Post by unit7 on Oct 9, 2023 6:41:16 GMT -6
As I'm going hybrid I've been asking around a bit regarding the impedance situation connecting my Avid and Prism interfaces directly (via patch bay though) to my outboard ins and outs which to my knowledge is 600Ω. I saw the thread about Eric's Copperline which mentions that possible issue and thought I should ask here. I can't afford 20 Copperlines , but I'm good with a soldering iron so I could easily build a bunch of simple "adapters". Has anyone any insight? Or even A/B'd with a Copperline or other solution?
Post by svart on Oct 9, 2023 7:08:24 GMT -6
As I'm going hybrid I've been asking around a bit regarding the impedance situation connecting my Avid and Prism interfaces directly (via patch bay though) to my outboard ins and outs which to my knowledge is 600Ω. I saw the thread about Eric's Copperline which mentions that possible issue and thought I should ask here. I can't afford 20 Copperlines , but I'm good with a soldering iron so I could easily build a bunch of simple "adapters". Has anyone any insight? Or even A/B'd with a Copperline or other solution? What's the output impedances of your interfaces? You didn't mention the models so I can't go look them up.. In any case, you'll probably be OK. Most "outputs" on an interface will have enough drive to work with 600R even though they might be spec'd at a higher value. Generally the spec will just be the impedance they test at, not the limit.
Post by andersmv on Oct 9, 2023 7:09:16 GMT -6
In a couple of larger studios I worked in, they had XLR barrel adapters hard patched into a few I/O on the patch bay so you could patch between a few pieces of gear if need be. Seemed like a really good cheaper solution, as it was only needed on the end of some older compressors mostly. Kind of a toss up, I ignored them as I played around with them a few times and could never really tell a difference.
I’m kind of curious to play around with something like that again. I’m reviewing the Undertone Audio preamps right now and they have a 600 ohm switch on them for the end of the chain. It’s a noticeable difference when mixing through them with their Pyra Sum summing mixer.
Post by drbill on Oct 9, 2023 8:26:42 GMT -6
I have 120 i/o on my HDX system - AVID converters - with a hundred + pieces of gear. The below pic is only about 1/3 of it. All gear comes into PT via PT hardware inserts on the converters. I have no special adapters on the outputs or have done no special wiring in the bays. It all works fine. A few of my compressors do have load switches, and I switch them to where I like the tone best, but it all works fine for me. I'm sure that "theoretically" some gear could be better matched, but it all sounds fine to me. I'd start by just hooking stuff up and see if you like the tone of things. Don't find a problem that may not exist. Good luck and have fun!!
Post by unit7 on Oct 9, 2023 14:56:01 GMT -6
Thanks guys!!! I'm certainly not trying to produce a problem here. It's a BIG move to throw out my 72 channel Harrison desk so there's a lot of planning and soldering coming up so among all the stuff that needs to be done I just thought IF this could be something to look into, now's the time. My interfaces are 2 x Avid I/o 16 x 16 and 1 x Prism ADA8-XR. I googled specs for the Avid interface but can't find, but I believe I've read before that it's 10kOhms. I'm not worrying at all and I'll probably notice if there's any major difference in sound from any of the outboard I've got for a good while now. drbill wow 120 i/o!! I concidered 64 i/o but decided to settle for 40 and chain my five units on the mix bus directly from unit to unit instead of having them all accessible in the patchbay Thanks again everybody for the input!
Post by Ward on Oct 10, 2023 15:06:00 GMT -6
I have 120 i/o on my HDX system - AVID converters - with a hundred + pieces of gear. The below pic is only about 1/3 of it. SNIP You such a conservative minimalist.
Post by chessparov on Oct 16, 2023 17:09:37 GMT -6
That's a liberal assessment. Chris
Post by unit7 on Oct 16, 2023 23:28:55 GMT -6
I have yet another question regarding delay compensation. I asked on the DUC but got no qualified answer yet. I believe drbill will know this right away.. Before going to the final mix bus I'll be sending the whole mix to an Aux and insert an outboard compressor to blend in some parallel compression. All good so far. But if I'll send that (already compensated for) signal to yet another Aux with yet another outboard insert, will PT then calculate the added delay correctly?
