Post by crillemannen on Nov 12, 2023 5:04:52 GMT -6
Build up doesn't mean anything. I've been doing plenty of comparisons and a certain color might be beneficial on a certain mic and source while on another source/combo that color might be a bit to much. Then you have personal preference which is completely subjective.
I'd suggest you do a test yourself to figure out what you personally like and then stick to it. The microphone is allot more important then the preamp and the performance and song trumps all.
Post by Deleted on Nov 12, 2023 7:31:23 GMT -6
When it comes to a standard IC (which are usually cheap), cheap mixer, cheap external or interface amps vs. a proper transformer balanced design there is for me a massive difference after the chain has been through a comp. Cheap stuff sounds degraded, "flat" & "2D". Now I know these descriptions irk but there are reasons for it like harmonic distortion, phase, slew, imp and decay. I've seen tests on the purple site where two amps wouldn't even null at -30. There's IME no such thing as truly "clean", there's just a bunch of design decisions to lessen the impact of degredation caused by the topology. What I've always found curious is even with basic measurements, manufacturers explaining their topologies and reasons for it why to some it just doesn't matter.
Don't get me wrong, at a certain level of quality most amps seem to be absolutely fine and I have not nor will I ever use every IC amp out there, some might be great. That being said in the grand scheme of entire productions when we factor everything else, no amp or piece of equipment (unless it's broken) will ever compare to a smashed limiter for "degraded, 2D & flat" this is the realms of undesirable distortion, stereo imaging issues and hardly any dynamic range which subtracts most nuance created by dynamic range.
We still do this today and then debate about amps?! I have to ask, if someone truly believes this sounds better than a technically controlled master then have you not got bigger issues? This is quantifiable in all regards and I know why pro's do it, louder always appears to be better (until you just turn up the controlled version). In a sea of songs where people flip to the next in a second then you have to grab their attention, I understand. However, how many engineers actually think this sounds better?
My point is for all the benefits equipment may give there are so many idiosyncracies, variances, preferences etc. that have a far greater influence. Some say mixing doesn't have a massive impact but I disagree, I've heard too many crap productions made from relatively well recorded material. Although usually in low budget metal when mic's were a thing it's bad recordings and no amount of mixing will fix that. Also sometimes the production itself demands "2D", the ISK 2B tube mic has some phase spillage which makes it sound bigger than a usual mono source mic and it also has a nice bit of harmonic distortion. In a wide acoustic track it's lovely, it fills out the vocals & guitars but I could never use it in a metal song, there's too much going on and a super wide hi-fi sounding chain will only cause clashes resulting ultimately in a low-fi mushy mess.
Post by ericn on Nov 12, 2023 8:14:02 GMT -6
I think a lot of developing the skill to see if a new piece of kit is going to work in a mix comes from mixing as you go. Bringing up the faders and listening tells you in the beginning if it’s going to work.
Post by niklas1073 on Nov 12, 2023 8:32:40 GMT -6
Build up doesn't mean anything. I've been doing plenty of comparisons and a certain color might be beneficial on a certain mic and source while on another source/combo that color might be a bit to much. Then you have personal preference which is completely subjective. I'd suggest you do a test yourself to figure out what you personally like and then stick to it. The microphone is allot more important then the preamp and the performance and song trumps all. The sole reason i threw out the question to begin with was, since Ive tried and have come to the conclusion that it is all about the stacking and build up and consistency for me. Back when I realized this, it took my recordings and productions to a completely new level. My tracks ended up with 1-3 plugs instead of a motherload trying to correct and achieve the wanted outcome. Finding the right pres and comps to achieve this was a time consuming project for sure. Listening to single source comparisons was a dead end for me that did not really tell me much of the pres behavior in larger context. Thats what my question initially was about, how others experience it, when i just suddenly began thinking why all the comparisons tend to be single source out there on you tube and the other side is not much of a topic or debate.
