Post by kcatthedog on Feb 25, 2023 10:41:32 GMT -6
As Luna does not have inserts (yet!), I had thought you couldn’t use OB on say your 2 bus.
But, a post today at ua forum by slamthecrank, describes this workaround:
“Simply engage ARM mode (if it's not already on), change the output of the track you wish to process with hardware to one of the outputs on your Apollo // create a new audio track and set its input to the corresponding input(s) on your Apollo // select the "I" for input monitoring and the "R" for record-enable on your new audio track in Luna and adjust your hardware how you want it while your project plays // when you're happy with your hardware settings, record the track using the standard Record + Play in the transport.”
Post by Johnkenn on Feb 25, 2023 11:15:34 GMT -6
Yeah the delay doesn’t matter on the master bus.
Post by kcatthedog on Feb 25, 2023 11:25:47 GMT -6
Didn’t know: thx!
Drew confirmed at ua forum too.
Wonder if I can record in luna without an apollo ?
Post by sirthought on Feb 25, 2023 14:05:56 GMT -6
Didn’t know: thx! Drew confirmed at ua forum too. Wonder if I can record in luna without an apollo ? You can, but you still have to own an Apollo at this point to get access to LUNA. But you could track through your Lynx and have a mix bus chain going to the Main Bus in LUNA. And...they've handicapped LUNA so that on Core Audio option the lowest rate you can choose is 128. This isn't really a problem for me much of the time, but it's annoying that they purposely made it so Apollo would always have lower latency in that DAW.
Post by kcatthedog on Feb 25, 2023 14:28:10 GMT -6
That’s what I thought, I’d experiment with L if it was easy, and I’n curious about the next apollo, but won’t be selling my aurora N anytime soon.
I get everything I want done in logic.
Also, I won’t reiterate my issues with UA, but I did list my octo and plugs , so I’m as close to out the ua door as you can get.
Post by sirthought on Feb 26, 2023 19:42:01 GMT -6
What kind of latency do you get the Aurora N?