Post by Blackdawg on Oct 16, 2023 23:58:51 GMT -6
I have yet another question regarding delay compensation. I asked on the DUC but got no qualified answer yet. I believe drbill will know this right away.. Before going to the final mix bus I'll be sending the whole mix to an Aux and insert an outboard compressor to blend in some parallel compression. All good so far. But if I'll send that (already compensated for) signal to yet another Aux with yet another outboard insert, will PT then calculate the added delay correctly? So you're going to add another HW insert to just the parallel signal? Why use another aux? Just put it after the other HW insert. But if your saying your folding in the first parallel aux into the mix, but sending that to another aux for more processing and folding that one also back in, so in effect having 2 parallel buses? I think you'll have issues there. Why are you trying to do that exactly?
Post by drbill on Oct 17, 2023 9:55:00 GMT -6
Sorry, I don't think I am 100% understanding.
Post by unit7 on Oct 17, 2023 13:59:42 GMT -6
I have yet another question regarding delay compensation. I asked on the DUC but got no qualified answer yet. I believe drbill will know this right away.. Before going to the final mix bus I'll be sending the whole mix to an Aux and insert an outboard compressor to blend in some parallel compression. All good so far. But if I'll send that (already compensated for) signal to yet another Aux with yet another outboard insert, will PT then calculate the added delay correctly? So you're going to add another HW insert to just the parallel signal? Why use another aux? Just put it after the other HW insert. But if your saying your folding in the first parallel aux into the mix, but sending that to another aux for more processing and folding that one also back in, so in effect having 2 parallel buses? I think you'll have issues there. Why are you trying to do that exactly? 7-8 years ago I found a setup/routing for processing the whole mix on my analog desk/my outboard that I really like and have used for all styles: Firstly I do classic parallel comp of the whole mix using a (HW) Shadow Hills Mastering Comp. Then I started experimenting with parallel distortion (on the whole mix/sometimes sans lead vocal) from my (HW) Culture Vulture (Anniversary Edition) and really loved it. But on dynamic material which I do a lot I found the distortion too present on loud parts, so instead I used the compressed version of the mix coming from the SHMC into the Culture Vulture and blended that into the mix in parallel, and it was an instant hit. Since the Culture Vulture doesn't have a mix pot I can't do the way you suggest (if I get what you suggest..). Anyway this, and similar stuff, is what I want to do in the hybrid setup. I'm certain the parallel comp will work, sending the whole mix to an Aux and insert my Shadow Hills on that Aux. But then when I send from that Aux to yet another Aux and insert the Culture Vulture on that second Aux, will PT then calculate additional delay compensation, I mean...will it see that the signal going into the second Aux is already compensated for and understand that it has to delay further when doing HW insert on the second Aux?.. My signature says "Babe in the woods"...Could be in this case, as I find it hard to wrap my head around this thing. Grateful for any advice! But in two weeks I'll start with my new setup and if it doesn't work I'll hear it right away and will probably know what to do to make it work, though dialing in delay comp manually would be tedious, especially since values differ at different sample rates
Post by thirdeye on Oct 17, 2023 15:33:25 GMT -6
So you're going to add another HW insert to just the parallel signal? Why use another aux? Just put it after the other HW insert. But if your saying your folding in the first parallel aux into the mix, but sending that to another aux for more processing and folding that one also back in, so in effect having 2 parallel buses? I think you'll have issues there. Why are you trying to do that exactly? 