Pretty substantial update to auto align 2!!
Dear Auto-Align 2 users,
Thank you for your continued support and feedback.
We are excited to announce the release of Auto-Align 2.1 beta! This new version includes a number of new features and bug fixes, including:
New features:
Alternative group alignment timing modes: You can now choose between three different timing modes for group alignments: Optimal, Minimal, and Off.
Spectral phase optimization per-track toggle: You can now enable or disable spectral phase optimization on a per-track basis.
Four preset banks: You can now save up to four different preset banks for easy comparison of different alignments.
Import/export alignment state: You can now import and export the alignment state of a project.
Per-group flip polarity toggle: You can now flip the polarity of a group of tracks with a single click.
Sum to mono of multi-channel tracks: You can now sum multi-channel tracks to mono.
Improved groups lock/unlock workflow: The groups lock/unlock workflow has been improved for easier and more intuitive use.
Improved reset options: The reset options have been improved to give you more control over how the alignment is reset.
Improved edit menu: The edit menu has been improved to make it easier to find the commands you need.
Improved capture indicator in UI: The capture indicator in the UI has been improved to make it easier to see when audio is being captured.
Improved alignment invalid notifications and warnings: The alignment invalid notifications and warnings have been improved to make them more informative and helpful.
Offset view is now saved as a global setting: The offset view is now saved as a global setting, so you don’t have to change it every time you open a new project.
Bug fixes:
ARA: Report tail/head for sample accurate playback
ARA: Support Cakewalk
ARA: Fix memory leak under Logic Pro X
ARA: Fix possible crash under Logic Pro X
ARA: Fix inconsistent results when using multi-mono under Nuendo and Cubase
VST3: Fix FL Studio instances are always mono (Mono available using sum to mono)
Fix: Ensure sample offset is calculated at project sample-rate
Fix track order when switching between manual and auto groups
Please note:
As with any beta software, it is important to back up your existing projects before using this version.
Under the hood, we have made many improvements that required us to change the way we save alignments. Projects saved with Auto-Align 2.1 onwards are not compatible with Auto-Align 2.0.1.
forum.soundradix.com/t/auto-align-2-1-0-public-beta-1/1973
