Louder Than Liftoff Pulse Delay Module - Re-Launch
Dec 19, 2023 16:42:05 GMT -6
Johnkenn, kcatthedog, and 5 more like this
Post by ResistanceAudio on Dec 19, 2023 16:42:05 GMT -6
Hi folks! Due to popular demand, we're re-launching the Louder Than Liftoff 'Pulse' colour module in collaboration with LTL. This is a super cool delay unit for the colour format, and they've been unavailable for the last several years.
These are exactly the same design and components as the most recent revision 'Rev 1' so they'll match most existing units perfectly. (check under your PCB for the revision number).
We've made these available as DIY kits or completed modules, built in house by Resistance Audio.
They're available here at ResistanceAudio.com
Still time for stocking stuffers
Side note, this is Matt (mdmitch2 on this forum), also of Heiserman Audio. I'll be occasionally posting under the Resistance Audio username for some new product releases this year.
Here's the description from the website:
"We absolutely love the way that real analog tape echo and slapback can add depth and dimension to a vocal or guitar track. A subtle dose can integrate a dry source into the space of the mix like nothing else. We use this simple effect so much that we knew we had to capture the sound of our trusty Otari 1/4" 2-track echo deck and miniaturize all those motors and tape heads for the Colour format." - Brad McGowan, LTL
If you push hard Pulse pushes back with saturated grit, enhancing the texture of the echo. By means of an internal jumper you can choose to set up Pulse as an insert or send effect. Onboard trimpots give you control over Echo Time and Repeats. An Echo Mix trimpot controls the mix of echo summed with the dry signal when used as an insert effect. In 'Wet' mode the dry signal is disabled and the output is 100% wet for use as a send effect. Did we mention? We also tweaked the frequency contour so it sits in the mix perfectly every time.
Circuit emulates LTL studio's echo 2-track deck
Input saturation (selectable via jumper)
Ear-tuned frequency response
Adjustable Echo Time, Repeats, and Mix via internal trimpots
Uses PT2399 delay IC
Compatible with DIYRE Colour
Analog plugin compatible with LTL Chroma and Mister Focus
C-DRV knob on Chroma controls amount of input saturation
C-MIX knob on Chroma controls level of delayed signal blended with dry signal