Post by crillemannen on Nov 12, 2023 8:55:24 GMT -6
Build up doesn't mean anything. I've been doing plenty of comparisons and a certain color might be beneficial on a certain mic and source while on another source/combo that color might be a bit to much. Then you have personal preference which is completely subjective. I'd suggest you do a test yourself to figure out what you personally like and then stick to it. The microphone is allot more important then the preamp and the performance and song trumps all. The sole reason i threw out the question to begin with was, since Ive tried and have come to the conclusion that it is all about the stacking and build up and consistency for me. Back when I realized this, it took my recordings and productions to a completely new level. My tracks ended up with 1-3 plugs instead of a motherload trying to correct and achieve the wanted outcome. Finding the right pres and comps to achieve this was a time consuming project for sure. Listening to single source comparisons was a dead end for me that did not really tell me much of the pres behavior in larger context. Thats what my question initially was about, how others experience it, when i just suddenly began thinking why all the comparisons tend to be single source out there on you tube and the other side is not much of a topic or debate. Have you considered that you improved your skills and ears while doing that? Of course a great preamp and mic can help the end result, I'm all about that since I have quite a few nice pieces. But it's not about stacking. You can check out several of my preamp videos on YT. All stacked tracks, especially the last couple of episodes. My conclusion is that if you know your tools you can mix and match, and some preamps definitely helps things sound more cohesive. But.. the mic is so much more important and a good microphone like say the Km84 makes the recording effortless, it just sounds right. I would trade a great mic for a good affordable preamp like the Golden Age Premier 73 then vice versa.
Post by niklas1073 on Nov 12, 2023 10:53:43 GMT -6
The sole reason i threw out the question to begin with was, since Ive tried and have come to the conclusion that it is all about the stacking and build up and consistency for me. Back when I realized this, it took my recordings and productions to a completely new level. My tracks ended up with 1-3 plugs instead of a motherload trying to correct and achieve the wanted outcome. Finding the right pres and comps to achieve this was a time consuming project for sure. Listening to single source comparisons was a dead end for me that did not really tell me much of the pres behavior in larger context. Thats what my question initially was about, how others experience it, when i just suddenly began thinking why all the comparisons tend to be single source out there on you tube and the other side is not much of a topic or debate. Have you considered that you improved your skills and ears while doing that? Of course a great preamp and mic can help the end result, I'm all about that since I have quite a few nice pieces. But it's not about stacking. You can check out several of my preamp videos on YT. All stacked tracks, especially the last couple of episodes. My conclusion is that if you know your tools you can mix and match, and some preamps definitely helps things sound more cohesive. But.. the mic is so much more important and a good microphone like say the Km84 makes the recording effortless, it just sounds right. I would trade a great mic for a good affordable preamp like the Golden Age Premier 73 then vice versa. No, it has not been about learning curve in that sense, but yes in the sense that the more I was able to invest in the front end, the more I learned about the significance of how that defines the end result in a fundamental way and the mixing becomes dependent and reliant on that and not vice versa. I do believe the same philosophy applies for mics, room, instruments etc. The build up of tonal cohesiveness will eventually give a character that is cohesive across the production. Might of course also end up in unwanted results when choosing the wrong tool that might have sounded fine at the time on a single track but not as part of defining the character. I will take a look at your channels latest vids absolutely, thanks for the tip. The mic absolutely has more impact than a pre in most cases. And the same applies there in choices of mic characters used across the production. Their character will build up just the same. Sure we often have to do compromises due to economical realities. But how to reach close enough to the coveted sound of course varies. And you are absolutely right in knowing your gear and the outcome of matching. This is of course also a debate of aesthetics to some extent. Do we aim for consistency and cohesiveness, compromising on some tracks for the greater good, or do we aim for perfect tracks across the field and giving away some of the big picture. Tool-choice is an art of its own, and even on very high level productions today you occasionally come across elements not sitting and sterile, identity-less productions, despite being technical masterpieces. I think in the time of consoles, certain randomness and mismatch was naturally eliminated. And I do believe the stacking was one factor of recognizable sounds and productions we came to know and covet.