7-8 years ago I found a setup/routing for processing the whole mix on my analog desk/my outboard that I really like and have used for all styles: Firstly I do classic parallel comp of the whole mix using a (HW) Shadow Hills Mastering Comp. Then I started experimenting with parallel distortion (on the whole mix/sometimes sans lead vocal) from my (HW) Culture Vulture (Anniversary Edition) and really loved it. But on dynamic material which I do a lot I found the distortion too present on loud parts, so instead I used the compressed version of the mix coming from the SHMC into the Culture Vulture and blended that into the mix in parallel, and it was an instant hit. Since the Culture Vulture doesn't have a mix pot I can't do the way you suggest (if I get what you suggest..). Anyway this, and similar stuff, is what I want to do in the hybrid setup. I'm certain the parallel comp will work, sending the whole mix to an Aux and insert my Shadow Hills on that Aux. But then when I send from that Aux to yet another Aux and insert the Culture Vulture on that second Aux, will PT then calculate additional delay compensation, I mean...will it see that the signal going into the second Aux is already compensated for and understand that it has to delay further when doing HW insert on the second Aux?.. My signature says "Babe in the woods"...Could be in this case, as I find it hard to wrap my head around this thing. Grateful for any advice! But in two weeks I'll start with my new setup and if it doesn't work I'll hear it right away and will probably know what to do to make it work, though dialing in delay comp manually would be tedious, especially since values differ at different sample rates You should be fine with the Avid interface as long as inside Pro Tools you are using hardware inserts on auxes (or tracks - but not on master faders). Pro Tools will calculate for the hardware insert delays when using Avid interfaces (or cloned HDX)
Post by drbill on Oct 17, 2023 17:05:44 GMT -6
I'm certain the parallel comp will work, sending the whole mix to an Aux and insert my Shadow Hills on that Aux. But then when I send from that Aux to yet another Aux and insert the Culture Vulture on that second Aux, will PT then calculate additional delay compensation, I mean...will it see that the signal going into the second Aux is already compensated for and understand that it has to delay further when doing HW insert on the second Aux?.. If I'm understanding correctly, and if you're on HDX Ultimate, yes PT will recalculate for the second Aux. No worries. But it will still be a 100% wet signal, right? If not and you're trying to mix the SH signal, along with the SH into CV signal - you are essentially creating a parallel "wet/dry blend" of the two. If you need to "blend" these two signals together, best to do it in the analog world. If your analog device(s) - CV - had a wet/dry mix, you'd be 100% OK - just use the output of the blended CV mix as your final stream. PT will delay compensate for the round trip no worries. But if you're trying to "submix" the two together to create your final "blend - you're going to run into inter sample issues no matter what DW you use. Physics will not be cheated. . Inter sample latency is something that no DAW can compensate for. And for that conundrum - depending on how "close" to the beginning or end of a sample you may fall, or what sample rate you're mixing at, the "error" between samples may or may not bother you. Even still though, if I need a wet/dry blend between an analog signal and a digital signal, I'll always try to accomplish that outside the DAW. Higher sample rate sessions cut in half or quarter the possible amount of error that delay compensation cannot "fix". If I'm understanding, the best thing you can do is to drop a pair of these on the output of your CV : serpentaudio.com/send-n-blend/. Then, the output of the send n blend is your final mix. OOOrrrrrr - it's quite possible that I'm still not completely understanding your workflow. I'd say just try it and see what happens.
Post by Blackdawg on Oct 17, 2023 22:56:21 GMT -6
Yeah I'll echo what Bill said. PT should deal with it as much as it can.
There are a few parallel processors you could look into out here as well. SPL I think makes a 500 series one.
But you should try it, might not be a big enough deal to bother you.
Post by unit7 on Oct 18, 2023 5:08:30 GMT -6
Thanks again everybody for excellent input and taking the time to help out! In these kind of discussions there's often bits of experiences that are shared that I value. But I'm a bit embarrassed now... As I have the i/o's of my interfaces hooked up in patch bays it was very easy to try this, I just didn't think of it, because routing has been analog/console related for so long. Didn't have to insert the HW outboard even, I just (physically) patched the outs to the ins on the selected inserts. So I just took a stereomix and routed it the the way I described, took three minutes and it works! All three busses play in phase. Could perhaps run into delay comp issues when routing multichannel gets more complicated but now at least I know this is working. Thanks again! Over and out! Attachments:
Post by keymod on Oct 18, 2023 8:29:03 GMT -6
That Pyra Sum looks very interesting
