Post by bluesholyman on Jul 5, 2023 6:47:54 GMT -6
I have a Pro Tools Carbon interface and I am wondering if fronting it with a tube mic pre is worth the expense, given the Carbons real time DSP processing capabilities and a good AAX-DSP plugin used during tracking.
I am leaning towards a UA 610 Solo, for now, but in the distant past (15 years ago) have used an Avalon 737sp as my pre - just can't do THAT kind of spend right now.
OR, should I just invest in some good plugins and live in the box. I must confess, warm glowing outboard gear is theraputic. I don't know that I am completely convinced (in my mind) that a full digital path is as "nice" as having the analog gear in the signal chain, a tube mic pre specifically, for the purpose of this dicussion.
Would appreciate your input/thoughts.
Thanks, BHM
Post by drumsound on Jul 5, 2023 8:49:22 GMT -6
I generally cut vocals with a tube pre, but everything else with my console pres. I do think tubes bring something to the party. What type of tracking are you doing?
Post by bluesholyman on Jul 5, 2023 9:04:18 GMT -6
I generally cut vocals with a tube pre, but everything else with my console pres. I do think tubes bring something to the party. What type of tracking are you doing? Acoustic guitar (Martin D-35 and Teton parlor,) vocals, mando, eventually a violin/fiddle etc., for country song demos. This will largely be of myself to get demo ideas across but I want the demos to be good/high quality. I want to get gear to grow into (hence the Carbon) that will last me a while and not just stop-gap pieces. I intend to use this gear and my acquired skills for other songwriters I work with going forward. I also have a vintage ribbon I want to use and it takes an inline booster and maxing the Carbon's gain to get a good signal on it. Part of having a [tube] pre is to acquire some extra gain going into the Carbon for ribbons.
Post by crillemannen on Jul 5, 2023 9:47:58 GMT -6
I generally cut vocals with a tube pre, but everything else with my console pres. I do think tubes bring something to the party. What type of tracking are you doing? Acoustic guitar (Martin D-35 and Teton parlor,) vocals, mando, eventually a violin/fiddle etc., for country song demos. This will largely be of myself to get demo ideas across but I want the demos to be good/high quality. I want to get gear to grow into (hence the Carbon) that will last me a while and not just stop-gap pieces. I intend to use this gear and my acquired skills for other songwriters I work with going forward. I also have a vintage ribbon I want to use and it takes an inline booster and maxing the Carbon's gain to get a good signal on it. Part of having a [tube] pre is to acquire some extra gain going into the Carbon for ribbons. Check out my WT72 test. Lovely sounding preamp that gives you that open tubesound.
Post by Vincent R. on Jul 5, 2023 10:32:14 GMT -6
I have a Carbon as well. I primarily track through outboard preamps. Most of mine are Neve based. As for tube preamps, I owned a UA 610 a while back. It was nice, but I'd look at the Weight Tank WT72. I had owned a Tab Funkenwerk V78, which was their modern take on the V72, and preferred that preamp.
Post by bluesholyman on Jul 5, 2023 10:40:40 GMT -6
I have a Carbon as well. I primarily track through outboard preamps. Most of mine are Neve based. As for tube preamps, I owned a UA 610 a while back. It was nice, but I'd look at the Weight Tank WT72. I had owned a Tab Funkenwerk V78, which was their modern take on the V72, and preferred that preamp. I probably should not discount discrete preamps, but I love warm glowy things. The heritage audio mic pre's have peaked my interest as a possible option at a reasonable price. I am certainly open to broader suggestions than just tube pre's, even though that is what I said.
Post by Vincent R. on Jul 5, 2023 10:53:01 GMT -6
I have a Carbon as well. I primarily track through outboard preamps. Most of mine are Neve based. As for tube preamps, I owned a UA 610 a while back. It was nice, but I'd look at the Weight Tank WT72. I had owned a Tab Funkenwerk V78, which was their modern take on the V72, and preferred that preamp. I probably should not discount discrete preamps, but I love warm glowy things. The heritage audio mic pre's have peaked my interest as a possible option at a reasonable price. I am certainly open to broader suggestions than just tube pre's, even though that is what I said. I'm using the AMS Neve 1073 DPX and a reracked 1272 by Dan Alexander. Both are great if you like that sound. The Heritage has my interest peaked as well with their Super 8 that I could add to the Carbon for 8 more Neve Pres over ADAT. Its not cheap, although not badly priced for what you get.
