal costs the same as this baby, I'll happily set this up for re-amping and effects patching.
Post by gosart on Jan 12, 2024 13:13:52 GMT -6
If you haven't found it yet there's a very cool hidden feature on the tremolos of these 60s blue-tolex Ampegs. Turn the intensity knob all they way up then turn a little harder and you'll feel a switch click. It changes the tremolo from sine wave to square. I had my Reverberocket for many years before I found this by accident one day, the only hint that it's there is the little star printed on the faceplate to the right of "TREMOLO."
Post by gravesnumber9 on Jan 12, 2024 13:16:59 GMT -6
If you haven't found it yet there's a very cool hidden feature on the tremolos of these 60s blue-tolex Ampegs. Turn the intensity knob all they way up then turn a little harder and you'll feel a switch click. It changes the tremolo from sine wave to square. I had my Reverberocket for many years before I found this by accident one day, the only hint that it's there is the little star printed on the faceplate to the right of "TREMOLO." Whoa, cool! Yes mine has that. Thanks man!
beyer160
On Location
Post by beyer160 on Jan 13, 2024 10:49:04 GMT -6
I have an early '67 Gemini II (last of the handwired Ampegs), which I believe is basically the same amp except it has two channels instead of one.
These are Jazz amps. You can crank them up and clip them, but it doesn't sound as cool as doing it on a Fender.
If you haven't already addressed this, take it to a tech for a checkup. The good/bad thing about '60s Ampegs is that they were made so well that it's possible your amp still has the factory caps. This is bad because those are time bombs waiting to go off sooner than later. When I bought mine it was working OK, but I discovered I was the first person to crack the chassis open in 47 years.
This is when you'll discover that 7199 PI tubes are scarce and no one makes a modern replacement. Fortunately, the 6U8A is a functional equivalent and can still be found at reasonable prices. I bought four, enough for the rest of my life and well into the life of the next owner. You'll need to rewire the socket or use a converter- since it's unlikely I'll ever use 7199s in it again I rewired the socket in mine.
I went with Tung-Sol 7591s after trying JJs and inadvertently blowing one up (my fault). The JJs were good, but the Tung Sol had a clearer top end.
I ended up with a WGS G15C speaker in mine, it gave the amp a little firmer bottom and more snap on top. A lot of folks recommend the Eminence Big Ben for that amp, but I never liked it in this or my Traynor YBA4 because it sounded dull.
Post by mattbroiler on Jan 13, 2024 13:00:42 GMT -6
slightly off topic - I had a brand new (bad) JJ EL34 power tube fry one of my MUsicMan amps the repair tech said they won't use JJ tubes any more due to inconsistent quality and he recommended TungSol
obviously I don't know the circumstances but that may not have been your fault after all
I'm happy with TungSol or EHX or the new Mullard reissues (made in Russia not NOS) for guitar amps ymmv
beyer160
On Location
Post by beyer160 on Jan 13, 2024 13:28:26 GMT -6
slightly off topic - I had a brand new (bad) JJ EL34 power tube fry one of my MUsicMan amps the repair tech said they won't use JJ tubes any more due to inconsistent quality and he recommended TungSol obviously I don't know the circumstances but that may not have been your fault after all I'm happy with TungSol or EHX or the new Mullard reissues (made in Russia not NOS) for guitar amps ymmv Thanks, but actually it was the first amp I ever worked on and I screwed up setting the bias and fried the tube. Around that time I brought my Ampeg VT22 in to my amp guy for service, and he recommended JJs as the sturdiest (then) current production tube. That was a decade ago, though. I've had generally good luck with JJs over the years, but I did end up preferring the Tung-Sols in the Gemini. I like the T-S 12ax7s a lot, too.
