Post by mediatechnology on Jun 8, 2022 17:42:58 GMT -6
Wanted to share a pic of my new Wet Dry Mix Add "WDMA" Parallel Processor board.  The board has two pairs of inputs, Wet and Dry that sum into the final Mix output. The Mix mode uses a four section stepped switch to provide crossfading between Wet and Dry. Add forwards the Dry input at fixed gain to the output. Wet is folded in with variable level. If only the Add mode is desired a two section stepped switch can be used. An external gain trim switch allows +/- 5.5 dB gain correction in the Mix amp to normalize processed levels. The board has two soft bypass modes. When bypassed either the Wet or Dry input can be used as the bypass source. Dry permits pre-post comparison. Wet bypasses the parallel processor leaving the Wet signal path inline for conventional "serial" processing. The inputs and outputs are fully-balanced using THAT line drivers and receivers. The WDMA is available assembled and tested, a board with ICs or a bare PC board. Learn more about the "WDMA" Parallel Processor board here: ka-electronics.com/shop/index.php?route=product/product&path=60&product_id=124
