Post by OtisGreying on Sept 29, 2022 0:46:52 GMT -6
I'm going to construct absorption panels for my vocal recording area in my house/studio. About three 5-6 foot tall panels, situated in a sort of gobo kind of shape for the vocalist to stand/sit in front of. I was thinking of going 7-8 inches deep of mineral wool with open backs for each panel to absorb lower frequencies for male voice. Does that sound like overkill? All gobos for sale don't go nearly as deep as I would think is necessary to get a clean low end for a deeper voice.. All suggestions are appreciated!!
Post by nobtwiddler on Sept 29, 2022 6:58:25 GMT -6
Also remember, Proper treatment behind the vocalist, facing the microphone, can be as important as what's behind !
Post by drumsound on Sept 29, 2022 7:51:39 GMT -6
Also remember, Proper treatment behind the vocalist, facing the microphone, can be as important as what's behind ! That's what I was thinking too.
Post by svart on Sept 29, 2022 8:16:06 GMT -6
I'm going to construct absorption panels for my vocal recording area in my house/studio. About three 5-6 foot tall panels, situated in a sort of gobo kind of shape for the vocalist to stand/sit in front of. I was thinking of going 7-8 inches deep of mineral wool with open backs for each panel to absorb lower frequencies for male voice. Does that sound like overkill? All gobos for sale don't go nearly as deep as I would think is necessary to get a clean low end for a deeper voice.. All suggestions are appreciated!! Complete overkill if your only goal is to improve vocals. Extremely large and thick panels would only be necessary if you're trying to block instruments with much higher power levels than the human voice. Absorption isn't always about depth and overall size of the panel. Placement is key. The second part you're likely not aware of is that distance is as important as panel specs. If you place the vocal area in the middle of the room and place a few small panels in key areas (V shaped behind mic to cut reflections at the cardioid lobes, as well as one or two behind the vocalist, that could literally be all you need. The distance from the mic to the panel cuts the incident signal before it can reflect, and the distance between the panel and the wall will reduce the power of the reflections so that the panel will reduce the reflection to almost nothing. 4" thick panel of medium density mineral wool would be plenty. What I ended up doing was making 2'x4'x4" panels and using conduit hangers and eye bolts to hang them on mic stands. The stands make the panel heights adjustable and I can center the panel on the mouth-to-mic axis.
Post by Tbone81 on Sept 29, 2022 8:20:25 GMT -6
A 6' tall gobo thats 8" thick with rigid/dense mineral wool is going to be pretty heavy. That's probably the reason you don't see any for sale, that size isn't always practical. The gobos I've seen that are that size are usually homemade, and filled with something like Roxul Safe n Sound, so not as dense or heavy and easier to place (or roll around if you have wheels).
Post by kcatthedog on Sept 29, 2022 9:19:13 GMT -6
What svart said ! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by yewtreemagic on Sept 29, 2022 9:22:39 GMT -6
A 4-inch thick panel can (if placed carefully) provide some absorption down to around 100Hz. For vocals I can't see any point in increasing the thickness beyond that.
Post by thehightenor on Sept 29, 2022 10:46:32 GMT -6
I have a large GIK portable folding panel behind me. Imho, it’s what behind the vocalist that counts, way more than what’s behind the mic (unless recording with a ribbon or omni pattern LDC) The mic is mainly “listening” to what’s in front of it, not what’s behind it. Though in my case I have treated behind the mic too ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by kcatthedog on Sept 29, 2022 11:04:08 GMT -6
Since the voice will project forward away from the vocalist and if there is absorption ahead of the vocalist, does what’s behind, if there are no other signal sources matter that much?
Post by ericn on Sept 29, 2022 11:18:22 GMT -6
Since the voice will project forward away from the vocalist and if there is absorption ahead of the vocalist, does what’s behind, if there are no other signal sources matter that much? Yes because first the radaiating pattern becomes Omni at any freq lower than a wave length longer than the baffle ( width of the head. Second absorption will not be greater than 80% . My advice take some acoustical measurements, and either get a consult from Headback or advise from GIK. I keep finding that most rooms treated strictly based on dimensions seam to have some unforeseen problems. Also as far as absorbing bass freq. if you measure the room silent with an RTA or FFT you might find some unforeseen noise issues that some LF absorbers can at least help with. Do it with and without HVAC and if you have any major appliances near by measure nous with and without.
Post by kcatthedog on Sept 29, 2022 14:48:26 GMT -6
Thx, I understand the theory but am wondering how much energy , after passing through absorbent, then gets reflected back into the room, passed the microphone a second time, then bounces off the back and side walls and comes back to get into the mike, if its a lot what's the point of absorbing at all .
