M2 pro
Feb 23, 2023 15:47:56 GMT -6
via mobile
Post by kcatthedog on Feb 23, 2023 15:47:56 GMT -6
round 3g app memory 1 wired memory 4.8 memory used 5 cached files 0 Swap
Interesting.
M2 pro
Feb 23, 2023 18:47:10 GMT -6
Post by EmRR on Feb 23, 2023 18:47:10 GMT -6
interesting, much lower.
Studio M1 has 64GB. Shut everything off, Avid Link still running in background, 7GB app and 10GB total.
Post by wiz on Feb 23, 2023 19:34:40 GMT -6
interesting, much lower. Studio M1 has 64GB. Shut everything off, Avid Link still running in background, 7GB app and 10GB total. I have 8Gb M1... similar to Kkcat's cheers Wiz
M2 pro
Feb 24, 2023 7:06:45 GMT -6
via mobile
Post by kcatthedog on Feb 24, 2023 7:06:45 GMT -6
It seems odd to have a 25-30% system background operations memory tax, ie, only 70-75% of memory is actually available?
Post by brenta on Feb 24, 2023 8:09:52 GMT -6
The “Memory Pressure” stat is the one that’s important, along with “Swap Used”. If “Memory Pressure” goes into the yellow or red, then you are suffering performance degradation. “Swap Used” means your computer has had to use the hard drive to compensate for low RAM at times. Macs are engineered to try to use extra, unused RAM to provide better and snappier performance, so you may see some RAM being “used” even though it’s still available. support.apple.com/guide/activity-monitor/check-if-your-mac-needs-more-ram-actmntr34865/10.14/mac/12.0
M2 pro
Feb 24, 2023 9:01:25 GMT -6
via mobile
Post by kcatthedog on Feb 24, 2023 9:01:25 GMT -6
Understood, so low pressure and no swaps, also means soc ram is sufficient for demand
Post by EmRR on Feb 24, 2023 11:10:15 GMT -6
M1 MBP has 32
Open: Safari, Messages, Notes, Calendar, Activity Monitor, background is Avid Link, Dropbox, Drive.
App memory 16 wired memory 2 compressed 0.25 total 19
cached files 12.5 swaps 0 memory pressure looks like less than 10%
It is the first laptop I've owned that will so far open and run (without severe groaning) the most complex DAW session I ever make on the studio desktop.
M2 pro
Feb 25, 2023 18:26:40 GMT -6
Post by EmRR on Feb 25, 2023 18:26:40 GMT -6
M1 Studio 64GB
open: RX10, DP, messages, calendar, chrome, safari, music, Spotify, notes, textedit, activity monitor, avid link
RX10 crunching 6 parallel music rebalance files
App memory 46 wired memory 3 compressed 0 total 49
cached files 13 swaps 0 memory pressure looks like 5-10%
M2 pro
Mar 4, 2023 4:27:38 GMT -6
via mobile
Post by kcatthedog on Mar 4, 2023 4:27:38 GMT -6
Interesting stats, cpu/gpu and disc speeds 4-5 minutes
256 under 1500 RW
512 round 3000 RW
1Tb round 6000 RW ( but most expensive
M2 pro 512 best value ?
M2 pro
Mar 19, 2023 7:41:19 GMT -6
via mobile
Post by kcatthedog on Mar 19, 2023 7:41:19 GMT -6
