Post by RealNoob on Dec 2, 2023 12:55:02 GMT -6
Hi, I am using the Big Six with PT/SO/etc.
When I look at routing in PT I/O, I see all 16 channels out. If I click on routing on mains or a buss, I only see:
Main Out LR - A1/2 Ref - A3/4 Print Out - A5/6 Nexus Out - A1/2
Why don't I see the B6 here and how do I fix it? Thanks!
Post by drumsound on Dec 2, 2023 12:59:14 GMT -6
You probably need to go into the I/O setting window. You might need to make a new I/O 'preset' if you want to tailor it to something unique.
Post by RealNoob on Dec 2, 2023 13:48:14 GMT -6
When I look in I/O, it is all correct. I see all ins and outs labeled and available.
When I try to use them - routing a bus to an analog out, the available choices are not the same. I don't know why they don't match.
Post by notneeson on Dec 2, 2023 14:13:57 GMT -6
When I look in I/O, it is all correct. I see all ins and outs labeled and available. When I try to use them - routing a bus to an analog out, the available choices are not the same. I don't know why they don't match. Often it’s because of slightly different names, like you have to map Analog 1-2 to A1 A2 or whatever, depending on how the busses are named.
Post by jaba on Dec 2, 2023 14:47:45 GMT -6
Is there a possible feedback loop that it's forcing you to avoid?
Post by notneeson on Dec 2, 2023 14:48:44 GMT -6
Is there a possible feedback loop that it's forcing you to avoid? PT does that?
Post by Darren Boling on Dec 2, 2023 14:50:10 GMT -6
Have you checked in the I/O bus tab to make sure they're going where you want?
Post by RealNoob on Dec 2, 2023 15:26:13 GMT -6
Deleted all in I/O and rebuilt. Again, seen clearly there but doesn't show when I try to route any track to outboard.
Post by bentley on Dec 2, 2023 15:47:38 GMT -6
Deleted all in I/O and rebuilt. Again, seen clearly there but doesn't show when I try to route any track to outboard. Have to make sure you've created the outputs in the bus tab as well if they're not already there.
Post by RealNoob on Dec 2, 2023 15:58:43 GMT -6
Deleted all in I/O and rebuilt. Again, seen clearly there but doesn't show when I try to route any track to outboard. Have to make sure you've created the outputs in the bus tab as well if they're not already there. oh... really? will look. thanks
Post by jaba on Dec 2, 2023 16:00:44 GMT -6
Is there a possible feedback loop that it's forcing you to avoid? PT does that? Can't recall for sure but I know some DAWs do. Figured it was worth checking.
Post by the other mark williams on Dec 2, 2023 21:27:12 GMT -6
@soriantis - any thoughts on this? You're the only other person around here who I know runs a Big Six...
Post by RealNoob on Dec 3, 2023 21:46:02 GMT -6
Have to make sure you've created the outputs in the bus tab as well if they're not already there. That was it. Thanks. It didn't occur to me that I had to route it twice - outputs and busses. I just a playback and mute test. Everything seems to be functioning. Thanks all and thank you Bentley
Post by RealNoob on Dec 10, 2023 16:38:34 GMT -6
And then.....
I find out PT doesn't run on Sonoma. pfft. Keep getting 9173's with no plugins and 3% resource use. Had ultimate sub and spoke to support. They have no ETA