Post by Blackdawg on Jul 5, 2023 12:57:26 GMT -6
Try it. No one here knows what you like but you.
Get a pre and try it. Use your ears, you'll know if you like it or not.
I'd bet you'll find you like it on some things. And on others, the built in pre's will be great.
Post by ericn on Jul 5, 2023 13:49:13 GMT -6
I probably should not discount discrete preamps, but I love warm glowy things. The heritage audio mic pre's have peaked my interest as a possible option at a reasonable price. I am certainly open to broader suggestions than just tube pre's, even though that is what I said. I'm using the AMS Neve 1073 DPX and a reracked 1272 by Dan Alexander. Both are great if you like that sound. The Heritage has my interest peaked as well with their Super 8 that I could add to the Carbon for 8 more Neve Pres over ADAT. Its not cheap, although not badly priced for what you get. Your Dan Alexander is the later one with Dans boards and vintage transformers just like all 4 of mine. The Reracked module version has a slightly different faceplate layout, I also think a different PSU. If a preamp works I don’t care if it’s chip based, Solid state or tube, just that it works . Search for tone not topology. Selling topology is easy, but probably not really a solution.
Post by thehightenor on Jul 5, 2023 13:50:43 GMT -6
Tube pre = Coil CA-70.
Getting a Coil CA-70 has been for me (and a hate this expression) "a game changer" .... there said it.
Post by Deleted on Jul 5, 2023 14:38:54 GMT -6
I have a Pro Tools Carbon interface and I am wondering if fronting it with a tube mic pre is worth the expense, given the Carbons real time DSP processing capabilities and a good AAX-DSP plugin used during tracking. I am leaning towards a UA 610 Solo, for now, but in the distant past (15 years ago) have used an Avalon 737sp as my pre - just can't do THAT kind of spend right now. OR, should I just invest in some good plugins and live in the box. I must confess, warm glowing outboard gear is theraputic. I don't know that I am completely convinced (in my mind) that a full digital path is as "nice" as having the analog gear in the signal chain, a tube mic pre specifically, for the purpose of this dicussion. Would appreciate your input/thoughts. Thanks, BHM There are no great aax dsp tube plugins. AAX DSP was a dead on arrival plugin format and very few things were rewritten to be low latency and most developers went fully native after TDM. Most of the aax dsp plugins add more latency than native versions. Only the Sonnox Oxford plugins have less latency in AAX DSP running on those HDX cards than stock Avid plugins while sounding a great deal better but the Oxford “warmth” and Inflator are the last things I would use if you want subtle tube sound. The Sonnox aax dsp plugins still add more latency than the native versions. Why not just use something like sdrr2, Tupe, or a fuse plug in the mix? Modern x86 and ARM CPUs run circles around the TI DSP chips in the HDX cards. Or buy a separate pre that’s just much better than a UA610 or an interface pre. There are a ton of them.
Post by svart on Jul 5, 2023 14:50:06 GMT -6
What mic?
I'd say not to worry about a tube pre. I'm all about the U87 into an API preamp and into an 1176. It just works.
Post by thehightenor on Jul 5, 2023 14:58:15 GMT -6
What mic? I'd say not to worry about a tube pre. I'm all about the U87 into an API preamp and into an 1176. It just works.You wouldn't say that if you tried to record me with a U87 > API > 1176. I'd have all your fillings out by the end of the song :-)
Post by the other mark williams on Jul 5, 2023 15:42:53 GMT -6
Tube pre = Coil CA-70. Getting a Coil CA-70 has been for me (and a hate this expression) "a game changer" .... there said it. While the Coil is certainly fantastic, if the OP can't spend for an Avalon 737, it's unlikely he's looking to spend Coil money, either. If he's considering a UA 610, I personally think the WT-72 is far superior.
Post by the other mark williams on Jul 5, 2023 15:46:06 GMT -6
I have a Pro Tools Carbon interface and I am wondering if fronting it with a tube mic pre is worth the expense, given the Carbons real time DSP processing capabilities and a good AAX-DSP plugin used during tracking. I am leaning towards a UA 610 Solo, for now, but in the distant past (15 years ago) have used an Avalon 737sp as my pre - just can't do THAT kind of spend right now. OR, should I just invest in some good plugins and live in the box. I must confess, warm glowing outboard gear is theraputic. I don't know that I am completely convinced (in my mind) that a full digital path is as "nice" as having the analog gear in the signal chain, a tube mic pre specifically, for the purpose of this dicussion. Would appreciate your input/thoughts. Thanks, BHM I don't think you'd ever regret having an external pre (or several, even). Plugins have come a long way, but they still can't replace high quality pres. I'm going to agree with others, however, and say I'd take a look at the WT-72 if you really want a tube pre. It's far more versatile than the UA 610. Not that the 610 is bad, per se, just that the WT-72 works really, really well on a lot of sources. I've owned both. I still own the WT-72.