Post by yewtreemagic on Nov 12, 2023 12:13:38 GMT -6
Yeah I think we obsess about pres too much. Just give me one that doesn’t sound bad and we’re golden. If only all customers were like you John!
Post by ericn on Nov 12, 2023 12:47:33 GMT -6
Yeah I think we obsess about pres too much. Just give me one that doesn’t sound bad and we’re golden. m I think a lot of it is this: most haven’t been in a professional situation where the scenario is you walk in look at what’s in front of you and think “ OK this is what I’ve got now how do I make it work for me ?”. Vs going on the website of your favorite dealer and the 100’s of pre’s and going “ what should I buy.” Most don’t understand that up until the early 2000’s most top studios only had a handful of outboard pre’s, most tracking other than lead vocals were done with what’s in the board. Now granted this example is about recordings done on API and Classic Neve, but you will notice that in Recording Rumors and Tusked not a single mention of outboard preamps.
Post by matt@IAA on Nov 12, 2023 14:56:32 GMT -6
re: stacking... it probably depends quite a bit on the engineer as well. almost any pre is going to sound darn similar to any other at low levels. you wont hear big differences until you push, because distortion always rises with increased gain and increased output levels. distortion is as much a tool in the engineer's toolbox as eq or compression.
Post by notneeson on Nov 12, 2023 15:33:11 GMT -6
I completely agree on tonal cohesion and stacking having a fairly large macro impact on a project. Stacking is absolutely a thing and why specific studios get booked to this day. Listen to Beck’s Sea Change and Morning Phase, essentially the same record made twice. Big tonal difference with same players, studios and mics - only major change is the console and it’s quite dramatic. Can go all day with records with obvious signatures due to stacking. Have you seen enough footage of these sessions to conclude the mic placement is the same? Instruments? 100% curious.
Post by chessparov on Nov 12, 2023 18:09:48 GMT -6
My Spidey Sense is generally on Acoustic weighted recordings... Stacking REALLY matters. Typical Rock Mix with "real instruments"... Acoustic/Electric, still matters. But less. Less still on "Modern" Genres. Where they push lots of buttons, before Autotuning/Gridding it to death. Chris P.S. Due to limited experience/judgement... Didn't seem right to "like" things I don't fully understand.
Post by Deleted on Nov 13, 2023 10:11:34 GMT -6
re: stacking... it probably depends quite a bit on the engineer as well. almost any pre is going to sound darn similar to any other at low levels. you wont hear big differences until you push, because distortion always rises with increased gain and increased output levels. distortion is as much a tool in the engineer's toolbox as eq or compression. depends on the pre. many of these modern live boards and interface pres use absolute butt ic opamps. many interface pres use pga 2500 and need a pad before the pre. then there are additional chips and gainstages. it's really hard to make even a prism pre sound like an rme pre despite both using pga 2500 from how different their conversion sounds. RME can have some additional gainstages. Compare that to THAT chip pres like Lynx or THAT chip pres controlling opamps like Apogee. You cannot make them sound the same. You can pick out differences. Push them, you often activate additional gain stages that add extra distortion. So cleanish to toneful/crappier/plastic to crap often and you're not even clipping. Now for old school pres, anything recognizable Nevey (not like the new RND with the distortion turned off or made in UK Focusrite) or API can have a big tonal shift on a lot of material vs your Grace and Millenia type pres. Fizz and air disappearing on API even getting exacerbated on some Neve. The stack up with old pres is real because the distortion from old transformers in the low end to low mids and all of that stuff piles up. Some API type opamps are also quite muddy in the low mids versys the current 2520. Modern transformers like Jensens in Daking much less so but the Daking gets noticeably colored when pushed.
