Post by bikescene on May 12, 2023 6:55:37 GMT -6
I’m curious to see how you guys approached front wall treatment in your spaces. I’ve seen some control rooms with a lot of absorption, some with diffusion, and some bare. Did you focus on the corners, other walls, and ceiling instead?
I’m using JBL LSR305 speakers at home. I moved the speakers closer to the wall from 12” to 4” and it evened out nulls in the 100-140Hz range. There is a block wall 6” behind the front drywall, so I suppose the block wall is the the actual surface reflecting all of the low frequencies.
I was originally going to make two panels to put behind the speakers when they were 12” off the wall. However, placing a 4” 703 panel directly behind the speakers did not seem to help in that 100Hz range.
Post by svart on May 19, 2023 14:25:21 GMT -6
I just put a few 4" thick panels on the front wall. Mainly behind the speakers. I did it mainly for reflections, not balancing out the room modes.
Post by bgrotto on May 20, 2023 0:00:59 GMT -6
My favorite sounding control rooms typically have a lot of broadband absorption in the front wall, and/or soffited speakers
Post by Ward on May 21, 2023 16:54:26 GMT -6
Still believe in LEDE Here is my control room front wall, 13 ply oak plywood over rockwool and 2x6 studs, sheeting and sealing  and my main live room front wall. stone.
Post by Bob Olhsson on May 22, 2023 7:21:26 GMT -6
A couple thousand LPs has always worked for me!
Post by bikescene on May 22, 2023 13:05:02 GMT -6
I think I’ll add some more absorption on the front wall sooner rather than later. I’ve put up some absorption around my room, but my front wall is pretty bare for now.
Post by jcoutu1 on May 22, 2023 15:28:25 GMT -6
Post by Ward on May 23, 2023 6:16:22 GMT -6
Oh yes, part of the junk pile! There's also a 1995 Powermac 8100 behind the Palindrometer and it sits atop a 1992 Panasonic DAT machine (one of 3 defunct ones)
Post by subspace on May 28, 2023 1:21:07 GMT -6
Oh yes, part of the junk pile! There's also a 1995 Powermac 8100 behind the Palindrometer and it sits atop a 1992 Panasonic DAT machine (one of 3 defunct ones) While my front wall is simple burlap over fiberglass from floor to ceiling, I also employ a PowerMac 8100AV as a speaker stand for the JVC boombox, due to it's widely renowned acoustic properties of course.
Post by Ward on May 30, 2023 12:26:36 GMT -6
Only proving that those old macs last forever, including their second life repurposing.
Post by jmoose on May 30, 2023 18:07:04 GMT -6
This seems appropriate... 20 odd minute video showing BOP studios in various stages of construction. Tom Hidley room. Everything is exposed here including the massively deep bass trapping. Hidden behind / built into walls. And an old SOS piece on the studio w/ some pictures & from the hip floor plans etc. www.soundonsound.com/music-business/bop-studios-storyGood stuff!
