Post by kcatthedog on Aug 9, 2022 10:15:17 GMT -6
Anybody heard/using this brand ? These are 7 grand, apparently their entry level !
Post by Johnkenn on Aug 9, 2022 10:55:21 GMT -6
“Never trust a man that paints his nails…”
Abraham Lincoln
Post by Deleted on Aug 9, 2022 11:07:58 GMT -6
This costs more than ATC, has dsp with a conversion step worse than what I already own, class d plate amps that will break and you won’t be able to repair them, and those co-ax Seas tweeters are wimpy. If they blow, do you have to replace the whole assembly? Pass.
Give me a normal soft dome.
Dan.
Post by indiehouse on Aug 9, 2022 12:16:49 GMT -6
This costs more than ATC, has dsp with a conversion step worse than what I already own, class d plate amps that will break and you won’t be able to repair them, and those co-ax Seas tweeters are wimpy. If they blow, do you have to replace the whole assembly? Pass. Give me a normal soft dome. Dan. Dan, are these facts? What's your information source?
Post by Deleted on Aug 9, 2022 13:14:33 GMT -6
This costs more than ATC, has dsp with a conversion step worse than what I already own, class d plate amps that will break and you won’t be able to repair them, and those co-ax Seas tweeters are wimpy. If they blow, do you have to replace the whole assembly? Pass. Give me a normal soft dome. Dan. Dan, are these facts? What's your information source? Their own website and common sense. This stuff that cost thousands of dollars with custom class d plate amp boards and dsp crossovers won’t be fixable by your tech in ten years when the small company that made them no longer exists. Meanwhile guys with passive speakers, Genelecs, and ATCs are still rocking.
Post by kcatthedog on Aug 9, 2022 14:12:11 GMT -6
And you can send your atc’s in for refurb!
Post by kcatthedog on Aug 9, 2022 16:02:34 GMT -6
For shits and giggles!
Post by thehightenor on Aug 10, 2022 11:52:25 GMT -6
Dan, are these facts? What's your information source? Their own website and common sense. This stuff that cost thousands of dollars with custom class d plate amp boards and dsp crossovers won’t be fixable by your tech in ten years when the small company that made them no longer exists. Meanwhile guys with passive speakers, Genelecs, and ATCs are still rocking. ATC's active monitor class A/B amps are very repairable too, as they're discreet electronics and ATC will even repair and service their products from back in the 1970's!