but hey everyone is obsessed with coloring popular music as much as possible now and doesn't want to buy something multichannel, mostly pretty clean, and super reliable. They want to move huge ass racks around and feel special when nothing will solve the problem of poor recordings of bad music
Post by robo on Nov 13, 2023 11:20:24 GMT -6
I completely agree on tonal cohesion and stacking having a fairly large macro impact on a project. Stacking is absolutely a thing and why specific studios get booked to this day. Listen to Beck’s Sea Change and Morning Phase, essentially the same record made twice. Big tonal difference with same players, studios and mics - only major change is the console and it’s quite dramatic. Can go all day with records with obvious signatures due to stacking. Have you seen enough footage of these sessions to conclude the mic placement is the same? Instruments? 100% curious. Different engineers / producers / mixers. Also, I’m pretty sure Sea Change was recorded and mixed on the same console, and Morning Phase was mixed ITB. The band is the same, and I believe both were mostly recorded playing together.
Post by notneeson on Nov 13, 2023 11:34:25 GMT -6
Have you seen enough footage of these sessions to conclude the mic placement is the same? Instruments? 100% curious. Different engineers / producers / mixers. Also, I’m pretty sure Sea Change was recorded and mixed on the same console, and Morning Phase was mixed ITB. The band is the same, and I believe both were mostly recorded playing together. Ah, yeah. Nigel Godrich has a pretty distinct sound to his stuff, especially drums.
Post by christopher on Nov 13, 2023 12:10:50 GMT -6
I try to explain to my buddy who is still skeptic of all things analog.. I tell him a preamp is like a guitar amp for a mic. Lots of amps sound great, some just are incredible for doing what they do. Some guitars match with certain amps, it just works. Some Mics just work with certain preamps, it’s the magic recipe. Same with guitars, you don’t have to use the Gibson/Marshall etc recipes when there’s so many amps to choose from
Tape for me is my fav stacking device. Bouncing a mix is fun, but the real fun is every track taped up. It can be a little challenging for certain tracks and forces how you mix a little. If anyone has a project you want to try, PM me. I re-record wavs time-aligned to the original so it’s easy to switch between tape vs no tape.
Post by kbsmoove on Nov 13, 2023 13:56:46 GMT -6
Preamps don't matter much to me, until they do. I have my preferences, but my biggest preference is for a quality transformer balanced preamp for most sources. the end result still always sounds like one of my records no matter which preamp I use for which source.
Biggest differences i hear come when mixing other peoples work that was tracked with cheap interface preamps. raw tracks are often bland and need lots of iron to get some tone and weight in the mixes. Much harder to make them sound "like a record".
Second biggest differences are in the extremes - neve vs api on a kick drum make the lows do very different things. Neve vs api vs clean/transformerless preamp on overheads do very different things in the top end. Reamped guitar with distortion and harmonics galore to me usually overshadows the small differences between preamps in the mids.
plus, there are notably large differences for wild vibey stuff - altec 1566As get used when i need some extra something in the lows, a lofi-ish vocal, or a distortion box.
I will say i hate walking into a studio with 12 different preamp pairs and deciding which preamp to use on what part of a drumkit. i prefer a console, and in these situations i usually just ask the assistant to patch in what they like, or say "neve on kick and toms, clean on overheads, whatever you want for everything else". Still sounds like I recorded it, because mic choice and placement makes a bigger difference than a 1073 clone or a 3124 or a sytek etc.
Post by lee on Nov 13, 2023 14:16:12 GMT -6
I will say i hate walking into a studio with 12 different preamp pairs and deciding which preamp to use on what part of a drumkit. i prefer a console, and in these situations i usually just ask the assistant to patch in what they like, or say "neve on kick and toms, clean on overheads, whatever you want for everything else". Still sounds like I recorded it, because mic choice and placement makes a bigger difference than a 1073 clone or a 3124 or a sytek etc. I want at least 6-8 channels of one kind before having to make an alternate decision. Don't love the "pupu platter" approach.
