Post by RealNoob on Jun 10, 2022 10:14:33 GMT -6
I have 3 pair and a sub. I see the Heritage and an option from Drawmer that allows for 2 set of inputs (important to me) and enough outputs to run all of this. The Drawmer is less.
Would you expect an appreciable quality difference between the 2 brands? I don't want a Presonus equivalent. Try9ing to keep it under a grand. Thanks.
Post by Blackdawg on Jun 10, 2022 13:48:56 GMT -6
Post by mcirish on Jun 10, 2022 15:10:49 GMT -6
I use a Dangerous Monitor ST. Find a used one. It does just what you want. Excellent monitor controller.
Post by progear on Jun 11, 2022 4:56:08 GMT -6
I use Grace M905 and love it
Post by theshea on Jun 11, 2022 5:04:45 GMT -6
i am using the mackie big knob passive. some say it sucks tone but i don‘t hear a change so it works for me. is cheap. you would have to choose the bigger model though as you need more than 2 outputs.
Post by deaconblues on Jun 11, 2022 7:35:45 GMT -6
I use Grace M905 and love it Any cons on these besides the price?
Post by Guitar on Jun 11, 2022 8:09:57 GMT -6
The big Drawmers are good (I have an MC2.1,) but they have an Achille's Heel. The potentiometers WILL go bad, and you can replace them, then those will go bad again. Resulting in crackly noise and screwing with your stereo image. It's annoying.
But other than that, they are nearly "perfect."
Post by progear on Jun 11, 2022 10:26:49 GMT -6
I use Grace M905 and love it Any cons on these besides the price? Just the price… great product, built like a tank, sounds freaking amazing
Post by Quint on Jun 11, 2022 12:02:42 GMT -6
The big Drawmers are good (I have an MC2.1,) but they have an Achille's Heel. The potentiometers WILL go bad, and you can replace them, then those will go bad again. Resulting in crackly noise and screwing with your stereo image. It's annoying. But other than that, they are nearly "perfect." I just replaced the pot on mine. It was $20 though, and easy to order from Drawmer. It's also a simple molex plug and play thing, so it's super easy to swap out. Pretty painless, considering how much I like the price and feature set of the MC2.1. If I ever need to replace the pot again, I might explore buying one of those expensive Goldpoint switched attenuators. Didn't you swap out your pot too?
Post by Guitar on Jun 11, 2022 12:03:50 GMT -6
The big Drawmers are good (I have an MC2.1,) but they have an Achille's Heel. The potentiometers WILL go bad, and you can replace them, then those will go bad again. Resulting in crackly noise and screwing with your stereo image. It's annoying. But other than that, they are nearly "perfect." I just replaced the pot on mine. It was $20 though, and easy to order from Drawmer. It's also a simple molex plug and play thing, so it's super easy to swap out. Pretty painless, considering how much I like the price and feature set of the MC2.1. if I ever need to replace the pot again, I might explore buying one of those expensive Goldpoint switched attenuators. Didn't you swap out your pot too? I've done the swap, yeah, and Goldpoint is the obvious next destination for me too. Just putting it off. Potting it off.
Post by RealNoob on Jun 11, 2022 12:33:29 GMT -6
The big Drawmers are good (I have an MC2.1,) but they have an Achille's Heel. The potentiometers WILL go bad, and you can replace them, then those will go bad again. Resulting in crackly noise and screwing with your stereo image. It's annoying. But other than that, they are nearly "perfect." I just replaced the pot on mine. It was $20 though, and easy to order from Drawmer. It's also a simple molex plug and play thing, so it's super easy to swap out. Pretty painless, considering how much I like the price and feature set of the MC2.1. If I ever need to replace the pot again, I might explore buying one of those expensive Goldpoint switched attenuators. Didn't you swap out your pot too? You're saying it is not a solder job, just a connector for the Pot?
Post by Quint on Jun 11, 2022 12:37:12 GMT -6
I just replaced the pot on mine. It was $20 though, and easy to order from Drawmer. It's also a simple molex plug and play thing, so it's super easy to swap out. Pretty painless, considering how much I like the price and feature set of the MC2.1. If I ever need to replace the pot again, I might explore buying one of those expensive Goldpoint switched attenuators. Didn't you swap out your pot too? You're saying it is not a solder job, just a connector for the Pot? Yep. It took longer to unscrew the lid off of the box than it did to swap out the pot. Pretty damn quick.
Post by tim on Jun 11, 2022 13:26:22 GMT -6
That new SPL has everything you need. Just a little over your budget though. I have their 2control and it’s a solid monitor controller for under 1k.
Post by Guitar on Jun 11, 2022 14:55:26 GMT -6
You're saying it is not a solder job, just a connector for the Pot? Yep. It took longer to unscrew the lid off of the box than it did to swap out the pot. Pretty damn quick. The new parts go bad too... in my case, rather quickly. It probably varies, a bit, the lenght of this thing.
Post by Quint on Jun 11, 2022 14:57:25 GMT -6
Yep. It took longer to unscrew the lid off of the box than it did to swap out the pot. Pretty damn quick. The new parts go bad too... in my case, rather quickly. It probably varies, a bit, the lenght of this thing. It took me about five years before mine started getting scratchy. Either way, if it ever happens again, $20 and an easy swap ain't too bad. But I'll probably just swing for the Goldpoint next time anyway.
Post by RealNoob on Jun 11, 2022 18:20:08 GMT -6
