Post by Johnkenn on Jul 5, 2014 15:22:27 GMT -6
Post by bakamo ichigei on Jul 6, 2014 15:21:05 GMT -6
Or maybe 18x36 so that you have two on one board. board..... board is a funny-looking word.
......aaannd that's enough homebrew for me.
Post by svart on Jul 7, 2014 11:23:26 GMT -6
That's what they say on the site, but that's only if you want the edges of the back board to be the same as those of the blocks. You could make it wider/taller if you wanted to make it easier to mount or something without it affecting the sound, which they also mention..
Post by Johnkenn on Jul 7, 2014 11:55:18 GMT -6
Post by svart on Jul 7, 2014 11:57:22 GMT -6
No hate here. Looks good to me. How much did it cost you, and how heavy is it?
Post by tonycamphd on Jul 7, 2014 14:38:21 GMT -6
Q the streamers, balloon release and triumphant big band music!!!! Great job JK! I knew u could do it, next comes the iron! How u liking the sound? U can hear it when u play/sing in front of it, but it's more evident with a mic capture ime svart 22.4 lbs, under $30 each I believe.
Post by Johnkenn on Jul 7, 2014 16:03:22 GMT -6
Thank you thank you. So where should I put it? Behind me when I sing?
Post by tonycamphd on Jul 7, 2014 19:05:11 GMT -6
Thank you thank you. So where should I put it? Behind me when I sing? just do some experimenting, i usually stick them around the back of the mic(not too close), great for figure of 8, omni, and even with a cardioid pattern, as you know it still totally picks up. The sparkle effect is subtle, but beautiful ime, this is one of those strange cases where the benefit of a piece is not near as obvious to your ears in the room, as it is once it hits tape. let us know what you find out bromee.
Post by Johnkenn on Jul 7, 2014 19:22:37 GMT -6
My little singing area is dead with absorption. Wondering whether I should take some of the absorption down and replace with the monster. Probably need to build another one.
Post by tonycamphd on Jul 7, 2014 19:45:51 GMT -6
My little singing area is dead with absorption. Wondering whether I should take some of the absorption down and replace with the monster. Probably need to build another one. Ur smarter than the average bear, i didn't want to suggest that right after you built this one, but yes, a few of these, and you really start hear a big diff, but one is still quite effective if you place it nicely.
Post by Johnkenn on Jul 8, 2014 8:51:26 GMT -6
You're gonna laugh, but I did this with a circular saw...and I ain't doing that shit again. Just gonna have to invest in a mitre.
Post by Johnkenn on Jul 8, 2014 8:52:32 GMT -6
@tonycamp should I replace some of the absorption with these? I could use the absorption behind my desk, actually...
Post by svart on Jul 8, 2014 11:43:27 GMT -6
Yeah, rear wall is a common place for diffusion. Move the absorption to behind your desk and over it, if you haven't already done that.
Post by jeromemason on Jul 8, 2014 22:28:24 GMT -6
I'd love to hear what it sounds like in Blackbirds room that has the smaller type from floor to ceiling, on every freaking wall. I bet that room sounds like it's twice it's size and the imaging in it must be incredible. This is just unreal.....
Post by Johnkenn on Jul 8, 2014 22:47:31 GMT -6
I've had a couple of things mixed in that room...spent a day in there once. Honestly, it's a little disconcerting. You never feel the thump of the bottom end...it's kind of weird. Looks cool as hell though...
Post by jcoutu1 on Jul 9, 2014 16:21:54 GMT -6
I'd love to hear what it sounds like in Blackbirds room that has the smaller type from floor to ceiling, on every freaking wall. I bet that room sounds like it's twice it's size and the imaging in it must be incredible. This is just unreal..... Wow. That's beautiful.
Post by tonycamphd on Jul 9, 2014 19:46:08 GMT -6
I'd love to hear what it sounds like in Blackbirds room that has the smaller type from floor to ceiling, on every freaking wall. I bet that room sounds like it's twice it's size and the imaging in it must be incredible. This is just unreal..... Wow. That's beautiful. Wow. That's... a lot of work!!!
Post by jcoutu1 on Jul 9, 2014 20:52:16 GMT -6
What's that desk? An Icon? I can't make it out on my phone.
Post by Johnkenn on Jul 10, 2014 7:45:17 GMT -6
Yes...last I saw, though, they had an SSL in there, though.
Post by ericn on Jul 10, 2014 8:34:18 GMT -6
Looks good John! Ill say it again if your going to build a bunch, build a reverse diffuser as a jig and I would rather use a small bandsaw for this than miter!
Post by tonycamphd on Jul 10, 2014 8:46:55 GMT -6
Looks good John! Ill say it again if your going to build a bunch, build a reverse diffuser as a jig and I would rather use a small bandsaw for this than miter! Jig is a good idea E, I used a miter/radial arm chop saw to cut mine, I set up a stop block and chopped enough pieces for 6 at a time.
Post by Johnkenn on Jul 10, 2014 9:01:40 GMT -6
Wtf is a jig? Reverse?
Post by jcoutu1 on Jul 10, 2014 10:27:04 GMT -6
Looks good John! Ill say it again if your going to build a bunch, build a reverse diffuser as a jig and I would rather use a small bandsaw for this than miter! Jig is a good idea E, I used a miter/radial arm chop saw to cut mine, I set up a stop block and chopped enough pieces for 6 at a time. I'm with Johnkenn, what's this reverse diffuser/jig business? Wouldn't the chop saw with a stop block be the best bet? ...obviously I'm not a carpenter.
Post by tonycamphd on Jul 10, 2014 10:52:57 GMT -6
Jig is a good idea E, I used a miter/radial arm chop saw to cut mine, I set up a stop block and chopped enough pieces for 6 at a time. I'm with Johnkenn, what's this reverse diffuser/jig business? Wouldn't the chop saw with a stop block be the best bet? ...obviously I'm not a carpenter. yes, a sliding radial arm chop saw is the easiest way to cut these(i think that's what Eric is saying?), a band saw requires you pushing the wood through the blade, that would be rough. If you build an inverse diffusor(you need at least one inverse of these for every 6 standards that you build, or you get what is called frequency "lobe-ing"), you can put the blocks agains the inverse blocks, and combined, it should make a perfect big square block, then you could apply glue on the back plate, and set it on the top of the whole block, and flip it over, let it dry, and pull the 2 diffusors apart. at least that is what i think Eric's saying? i personally would just set up a square 90 degree fence(back stops) and glue one at a time for tidiness, and clarity sake.
Post by jcoutu1 on Jul 10, 2014 11:16:48 GMT -6