Post by ericn on Sept 29, 2022 15:50:22 GMT -6
Thx, I understand the theory but am wondering how much energy , after passing through absorbent, then gets reflected back into the room, passed the microphone a second time, then bounces off the back and side walls and comes back to get into the mike, if its a lot what's the point of absorbing at all . It’s going to be more of what initially wraps around your head and reflects off the back, I can’t find a formula for figuring out when a oblong baffle ( your head ) effects directionality. So I’m sticking with the basic flat baffle if your head was 12 in wide it would go Omni from about 950hz down.
Post by kcatthedog on Sept 29, 2022 16:58:19 GMT -6
i am just wondering about one sound source, the vocalist, so their voice is the only sound source .
So, how can there be sound energy behind the vocalist if their voice is the only signal ?
If that signal goes directly into diffusion and absorption, back, sides and top, I just wonder how much sound/energy gets to the back of the room and then reflects back towards the mike?
I wouldn’t think much ?
But, If you have the whole band playing in the studio: one room, I completely understand your point !
Post by Tbone81 on Sept 29, 2022 17:58:21 GMT -6
i am just wondering about one sound source, the vocalist, so their voice is the only sound source . So, how can there be sound energy behind the vocalist if their voice is the only signal ? If that signal goes directly into diffusion and absorption, back, sides and top, I just wonder how much sound/energy gets to the back of the room and then reflects back towards the mike? I wouldn’t think much ? But, If you have the whole band playing in the studio: one room, I completely understand your point ! You're over thinking it ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) If someone has their back to you, you can still hear them talking. Sound waves aren't directional in the way that most of us visualize them. In air they act more like pressure waves than laser beams. Think about a light bulb and how it radiates light in all directions. If you block the light bulb with your head, some light will still wrap around it.
Post by christopher on Sept 29, 2022 18:00:15 GMT -6
As a performer, I like being next to a 5-8 foot wall of thick absorption. It’s tall enough to stand up and perform against or get a chair and feel like you are in a place to work. Right up next to it does feel incredibly dead, backing away gets a little more life. They are right the rest of the room will leak into the noise floor, it will still be a huge improvement though. If both sides absorb, should help dry up the room reverb a little. If the room sounds good, walls aren’t close by that might work out nicely. Then again, I’m not super picky. The GIK PIB might be something to look at as part 2? I like the idea, I’m not sure I’d be inspired to work in it though. www.gikacoustics.com/product/pib-portable-isolation-vocal-booth/?gclid=EAIaIQobChMIh8Siqpi7-gIVkmxvBB00rQZiEAQYASABEgI5MPD_BwE
Post by OtisGreying on Sept 29, 2022 19:51:28 GMT -6
Sounds like 7-8 inches was overkill then, I'll probably just do two rockwool baffles thick which is about 4-5 inches. That extra inch so I can sleep at night...
I actually do plan on having it behind the vocalist - when I was writing the post I realize it sounds like the other way around. It makes sense that the mic (especially cardiod) would pick up more reflections in front of it rather than behind...
I also have a bunch of DIY tube traps to work with. It's crazy how different it sounds singing into a tube trap (just in front of it, not recording) with 2MM plastic film on versus no plastic film. Never thought the difference would be THAT audible. Seems like a great way to have more high end in the vocal with that diffusion side being used in the tracking area. Excited to experiment with those as well.
Post by RealNoob on Sept 29, 2022 21:19:39 GMT -6
In a treated room, I built and used a V-shape frame with really heavy moving blankets. With lots of space behind them, they seem to do pretty well. The open end for the vocalist face a 4" panel behind the singer. The difference in a treated room even, was staggering.
Post by ericn on Sept 29, 2022 21:46:33 GMT -6
Sounds like 7-8 inches was overkill then, I'll probably just do two rockwool baffles thick which is about 4-5 inches. That extra inch so I can sleep at night... I actually do plan on having it behind the vocalist - when I was writing the post I realize it sounds like the other way around. It makes sense that the mic (especially cardiod) would pick up more reflections in front of it rather than behind... I also have a bunch of DIY tube traps to work with. It's crazy how different it sounds singing into a tube trap (just in front of it, not recording) with 2MM plastic film on versus no plastic film. Never thought the difference would be THAT audible. Seems like a great way to have more high end in the vocal with that diffusion side being used in the tracking area. Excited to experiment with those as well. you want both, most cardiods are more of a notch than as directional as most think. Oh and once again yup varies with Frq. Do a 360 of your favorite mic with headphones, for even a better lesson download a Freq generator app and do it at different freq. Even Ward will tell you learning the real world polar patterns of all of your mics will make you a better AE, and help make better choices on the fly. And yes as geeky as I am I did actually have a hot girlfriend in high school and still had time to do all this audio stuff, I just didn’t go to class.