Post by Ward on Nov 13, 2023 14:23:18 GMT -6
I will say i hate walking into a studio with 12 different preamp pairs and deciding which preamp to use on what part of a drumkit. i prefer a console, and in these situations i usually just ask the assistant to patch in what they like, or say "neve on kick and toms, clean on overheads, whatever you want for everything else". Still sounds like I recorded it, because mic choice and placement makes a bigger difference than a 1073 clone or a 3124 or a sytek etc. I want at least 6-8 channels of one kind before having to make an alternate decision. Don't love the "pupu platter" approach. Very good thinking. What do you think some of the best options would be? Neve 1290 family, API/CAPI 312 family, Focusrite ISA110, Grace, Jenson 990 twin variety, others?
Post by thehightenor on Nov 13, 2023 15:32:14 GMT -6
The sole reason i threw out the question to begin with was, since Ive tried and have come to the conclusion that it is all about the stacking and build up and consistency for me. Back when I realized this, it took my recordings and productions to a completely new level. My tracks ended up with 1-3 plugs instead of a motherload trying to correct and achieve the wanted outcome. Finding the right pres and comps to achieve this was a time consuming project for sure. Listening to single source comparisons was a dead end for me that did not really tell me much of the pres behavior in larger context. Thats what my question initially was about, how others experience it, when i just suddenly began thinking why all the comparisons tend to be single source out there on you tube and the other side is not much of a topic or debate. Have you considered that you improved your skills and ears while doing that? Of course a great preamp and mic can help the end result, I'm all about that since I have quite a few nice pieces. But it's not about stacking. You can check out several of my preamp videos on YT. All stacked tracks, especially the last couple of episodes. My conclusion is that if you know your tools you can mix and match, and some preamps definitely helps things sound more cohesive. But.. the mic is so much more important and a good microphone like say the Km84 makes the recording effortless, it just sounds right. I would trade a great mic for a good affordable preamp like the Golden Age Premier 73 then vice versa. A great pre-amp needs something great to pre amplify. Ime, you don’t get the best from a great mic without a great pre-amp. And that doesn’t mean an expensive mic, the M88 or SM57/58/SM7 can sound fantastic with a great pre-amp. A great preamp can take a great dynamic mic to a whole new level. …. and anyway, what is it people have against pre-amps recently! I guess it’s their turn, people used to pick on converters
Post by kbsmoove on Nov 13, 2023 15:38:52 GMT -6
I want at least 6-8 channels of one kind before having to make an alternate decision. Don't love the "pupu platter" approach. I want 16 of the same thing! and if i can't have that i'd like 6-8 of the same thing. and if i can't have that i'd at least like 4 of one thing and 4 of another. but having 16+ channels on a good sounding console and only thinking about whats in the rack if something is lacking is my favorite way to work.
Post by lee on Nov 13, 2023 18:52:27 GMT -6
I want at least 6-8 channels of one kind before having to make an alternate decision. Don't love the "pupu platter" approach. Very good thinking. What do you think some of the best options would be? Neve 1290 family, API/CAPI 312 family, Focusrite ISA110, Grace, Jenson 990 twin variety, others? Hey Ward, I'd be happy to record with any of the above, but I admit I have no Jensen 990/Hardy experience. Always wanted to hear one. This is a fun thought experiment. I think that if you have contrasts, they should be BIG contrasts. And as few contrasts as you can get away with. And the biggest decision is about the "foundation" tone. Examples of a modest setup might be something like: (based around solid state, with color) Majority - 312 type Extra flavor 1: some kind of super clean, high headroom (Grace or Millennia or Manley) Extra flavor 2: something really colored, like some channels of Coil or WT-72. Or (based around tube, clean and high headroom) Majority - Manley Force. Checks a lot of boxes. Extra flavor 1: something solid state that you like (I might choose a pair from the Quad Eight family. The A-Designs Ventura was a real under-appreciated unit) Extra flavor 2 :Again, something that sounds like it's out of recording history, like the ones above or Electric EC3? Fearn? Or (based around versatility) Majority - Undertone MPDI-4. Checks maybe more boxes. Extra flavor 1: At that point, do you even need any Grace or Millennia or ISO110 with all the transformer options? Probably not. Extra flavor 2: Again, something very retro. I'd prefer any of the above to the pick-n-mix strategy, if I had the choice. EDIT: where this might fall down is if you have a particular mic that really connects well with a certain preamp (be it impedance or whatever voodoo), which somebody mentioned above. It's a good point.
