Post by Johnkenn on Apr 10, 2023 12:27:52 GMT -6
An oldie but a goodie. Anyone have opinions if 500 series mic pres have limitations vs 19” with dedicated Ps?
Post by EmRR on Apr 10, 2023 12:34:28 GMT -6
No they do not in regards to power. Apples to apples, this has been soundly disproven as a limiting factor. Apples to oranges, sure, get in the weeds about the type of PSU. More important if a rack version has a larger audio transformer than will fit in a 500 version, sometimes the case....and you might like the smaller transformer better!
Post by Blackdawg on Apr 10, 2023 12:44:05 GMT -6
My experiance is that it has more to do with the PSU of the 500 rack than anything. Not all are created equal. Vs a rack mount pre the designer(hopefully) made the PSU good and up to their standards. Otherwise if you make a 500 series anything you're at the mercy of whatever the user plugs it into.
Could be a good unit. Could be a bad one.
So as long as you have one of the good Racks(Purple, CAPI, TAC, Lindell, RND,ect) then no, I don't think it matters.
Post by ericn on Apr 10, 2023 13:33:15 GMT -6
3 factors 1. Voltage, most modules that were designed for +-15 are fine in 500 format. Yeah Voltage can work but not as well. 2. Current , it always matters, Now some of us don’t have this problem when an old DDA XL series PSU is powering a 500 rack. 3. The physical design and part choices in the rack units just won’t fit in 500 series. This is why the Great River is 2spaces!
Post by EmRR on Apr 10, 2023 13:56:02 GMT -6
500 pre’s in racks with an outboard supply probably have a lower noise floor than a rack with PSU built in , sheer proximity factor. Also why people like cloudlifter type devices, the gain is not near the PSU.
Post by drbill on Apr 10, 2023 14:00:48 GMT -6
500 is fine. The differences will be in the topology and design of the unit itself - not in the form factor of the delivery medium. The exception - tube mic pre's. You need a lot more juice to the tubes, and a rack mount unit is way more accessible to doing that.
Post by ironinthepath on Apr 23, 2023 7:41:57 GMT -6
As an EE doing analog for a living, my feeling is this: 1. Does the mic pre have input and/or output transformers? If so, can they fit those transformers into the 500 series form-factor or are compromises required? It is my understanding that API generally uses same transformer for preamp regardless of 19 inch or 500 series…but I know for a fact that at least one company has significantly different transformers in a 500 series version of the preamp, and I can tell a difference in low-end behavior; I’d bet it’s measurable (but I did not take any measurements)
2. Does the circuit topology used have any major trade-off with +\- 16V (IIRC that’s the 500 series spec) or could some modest incremental performance benefit come along with even higher supply voltages (distortion or otherwise)? Example: my memory is that quad eight and newest RND preamps in 19 inch format use +\- 24V… I can’t imagine that being anything other than a carefully crafted design choice: it costs more to implement high voltage circuitry in almost every case.
3. There are design implementations that can make the supply voltage difference much less impactful. (A) Some companies use compact DC-DC converters (I’ve seen at least one switched-capacitor AKA charge pump implementation) to locally boost the internal supply voltage for a subset of circuits in the 500 series version - as long as switching-noise and ripple are handled appropriately, no big deal. (B) Another common approach is modifying a “single-supply” 24V circuit (using capacitor coupling) so it operates with +\-16V using the negative supply as its ground-like reference, basically like 16V - -16V = 32V supply. In at least one case I’ve noticed that the designer put an RC circuit in the “ supply path” (Like old vacuum tube amps) so that with the I*R drop the supply voltage “seen” by the circuit at audio frequencies is still 24V. (C) “fully-differential” signaling is used by the designer, which effectively doubles the allowable signal swing for the same supply voltage. This is routinely used in chip design (single-ended circuits are the exception) to take advantage of matching, operate with cell phone battery voltage of 3.7V and below, and to improve THD since 2nd harmonic effectively canceled in these circuits. I believe Buzz Audio designs (still using discrete transistors) do this.
In the end, there are too many variables to simply state that 19 inch vs. 500 series differences “matter “ or “don’t matter”. Since we’re not all going to get to talk with the original circuit designer, etc…and even if we did: We just have to use our ears :-)
Update (a few days later): the above points are assuming that the 500 series power-supply in use is capable of providing the preamp unit's or units' the appropriate amount of current/power at the +/- 16V and with minimal interaction between channels (channel "isolation")! All bets are off if supply isn't operating properly.
Post by javamad on Apr 24, 2023 2:25:07 GMT -6
I have BAE and UA rackmount pres and API and RND 500 series in an RND chassis.
I don’t think about it and they all sound great.
I certainl could not have acomodated all the pres I have in 500 series in rack format due to space in my desk … so even if there were some slight difference I would have still made the same choices.
Post by Ward on Apr 24, 2023 13:55:13 GMT -6
Most of the early issues have been sorted out and 500 series units being "considerably power-starved and weaker" is mostly in the past when comparing apples to apples.
Post by Deleted on Apr 24, 2023 15:35:23 GMT -6
They’re all better than +/- 5v ti pga2500 pres
Post by ericn on Apr 24, 2023 15:40:57 GMT -6
Most of the early issues have been sorted out and 500 series units being "considerably power-starved and weaker" is mostly in the past when comparing apples to apples. Or you just run a big old DDA / Midas console supply all trimmed out, never heard the words starving for current.
Post by copperx on Apr 25, 2023 15:49:29 GMT -6
I'd like to know if the BAE 500 series MPL preamp sounds like the BAE DMP. Has anybody tried the BAE 500 series?
Post by core64 on Apr 25, 2023 19:51:12 GMT -6
I'd like to know if the BAE 500 series MPL preamp sounds like the BAE DMP. Has anybody tried the BAE 500 series? I don’t have those specific models but do have the BAE 1073D (500 series) and their rack mount 1073 and don’t hear any difference at all.
Post by copperx on Apr 25, 2023 22:44:29 GMT -6
I'd like to know if the BAE 500 series MPL preamp sounds like the BAE DMP. Has anybody tried the BAE 500 series? I don’t have those specific models but do have the BAE 1073D (500 series) and their rack mount 1073 and don’t hear any difference at all. That's fantastic to hear. Thank you.