Post by svart on Sept 30, 2022 6:30:26 GMT -6
I actually do plan on having it behind the vocalist - when I was writing the post I realize it sounds like the other way around. It makes sense that the mic (especially cardiod) would pick up more reflections in front of it rather than behind... I also have a bunch of DIY tube traps to work with. It's crazy how different it sounds singing into a tube trap (just in front of it, not recording) with 2MM plastic film on versus no plastic film. Never thought the difference would be THAT audible. Seems like a great way to have more high end in the vocal with that diffusion side being used in the tracking area. Excited to experiment with those as well. Think of a cardioid pattern.. Those side lobes are almost as sensitive as the focal point of the pickup pattern, but they'll be off-axis and picking up phased versions of the singer as well as the reflections. That's why I think of them as being just as important to control as on-axis signals. Also, what do you mean by 2mm plastic film? Traps should never have any air-tight material covering them. The whole point of the trap is to allow sound pressure wavefronts travelling through the air to enter the fiber structure of the mineral wool unimpeded and diffuse throughout it. Any type of plastic covering or even really tightly woven material will just reflect almost all frequencies and render the trap useless.
Post by kcatthedog on Sept 30, 2022 8:40:10 GMT -6
There is a school of thought to put thin plastic film .02 ml inside a diffusser to promote its diffusion snd that is stuffed it will absorb as well ?
Post by svart on Sept 30, 2022 9:06:33 GMT -6
There is a school of thought to put thin plastic film .02 ml inside a diffusser to promote its diffusion snd that is stuffed it will absorb as well ? Not that I'm aware of. The whole point of the mineral wool is that the fibers redirect sound waves and take small amounts of the energy out of the wave (similar to how billiard balls react when bouncing off each other. Higher frequencies have small amounts of power and smaller wavelengths so thinner panels work. Lower frequencies have much more power and have longer wavelengths which is why you need deeper panels to work. Any kind of solid barrier, even embedded in the fibers, will reduce the effectiveness of the depth of the fibers.
Post by christopher on Sept 30, 2022 9:13:09 GMT -6
Re: off axis, that reminds me why when Seawell did his 87 shootout I tested them all with EQ. Boosting highs and mids on Neumann 87 is a different experience than a million other popular clones. They seem tighter and don’t have so much room mixed in, it’s closer to a dynamic in terms of signal to ambience, maybe how I’d explain it? My experiment helped me notice the Serrano as a standout. Bees knees was very good too in a different way. Small sample size but enough to know I need to be more discerning. Summary: a great mic might solve some troubling room issues
Post by kcatthedog on Sept 30, 2022 9:36:17 GMT -6
Understood, but when I was researching diy diffusers a year or so ago that's when I bumped into this idea.
If one wants to experiment best to do before and after full freq sweep measurements.
Post by Tbone81 on Sept 30, 2022 9:36:57 GMT -6
There is a school of thought to put thin plastic film .02 ml inside a diffusser to promote its diffusion snd that is stuffed it will absorb as well ? Not that I'm aware of. The whole point of the mineral wool is that the fibers redirect sound waves and take small amounts of the energy out of the wave (similar to how billiard balls react when bouncing off each other. Higher frequencies have small amounts of power and smaller wavelengths so thinner panels work. Lower frequencies have much more power and have longer wavelengths which is why you need deeper panels to work. Any kind of solid barrier, even embedded in the fibers, will reduce the effectiveness of the depth of the fibers. Reducing the bandwidth of absorption is the goal when putting a thin plastic barrier on the face of a trap. Depending on the design, some people glue craft paper to the front face of the traps, or use wood slats. The barrier reflects mostly high frequencies while still allowing low frequency waves to be absorptive. You’re right though that at a certain point, if the barrier is too good the trap won’t work at all. But we’re only taking about a thin barrier covering only face of a trap so plenty of sound energy is still passing through the trap.
Post by Quint on Sept 30, 2022 9:59:42 GMT -6
Not that I'm aware of. The whole point of the mineral wool is that the fibers redirect sound waves and take small amounts of the energy out of the wave (similar to how billiard balls react when bouncing off each other. Higher frequencies have small amounts of power and smaller wavelengths so thinner panels work. Lower frequencies have much more power and have longer wavelengths which is why you need deeper panels to work. Any kind of solid barrier, even embedded in the fibers, will reduce the effectiveness of the depth of the fibers. Reducing the bandwidth of absorption is the goal when putting a thin plastic barrier on the face of a trap. Depending on the design, some people glue craft paper to the front face of the traps, or use wood slats. The barrier reflects mostly high frequencies while still allowing low frequency waves to be absorptive. You’re right though that at a certain point, if the barrier is too good the trap won’t work at all. But we’re only taking about a thin barrier covering only face of a trap so plenty of sound energy is still passing through the trap. I still don't get that logic. If the trap requires air movement thru it to work, hence the use of breathable fabric, even a thin film of plastic would completely cut off that air movement. As such, a thin layer of plastic would render the trap useless, based on my understanding of the necessity of air flow. Can anyone point me to where it is definitively explained that plastic film (or some other thin non-porous material) will still allow a trap to work? It just seems to me like a lot of hard work to build traps is getting undone by a little piece of plastic.