Post by lee on Nov 13, 2023 18:53:12 GMT -6
I want at least 6-8 channels of one kind before having to make an alternate decision. Don't love the "pupu platter" approach. I want 16 of the same thing! and if i can't have that i'd like 6-8 of the same thing. and if i can't have that i'd at least like 4 of one thing and 4 of another. but having 16+ channels on a good sounding console and only thinking about whats in the rack if something is lacking is my favorite way to work. I agree with you here.
Post by plinker on Nov 13, 2023 19:07:15 GMT -6
Since this thread is a philosophical endeavor, here's another argument on the stacking reasoning that contradicts my previous mathematical analogy. Apologies, in advance, for being pedantic... - every preamp imparts its own distorted tone: - distortion is, at least, an EQ change (that may be none) and an amount of saturation equal to, or greater than zero. - every transient has a peak and dip. - we expect a preamp to impart more tone (especially saturation) with more gain. So, as the transient increases/peaks we can expect more preamp tone, and less as it dips. - transients peak in the total mix frequency spectrum at different instances. - as audio engineers our goal is to mix all the different transients in a way that they complement, not overlap, each other in both the frequency and amplitude dimensions Therefore: - as we stack more tracks, we fill up more of the frequency/amplitude spectrum, at each time sample, with more signal information. As we add more tracks, we add more preamp tone to the available frequency/amplitude space. So, if we have only a small number of instruments/sources in a mix, there are fewer frequency peaks occurring on a sample-to-sample basis. As we add more sources we fill the spectrum with more distortion and it adds up --- stacking! Of course, every other part of the signal is stacking too (mic tone and processor tone), and I'm not sure how to address that... I hope that made some shitty sense -- it's been a few beers
Post by thehightenor on Nov 14, 2023 2:30:07 GMT -6
Since this thread is a philosophical endeavor, here's another argument on the stacking reasoning that contradicts my previous mathematical analogy. Apologies, in advance, for being pedantic... - every preamp imparts its own distorted tone: - distortion is, at least, an EQ change (that may be none) and an amount of saturation equal to, or greater than zero. - every transient has a peak and dip. - we expect a preamp to impart more tone (especially saturation) with more gain. So, as the transient increases/peaks we can expect more preamp tone, and less as it dips. - transients peak in the total mix frequency spectrum at different instances. - as audio engineers our goal is to mix all the different transients in a way that they complement, not overlap, each other in both the frequency and amplitude dimensions Therefore: - as we stack more tracks, we fill up more of the frequency/amplitude spectrum, at each time sample, with more signal information. As we add more tracks, we add more preamp tone to the available frequency/amplitude space. So, if we have only a small number of instruments/sources in a mix, there are fewer frequency peaks occurring on a sample-to-sample basis. As we add more sources we fill the spectrum with more distortion and it adds up --- stacking! Of course, every other part of the signal is stacking too (mic tone and processor tone), and I'm not sure how to address that... I hope that made some shitty sense -- it's been a few beers Stacking is a very real thing. That’s why when I’m recording 24 tracks of BV’s I don’t use a 1073 or CA-70. The sound gets too thick and dominant. I always use a clean solid state pre that’s more “straight wire and gain” and a wide bandwidth and then there’s air and clarity to the BV’s. I don’t like to paint a picture with same brush, I like to have a few different sizes and textures in the jar (so to speak)
Post by Hudsonic on Nov 15, 2023 4:49:42 GMT -6
Preamp is King. Rens Heijnis custom built 60 volt has treble response to 1MHz. Imparts super clean sound so the player / singer / instrument has to be very very good. Not for everyone. Sytek also one of my faves along with Neve 9098 stand alone pre. (2 ch. in a 19" format).
