Post by kcatthedog on Nov 17, 2022 5:43:38 GMT -6
I was thinking of how much I liked @shadow’s Bettermaker limiter.
I found it had this somewhat bigger then life glassy sound: both focussing and opening up the mix.
Was wondering whose running an ob limiter on their 2 bus, which ones, why and cost?
thx!
Post by Ward on Nov 17, 2022 7:19:36 GMT -6
If I want glassy and bigger than life outboard, I turn to my Focusrite Red 3 (and I usually pair it with the Red 2 for any EQ correction pre-comp)
Post by Ward on Nov 17, 2022 7:30:21 GMT -6
P.S. you can see both units in the second bay of my main rack. Red ones (duh) in the top.
Post by recordingengineer on Nov 17, 2022 11:36:03 GMT -6
I keep on meaning to play more with the Red 2 and 3… They’ve been sitting next to me, all hooked up, the past 4 years!
Post by Deleted on Nov 19, 2022 7:08:46 GMT -6
I was thinking of how much I liked @shadow’s Bettermaker limiter. I found it had this somewhat bigger then life glassy sound: both focussing and opening up the mix. Was wondering whose running an ob limiter on their 2 bus, which ones, why and cost? thx! You should hear it in M/S mode Matt with about 7% even harmonic distortion set around the 2 - 4K region. It's not subtle and that's what I love about it..
That being said I've also incorporated a Neve MBP into the equation, I could probably use either or but it's nice to take some load off the Bettermaker Mastering Limiter.
Post by lowlou on Nov 21, 2022 5:44:48 GMT -6
I'm curious about the HUM LAAL limiter. I'm mentally conditioning myself to spend 9k€ for it, at some point.
Post by kcatthedog on Nov 21, 2022 6:28:06 GMT -6
Ubu !
