Post by robsmith on Mar 2, 2023 20:05:06 GMT -6
I am a one man shop and can't afford yet to go with an argosy desk. However, I need something larger, having used a smaller desk with two 4U racks for years. I do have the side car so rack space is generous but workspace is not and I not only mix but also do my day job at my desk.
Looks like I'd have to spend $1500 just to get started with a decent size like with the Rab ProRack M88. Even then the workspace depth is not awesome.
So, I have ordered three natural colored Gator 4U desktop racks. I am going to grab a natural (Pine colored) desktop (72"x36") and build legs and supports with black iron piping. All in, it will be about $700 which is crazy considering the end result: 12U's on the desk and lots of real estate to work on.
Anyone done something similar?
Post by tahoebrian5 on Mar 2, 2023 23:36:08 GMT -6
You can buy premade legs. I did something similar recently.
Post by Tbone81 on Mar 3, 2023 10:57:26 GMT -6
I built my desk by using two (store bought) 12u rolling racks. Those are the “legs”, then I used a nice piece of 5/8” plywood, sanded, stained and clear coated. And then built two 4u racks on top of the desk.
The racks were the most expensive part. They were about $500 each. But I figured if I outgrow this setup, or move to a new space that needed a different setup then I could take the table top off and use the racks in a new configuration.
Post by robsmith on Mar 3, 2023 20:16:50 GMT -6
You can buy premade legs. I did something similar recently. Yes, I saw some on amazon. Thanks!
Post by robsmith on Mar 3, 2023 20:18:24 GMT -6
I built my desk by using two (store bought) 12u rolling racks. Those are the “legs”, then I used a nice piece of 5/8” plywood, sanded, stained and clear coated. And then built two 4u racks on top of the desk. The racks were the most expensive part. They were about $500 each. But I figured if I outgrow this setup, or move to a new space that needed a different setup then I could take the table top off and use the racks in a new configuration. how wide is your desk and how does the 5/8" do - does it flex much? I see a 1.5" butcher block top at HD for $169. Seems really heavy and don't think I need 1.5"
Post by tahoebrian5 on Mar 3, 2023 23:15:20 GMT -6
I used 1.5” butcher block that I got from Home Depot. It was 4’x8’ but I cut it down to 42”x7’ if I remember correct. I don’t think I would want to use 5/8.. seems like it would have some flex, and beyond that not much meat for the leg screws.
Post by Tbone81 on Mar 4, 2023 17:14:35 GMT -6
I built my desk by using two (store bought) 12u rolling racks. Those are the “legs”, then I used a nice piece of 5/8” plywood, sanded, stained and clear coated. And then built two 4u racks on top of the desk. The racks were the most expensive part. They were about $500 each. But I figured if I outgrow this setup, or move to a new space that needed a different setup then I could take the table top off and use the racks in a new configuration. how wide is your desk and how does the 5/8" do - does it flex much? I see a 1.5" butcher block top at HD for $169. Seems really heavy and don't think I need 1.5" I don’t remember the exact dimensions but it’s pretty close to three 19” rack cases wide, if that makes sense. The plywood holds up good and doesn’t really flex but I’ve thought of adding a middle support leg for safety. If I did it again I’d buy butcher block
Post by robsmith on Mar 4, 2023 19:44:22 GMT -6
how wide is your desk and how does the 5/8" do - does it flex much? I see a 1.5" butcher block top at HD for $169. Seems really heavy and don't think I need 1.5" I don’t remember the exact dimensions but it’s pretty close to three 19” rack cases wide, if that makes sense. The plywood holds up good and doesn’t really flex but I’ve thought of adding a middle support leg for safety. If I did it again I’d buy butcher block OK, I spent time at Home Depot chatting with the old timers. Here's what I grabbed. I got a sheet of 3/4" Maple Plywood cut down to 6x3. I will use the cut scraps to 1) do a center brace, left to right and 2) build up where the legs will attach. It will make those places 1.5". will clear coat on top and add a front trim. I'm told I should be bale to stand on it when done - lol. Now I have choose the legs off amazon. i also got 3ea 4U Gator racks. They have arrived so I have to get busy.
Post by robsmith on Mar 4, 2023 20:09:17 GMT -6
Post by Omicron9 on Mar 5, 2023 11:53:22 GMT -6