Post by drumsound on Jul 5, 2023 16:08:09 GMT -6
For a single channel tube pre that doesn't get a lot of talk the Useful Arts AFP 30 is really cool. I have the stereo version. There is standard input and output, but also a control for color that I believe is driving a separate tube.
Post by bluesholyman on Jul 5, 2023 17:03:38 GMT -6
What mic? I'd say not to worry about a tube pre. I'm all about the U87 into an API preamp and into an 1176. It just works. I don't have much yet. The ones maybe worth speaking of: LA-320, Warbler MKIII, and I have a Lewitt 840 on the way. I suspect I'll spend most of my time using the Lewitt and probably the Warbler from time to time, but I could be wrong - just depends upon what sounds best in the chain after experimenting.
Post by Blackdawg on Jul 5, 2023 17:54:47 GMT -6
I will say I've never ever liked the UA610 pre sounds. The modern ones are not great IMO. I'd use the Carbon pres over those any day.
The WT though one i'm sure is good.
Post by Vincent R. on Jul 5, 2023 19:44:52 GMT -6
I did like the 610 with my Altec 639 Ribbon. I’ll say that.
Post by subspace on Jul 5, 2023 19:56:01 GMT -6
I record on a Carbon, the pres are nice if you're looking for a transparent design, but if I'm close mic'ing a drum shell, guitar speaker, or rock vocal, I'm gonna use a Neve or Trident console module instead. The AAX DSP channel strips are nice utility plug-ins, but they aren't gonna re-create a mic plugged into a discrete pre.
Post by the other mark williams on Jul 5, 2023 19:58:01 GMT -6
I did like the 610 with my Altec 639 Ribbon. I’ll say that. And I liked it with my U195. I had a fairly early Soundelux U195 with a capsule that could get overly bright at times. The 610 helped darken it up and smooth it out.
Post by wiz on Jul 5, 2023 19:58:26 GMT -6
The thing I notice most about good tube preamp ( I have a seimens v72) is with dynamic mics that’s where the quality of the mic seems to jump up
Cheers
Post by EmRR on Jul 5, 2023 20:07:56 GMT -6
The thing I notice most about good tube preamp ( I have a seimens v72) is with dynamic mics that’s where the quality of the mic seems to jump up Cheers Wiz The varying impedance versus frequency frequently does favorable things that you don't get from the flat impedance of a transformerless preamp. The greater the turns ratio (as found in tube pre's) the greater the effect. For better or worse. Ribbons tend to prefer it. Plus, free 'noiseless' transformer gain over 20dB. Hard to beat.....unless you have a hot condenser then you've got the opposite problem.
Post by thehightenor on Jul 6, 2023 1:28:04 GMT -6
Tube pre = Coil CA-70. Getting a Coil CA-70 has been for me (and a hate this expression) "a game changer" .... there said it. While the Coil is certainly fantastic, if the OP can't spend for an Avalon 737, it's unlikely he's looking to spend Coil money, either. If he's considering a UA 610, I personally think the WT-72 is far superior. Sometimes you just gotta hold off and save for longer and get that “special something” piece, it’s so worth the wait imho.
Post by Vincent R. on Jul 6, 2023 6:09:37 GMT -6
I'm using the AMS Neve 1073 DPX and a reracked 1272 by Dan Alexander. Both are great if you like that sound. The Heritage has my interest peaked as well with their Super 8 that I could add to the Carbon for 8 more Neve Pres over ADAT. Its not cheap, although not badly priced for what you get. Your Dan Alexander is the later one with Dans boards and vintage transformers just like all 4 of mine. The Reracked module version has a slightly different faceplate layout, I also think a different PSU. If a preamp works I don’t care if it’s chip based, Solid state or tube, just that it works . Search for tone not topology. Selling topology is easy, but probably not really a solution. This is true. I just find reracked 1272 easier to say than 1272 with vintage transformers and replacement boards.
